4 Replies Latest reply: Nov 28, 2011 9:14 AM by heatherp123 RSS
    Full Motion recording screen size
    JamiNL Community Member
      I've updated a project from v3 to v5.  The full motion recordings are not displaying correctly.  They appear to be zoomed in and part of the screen is cut off.  This occurs when editing the slides as well as after published.  The recordings were originally made in 1024x768 then resized to 800x600.  When converting to v4 the recordings are fine, but going from v3 to v5 or v4 to v5 causes this issue.  This is happening on all projects.  Any thoughts?
        • 1. Re: Full Motion recording screen size
          M_Anand Community Member
          Hi There,
          I could see your issue.
          I guess there is some issue in Captivate 5. However, the good thing is that - I upgraded my project(1024X768) from V3 to V5(still 1024X768) and then in V5, resized my projec to 800 X 600 - and I got perfect results.
          So for now, the ideal thing would be resizing the project after upgrading to V5.
          Do let us know whether this resolved your issue...
          -Manish
          blogs.adobe.com/captivate
          • 2. Re: Full Motion recording screen size
            Hi There,
            I could see your issue. I think there is an issue with Captivate 5.
            However, the good thing is that - I upgraded my V3 project ( that is 1024 X 768) to V5 ( still 1024 X 768) and then in V5, I resized my project. This totally worked fine for me. So ideal thing for now is to upgrade your project as-is from V3 to V5 and then resize the project in V5.
            -Manish
            • 3. Re: Full Motion recording screen size
              Thanks Manish!  This worked for me as well.  Fortunately I had most of my older recordings and was able to easily copy and paste the full motion recordings to the new project.  I did notice that this did not occur on all of my projects only the ones that were capturing screens from a Citrix environment.  Perhaps that could be the issue.
              Thanks again!  You saved me a ton of work.
              Jami
              • 4. Re: Full Motion recording screen size
                heatherp123 Community Member
                I am having this same issue, but do not have access to the original 1024X768 recorded files.  So I've got half a project in 800X600, and then the FRM slides are 1024X768 and truncated when published or previewed.  Is there not some easy way to resize just the individual FMR slides within the same project (I'd hate to have to Copy/Paste all the slide into a new file, resize there, then Copy/Past back again, but I will if I must)??  Any other thoughts on this?
