2 Replies Latest reply on Nov 16, 2010 4:14 PM by the_wine_snob
    Splitting Large Video Files
    thisisJules75 Level 1
      I have just finished crafting my sisters wedding video and the  resultant M2T file generated by PE9 is 10GB - and looks great on the computer.  However,the file size has presented a problem, how  on earth do I get it onto a PS3?  For my home PS3, I can transfer  it over wireless.  But my plan to ship it on a USB stick for my sister  to put in her PS3 has come undone thanks to the FAT file size  limitations.
      So apart from reducing the video quality or  buying a bluray burner (neither option attractive), how can I do it?  If I could split it the file up into smaller parts I could create a playlist on the PS3 to join the  parts together but I'm not exactly keen on rendering lots of small parts with PE9.  I guess I'm looking for some 3rd party tool to split the M2t file?
      Any ideas?
        • 1. Re: Splitting Large Video Files
          Ted Smith Level 3
          You could try hjsplit a free utility.
          This will break it up into parts small enough to put on memory sticks or normal DVD disks
          Then she would have to reassemble them with a copy of hjsplit on her computer into one file.
          dont know if this would work on PS3 or not
          Alternately copy the project three times and delete a part of each, leaving one third on each.
          You would then have 3 smaller projects that should fit on a normal DVD.
          This will also play in most Blue ray players just like a Blue ray disk (does on my Pioneer).
          Set each going when you go to bed and it will only take you 3 nights!
          • 2. Re: Splitting Large Video Files
            the_wine_snob Level 9
            The splitting will certainly work, with a bit of effort and downloading two copies (one for you and one for her) of the free utility - great utility, BTW.
            You could also pick up an external with USB connections, Convert it to NTSF, and then the file size limitation goes away. Now, whether a PS3 will read NTSF is beyond my knowledge. Also, I do not know if a memory stick can be Converted. Just in case, this ARTICLE will give you tips.
            Were it me, I'd opt for the BD burner route, but even with the prices falling, I understand why one might not run that out instantly.
