3 Replies Latest reply on Nov 16, 2010 4:32 AM by Ned Murphy
    Splitting up strings
    celebritymusic Level 1
      Hi
      I'm trying to take the letters I have in a string var, eg "EXAMPLE", and display them in a textField like so:
      E
      X
      A
      M
      P
      L
      E
      Maybe I'm trying to make it too complicated, but I can't seem to figure it out.  I'm using the following code:
      var str:String = segmentName;
            var re:RegExp = /(\S)/;
            var results_array:Array = str.split(re);
            for (var i2:String in results_array)
          text_field_mc.text = results_array[i2];
          trace(results_array[i2]);
      The textFeild shows nothing (the textField is coded correctly, as it shows regular strings).  However, the trace shows it as:
      E
      X
      A
      M
      P
      L
      E
      I've got the textfield set large enough to accomodate the text.
      Is there a better way to split a string into individual letters, and then display them in a field one above the other?  I thought \n\r might have come into it, but I can't make them fit into the above example.
      Cheers
      Shaun
      Shaun
