1 Reply Latest reply on Nov 16, 2010 8:21 PM by Todd_Kopriva
    ImportREDServer.exe Running Multiple Instances
    sologuy
      When I launch Premiere CS5 it starts up 8 instances of ImportREDServer.exe (see attached). Is this normal? Also, when I am opening my project (1200+ R3D clips), it loads a few hundred then freezes (not responding) for 30 - 60 seconds, then loads a few hundred more, and so on. I don't know if these are related. However, when I open the CS4 version of the project in CS4 it loads much faster and smoother. Any thoughts?
      Specs:
      Premiere 5.0.2
      Windows 7 64 bit
      6GB RAM
      i7 1.6GHz
      Firewire 800 6TB LaCie connected via ExpressCard Adapter
        • 1. Re: ImportREDServer.exe Running Multiple Instances
          Todd_Kopriva Level 8
          Yes, it is normal for multiple instances of ImporterREDServer to start---up to one per processor core.
          You have a rather small amount of RAM for a computer with eight processors. If there are several instances of the RED importer running for loading hundreds of RED clips, it's going to take a while, especially if these instances are fighting over a small amount of RAM. Whenever software fights over RAM, you run into delays, especially if the contents of the RAM end up getting swapped to the hard disk.
          I have 24GB of RAM in my home computer with the same number of processor cores that you have. It makes a great positive difference.
