1 Reply Latest reply on Nov 17, 2010 10:29 PM by Mylenium
    Undo group mismatch, will attempt to fix
    Josh mehler
      Is anyone getting this error?  I'm getting this over and over.
      Process:         After Effects [873]
      Path:            /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/MacOS/After Effects
      Identifier:      com.adobe.AfterEffects
      Version:         10.0.1 (10.0)
      Code Type:       X86-64 (Native)
      Parent Process:  launchd [342]
      Date/Time:       2010-11-17 17:54:59.355 -0800
      OS Version:      Mac OS X 10.6.5 (10H574)
      Report Version:  6
      Interval Since Last Report:          77764 sec
      Crashes Since Last Report:           3
      Per-App Interval Since Last Report:  20671 sec
      Per-App Crashes Since Last Report:   2
      Anonymous UUID:                      E8BA9497-8C58-4B8A-9FB7-18E0A7E93E48
      Exception Type:  EXC_BAD_ACCESS (SIGABRT)
      Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000100fd6ff0
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Application Specific Information:
      abort() called
      Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
      0   libSystem.B.dylib                 0x00007fff827a5616 __kill + 10
      1   libSystem.B.dylib                 0x00007fff82845cca abort + 83
      2   U.dylib                           0x0000000102a89867 U_LoadFrameworkBundle + 695
      3   libSystem.B.dylib                 0x00007fff827b767a _sigtramp + 26
      4   ???                               0x00007fff5fbfdf20 0 + 140734799798048
      5   ...e.AfterEffectsLib.framework    0x0000000100b51982 CRQRenderSettings::SetRS_FromPref(int) + 61698
      6   ...e.AfterEffectsLib.framework    0x0000000100b529a4 CRQRenderSettings::SetRS_FromPref(int) + 65828
      7   ...e.AfterEffectsLib.framework    0x0000000100b5a20b CRQRenderSettings::SetRS_FromPref(int) + 96651
      8   ...e.AfterEffectsLib.framework    0x0000000100b498f9 CRQRenderSettings::SetRS_FromPref(int) + 28793
      9   ...e.AfterEffectsLib.framework    0x0000000100a1d7e3 COutlineDir::GetOutlinePano() + 23411
      10  ...e.AfterEffectsLib.framework    0x0000000100a1ff45 COutlineDir::GetOutlinePano() + 33493
      11  ...e.AfterEffectsLib.framework    0x0000000100af0811 CTLOutlinePano::CenterCurrentTimeIfNecessary() + 8865
      12  ...e.AfterEffectsLib.framework    0x00000001006d4679 CView::DispatchMouseEvent(ae::egg::MouseEvent const&) + 393
      13  ...e.AfterEffectsLib.framework    0x00000001006d4594 CView::DispatchMouseEvent(ae::egg::MouseEvent const&) + 164
      14  ...e.AfterEffectsLib.framework    0x00000001006d4594 CView::DispatchMouseEvent(ae::egg::MouseEvent const&) + 164
      15  ...e.AfterEffectsLib.framework    0x0000000100702ad8 dvacore::utility::SearchLiveHelp(std::basic_string<unsigned short, std::char_traits<unsigned short>, std::allocator<unsigned short> >) + 7480
      16  ...e.AfterEffectsLib.framework    0x0000000100a17c0e GetCEffects(BEE_Layer*) + 67326
      17  com.adobe.dvaui.framework         0x00000001031d9822 dvaui::ui::UI_Node::UI_DispatchMouseEventToLeaf(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&) + 146
      18  com.adobe.dvaui.framework         0x00000001031dc7d5 dvaui::ui::UI_Node::DispatchMouseEvent::operator()(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvacore::geom::PointT<float> const&) const + 165
      19  com.adobe.dvaui.framework         0x00000001031e6243 std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeafT<dvaui::ui::UI_Node::DispatchMouseEv ent>(dvaui::ui::UI_Node::DispatchMouseEvent&, dvacore::geom::PointT<float> const&, bool) + 131
      20  com.adobe.dvaui.framework         0x00000001031e0613 dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeaf(dvaui::ui::MouseEvent const&, bool) + 83
