2 Replies Latest reply on Nov 19, 2010 1:06 PM by jvenkatrao
    RenderPDFForm using Invocation API
    jvenkatrao
      I have a short-lived process which renders PDF Form. This process takes two inputs. Form and Form Data. Form data can be PDF/XDP file and Form Data needs to be in XML format. The process works just fine within Workbench with either XDP or PDF file as input Form. When I invoke the process using Java API using a servlet, it says "The File is damaged and could not be repaired." This happens only if the input Form is a PDF file. If the input is in XDP format, I do not see any problem.
      Any ideas ?
      Jyothi
