2 Replies Latest reply on Nov 22, 2010 9:35 AM by Tanu Jain
    Call back function for dataTips
    rob_phelan
      I'm trying to develop sample applications using SAP as the backend system, so I'm limited to Flex 3.
      I'm trying to build a Plot Chart that simply plots the Cost and Expense of a project. I'm passing in an array of 10 - 20 projects with Project Name, Cost, and Expense.
      I'm able to display the all points just fine, but I can't get the dataTips to display the name of the project. I was told I had to use some sort of callback function using HitData class.
      Can someone shed some light on this?
      thanks,
      robert.
        • 1. Re: Call back function for dataTips
          rob_phelan Level 1
          I'll include some code to help clarify....
          Bindable]
          public var dataSource:ArrayCollection;
          Bindable]
          public var prjcost:String;
          Bindable]
          public var prjbenefit:String;
          Bindable]
          public var prjname:String;
          <mx:PlotChart id="plotchart1" dataProvider="{dataSource}" showDataTips="true" >
            <mx:series>
              <mx:PlotSeries yField="{prjcost}" xField="{prjbenefit}"/>
            </mx:series>
          </mx:PlotChart>
          If i add displayName="{prjname}" to the PlotSeries, i do not get the text value - only the name of the attribute I'm passing in.
          • 2. Re: Call back function for dataTips
            Tanu Jain Level 2
            In mxml,
            <mx:PlotChart dataTipFunction="myDatatipFunction">
            private function myDataTipFunction(hitData:HitData):String
                            return  "<b>" +
            hitData.item.prjname
                                + "\nBenefit: " + hitData.item.prjbenefit
                                + "\nCost: " + hitData.item.prjcost ;
            Hopefully ur dataSource is a collection of prjname,prjbenefit and prjCost.