      21  com.adobe.dvaui.framework         0x00000001031e1dcf dvaui::ui::UI_Node::UI_DispatchMouseEventToTarget(dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&, bool) + 159
      22  com.adobe.dvaui.framework         0x00000001031e1eb4 dvaui::ui::UI_Node::UI_DispatchMouseEvent(dvaui::ui::MouseEvent const&, bool) + 68
      23  com.adobe.dvaui.framework         0x0000000103255433 dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEvent const&, bool) + 595
      24  com.adobe.dvaui.framework         0x0000000103251249 dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_Event const&) + 313
      25  com.adobe.dvaui.framework         0x00000001032578a2 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 450
      26  com.adobe.dvaui.framework         0x000000010324238f dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 31
      27  com.adobe.dvaui.framework         0x000000010324808b dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 59
      28  com.adobe.dvacore.framework       0x0000000102d4de16 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 38
      29  ...e.AfterEffectsLib.framework    0x0000000100663396 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5382
      30  ...e.AfterEffectsLib.framework    0x00000001006634c1 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5681
      31  com.adobe.dvacore.framework       0x0000000102d4ccf5 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 197
      32  com.adobe.dvacore.framework       0x0000000102d4ec83 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 99
      33  com.adobe.dvaui.framework         0x000000010324b34d -[DVAMacContainerView mouseDown:] + 253
      34  com.apple.AppKit                  0x00007fff8024534f -[NSWindow sendEvent:] + 5409
      35  com.apple.AppKit                  0x00007fff8017aa86 -[NSApplication sendEvent:] + 4719
      36  com.adobe.dvaui.framework         0x0000000103243d6f -[DVAMacApplication sendEvent:] + 223
      37  ...e.AfterEffectsLib.framework    0x0000000100470f73 0x10046a000 + 28531
      38  com.apple.AppKit                  0x00007fff801114da -[NSApplication run] + 474
      39  ...e.AfterEffectsLib.framework    0x00000001006b74a2 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 16386
      40  ...e.AfterEffectsLib.framework    0x000000010066181c SetAPETerminateFunc(boost::function<void ()()> const&) + 1308
      41  ...e.AfterEffectsLib.framework    0x0000000100661ee4 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 84
      42  com.adobe.AfterEffects            0x00000001000043b8 main + 1144
      43  com.adobe.AfterEffects            0x0000000100003895 _start + 227
      44  com.adobe.AfterEffects            0x00000001000037b1 start + 33
      Thread 1:  Dispatch queue: com.apple.libdispatch-manager
      0   libSystem.B.dylib                 0x00007fff8277016a kevent + 10
      1   libSystem.B.dylib                 0x00007fff8277203d _dispatch_mgr_invoke + 154
      2   libSystem.B.dylib                 0x00007fff82771d14 _dispatch_queue_invoke + 185
      3   libSystem.B.dylib                 0x00007fff8277183e _dispatch_worker_thread2 + 252
      4   libSystem.B.dylib                 0x00007fff82771168 _pthread_wqthread + 353
      5   libSystem.B.dylib                 0x00007fff82771005 start_wqthread + 13
      Thread 2:
      0   libSystem.B.dylib                 0x00007fff82791fca __semwait_signal + 10
      1   libSystem.B.dylib                 0x00007fff82795de1 _pthread_cond_wait + 1286
      2   com.adobe.amt.services            0x000000010c697c53 AMTConditionLock::LockWhenCondition(int) + 37
      3   com.adobe.amt.services            0x000000010c690cce _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 92
