2 Replies Latest reply on Jul 11, 2007 7:36 AM by ronchan
    Putting Images with Files
    ronchan Level 1
      For some reason in CS3 when I PUT an HTML file to the server, images in the HTML file that are new or updated won't upload to the server at the same time. I have to select the image file from the Site and upload it or select the image in the HTML file and right click then PUT the file. Needless to say this is very annoying and time consuming. This all worked fine in DW8 and am wondering if I am missing a setting or pref that is causing this new behavior?
      Thanks.
        • 1. Re: Putting Images with Files
          Level 7
          > the
          > time.
          > image
          > is
          > wondering
          Yes, there is a setting. Under preferences you need to look at
          Edit > Preferences > select Site --- see Dependent Files - Prompt on
          put/check. Checked, this will then ask you if you want to put the
          dependent files to which you would answer "yes".
          • 2. Re: Putting Images with Files
            ronchan Level 1
            Thanks!!
