Hi All-
I have two select dropdowns. When one dropdown is selected, the other dropdown value selected to a default value which is 0 in my case and viceversa. We had to convert our dropdowns to extJS combobox to include search functionality in the dropdown. How can I achieve the above in extJS. In javascript I can simply use onchange function and get what I want, but not able to do the same in extJS.
Here is the code I have till now
Ext.onReady(function(){
var converted = new Ext.form.ComboBox({
typeAhead: true,
triggerAction: 'all',
transform:'id_Select1',
width:600,
forceSelection:true,
emptyText:'Select' }
var converted2 = new Ext.form.ComboBox({
typeAhead: true,
transform:'id_select2',
width:600,
emptyText:'Select'
}); I have two select drop downs populated from database
You might want to post this question on a forum for ExtJS.
This is fairly easy to do. If you need help with using CF Query info with ExtJS
directly you can check out my CFQueryReader for ExtJS (http://cfqueryreader.riaforge.
org). A good post for ExtJS related selects is:
http://www.webeks.net/programming/extjs/dynamic-cascading-linked-combobox.html