      4   com.adobe.amt.services            0x000000010c697cbe AMTThread::Worker(void*) + 28
      5   libSystem.B.dylib                 0x00007fff82790536 _pthread_start + 331
      6   libSystem.B.dylib                 0x00007fff827903e9 thread_start + 13
      Thread 3:
      2   ...ple.CoreServices.CarbonCore    0x00007fff84ce4e27 TSWaitOnCondition + 118
      3   ...ple.CoreServices.CarbonCore    0x00007fff84c54310 TSWaitOnConditionTimedRelative + 177
      4   ...ple.CoreServices.CarbonCore    0x00007fff84c4e21b MPWaitOnQueue + 215
      5   ...e.Frameworks.ASL.Foundation    0x0000000104dc2080 ASL::(anonymous namespace)::TaskProc(void*) + 96
      6   ...ple.CoreServices.CarbonCore    0x00007fff84c26411 PrivateMPEntryPoint + 63
      7   libSystem.B.dylib                 0x00007fff82790536 _pthread_start + 331
      8   libSystem.B.dylib                 0x00007fff827903e9 thread_start + 13
      Thread 4:
      5   AdobeACE                          0x0000000108eff18d 0x108ec5000 + 237965
      6   AdobeACE                          0x0000000108efeb3a 0x108ec5000 + 236346
      7   ...ple.CoreServices.CarbonCore    0x00007fff84c26411 PrivateMPEntryPoint + 63
      8   libSystem.B.dylib                 0x00007fff82790536 _pthread_start + 331
      9   libSystem.B.dylib                 0x00007fff827903e9 thread_start + 13
      Thread 5:
      Thread 6:
      Thread 7:
      Thread 8:
      Thread 9:
      Thread 10:
      Thread 11:
      5   com.adobe.dvacore.framework       0x0000000102db5a1f dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 143
      6   com.adobe.dvacore.framework       0x0000000102d4ed5e boost::function0<void>::operator()() const + 46
      7   com.adobe.dvacore.framework       0x0000000102dade53 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
      8   ...obe.boost_threads.framework    0x0000000107fd4ac4 thread_proxy + 132
      9   libSystem.B.dylib                 0x00007fff82790536 _pthread_start + 331
      10  libSystem.B.dylib                 0x00007fff827903e9 thread_start + 13
      Thread 12:
      Thread 13:
      Thread 14:
      Thread 15:
      Thread 16:
      Thread 17:
      Thread 18:
      1   ...dobe.dvatransport.framework    0x0000000107d2ec4e boost::asio::detail::kqueue_reactor<false>::run(bool) + 478
      2   ...dobe.dvatransport.framework    0x0000000107d2fd05 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 517
      3   ...dobe.dvatransport.framework    0x0000000107d0d8cc SkyConnectionEnv::MainLoop() + 76
      4   ...dobe.dvatransport.framework    0x0000000107d0d939 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
      5   ...obe.boost_threads.framework    0x0000000107fd4ac4 thread_proxy + 132
      6   libSystem.B.dylib                 0x00007fff82790536 _pthread_start + 331
      7   libSystem.B.dylib                 0x00007fff827903e9 thread_start + 13
      Thread 19:
      2   ...dobe.dvatransport.framework    0x0000000107d2fe3f boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 831
      3   ...dobe.dvatransport.framework    0x0000000107d30a35 boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service<boost::asio ::ip::tcp>::work_io_service_runner>::run() + 53
      4   ...dobe.dvatransport.framework    0x0000000107d15c79 asio_detail_posix_thread_function + 25
      Thread 20:
      Thread 21:
      Thread 22:
      Thread 23:
      2   com.adobe.AfterEffects.MThread    0x00000001377f6a8f main + 20783
      3   com.adobe.dvacore.framework       0x0000000102d4ed5e boost::function0<void>::operator()() const + 46
      4   com.adobe.dvacore.framework       0x0000000102dade53 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
      Thread 24:
