1. Re: Dynamically set image path
bizcontentNR Nov 16, 2010 10:01 PM (in response to past-tense)Hello Scott,
click on the image Field. Pres Shift+F7. the object properties Palette appears on the right.
On the Object Tab --> Field Tab --> there are 2 properties
URL and a check Box called Embed Image data.
Will these help ?
If not, Try setting the Binding value of the Image field to a Data connection field , that will hold the url at run time
Let me know if this helped
Nanda
2. Re: Dynamically set image path
past-tense Nov 17, 2010 9:01 AM (in response to bizcontentNR)Hi there,
Thanks for your reply. The URL field is useful only to set a default image path. under the binding tab, when I bind the image to the url from a data connection, the url is displayed as text within the image field. No image appears.
The only solution that I've found online is to somehow get the image converted to base64... the issue is that the only technologies that I have available to me are SQL or javascript... neither of which were designed to convert images to base64.
Does onyone know where I can find a javascript function to convert an image to base64?
- Scott
3. Re: Dynamically set image path
bizcontentNR Nov 17, 2010 8:43 PM (in response to past-tense)Hello Scott,
I am using Images in my form too., But we dont store the path of the image in our database. We store the image itself as a blob in the database table datatype varbinary(max). We are using SQlServer 2008. So binding the Image field to the blob object displays it perfectly, no extra conversion is required.
Is that an option for you ?
regards
Nanda