      Thread 25:
      Thread 26:
      Thread 27:
      Thread 28:
      Thread 29:
      Thread 30:
      Thread 31:
      Thread 32:
      2   com.adobe.AfterEffects.OpenEXR    0x000000013a5fa4c6 IlmThread::Semaphore::wait() + 70
      3   com.adobe.AfterEffects.OpenEXR    0x000000013a5f933c IlmThread::(anonymous namespace)::WorkerThread::run() + 188
      4   libSystem.B.dylib                 0x00007fff82790536 _pthread_start + 331
      5   libSystem.B.dylib                 0x00007fff827903e9 thread_start + 13
      Thread 33:
      Thread 34:
      Thread 35:
      Thread 36:
      Thread 37:
      Thread 38:
      Thread 39:
      Thread 40:
      1   libSystem.B.dylib                 0x00007fff82791e59 nanosleep + 148
      2   ...dobe.AfterEffects.Scripting    0x000000013b296c7b zcfree + 197989
      3   ...dobe.AfterEffects.Scripting    0x000000013b279c93 zcfree + 79229
      4   ...dobe.AfterEffects.Scripting    0x000000013b296d76 zcfree + 198240
      Thread 41:
      2   libtbb.dylib                      0x000000010001222c tbb::internal::GenericScheduler::wait_while_pool_is_empty() + 92
      3   libtbb.dylib                      0x000000010001cb84 tbb::internal::CustomScheduler<tbb::internal::IntelSchedulerTraits>::wait_for_all(tbb::ta sk&, tbb::task*) + 1858
      4   libtbb.dylib                      0x0000000100014e3a tbb::internal::GenericScheduler::worker_routine(void*) + 632
      Thread 42:
      Thread 43:
      Thread 44:
      Thread 45:
      Thread 46:
      Thread 47:
      Thread 48:  com.apple.CFSocket.private
      0   libSystem.B.dylib                 0x00007fff8279ae92 select$DARWIN_EXTSN + 10
      1   com.apple.CoreFoundation          0x00007fff83eda498 __CFSocketManager + 824
      2   libSystem.B.dylib                 0x00007fff82790536 _pthread_start + 331
      3   libSystem.B.dylib                 0x00007fff827903e9 thread_start + 13
      Thread 49:
      0   libSystem.B.dylib                 0x00007fff8275733a semaphore_timedwait_signal_trap + 10
      1   libSystem.B.dylib                 0x00007fff82795cd2 _pthread_cond_wait + 1015
      2   ...ple.CoreServices.CarbonCore    0x00007fff84c54330 TSWaitOnConditionTimedRelative + 209
      3   ...ple.CoreServices.CarbonCore    0x00007fff84c540de TSWaitOnSemaphoreCommon + 416
      4   ...ple.CoreServices.CarbonCore    0x00007fff84c53ddc AsyncFileThread(void*) + 61
      Thread 50:
      2   com.apple.audio.CoreAudio         0x00007fff84ae567c CAGuard::WaitFor(unsigned long long) + 168
      3   com.apple.audio.CoreAudio         0x00007fff84ae7c0b CAGuard::WaitUntil(unsigned long long) + 185
      4   com.apple.audio.CoreAudio         0x00007fff84ae5d75 HP_IOThread::WorkLoop() + 1369
      5   com.apple.audio.CoreAudio         0x00007fff84ae5817 HP_IOThread::ThreadEntry(HP_IOThread*) + 9
      6   com.apple.audio.CoreAudio         0x00007fff84ae5745 CAPThread::Entry(CAPThread*) + 125
      Thread 51:
      0   libSystem.B.dylib                 0x00007fff82770f8a __workq_kernreturn + 10
      1   libSystem.B.dylib                 0x00007fff8277139c _pthread_wqthread + 917
      2   libSystem.B.dylib                 0x00007fff82771005 start_wqthread + 13
      Thread 52:
      Thread 53:
      Thread 54:
      Thread 0 crashed with X86 Thread State (64-bit):
        rax: 0x0000000000000000  rbx: 0x00007fff5fbfda90  rcx: 0x00007fff5fbfda68  rdx: 0x0000000000000000
        rdi: 0x0000000000000369  rsi: 0x0000000000000006  rbp: 0x00007fff5fbfda80  rsp: 0x00007fff5fbfda68
         r8: 0x0000000102a96760   r9: 0x00000001301fc200  r10: 0x00007fff827a1656  r11: 0x0000000000000202
        r12: 0x00007fff5fbfdaa0  r13: 0x00007fff5fbfe150  r14: 0x000000010e140570  r15: 0x000000010c93b010
        rip: 0x00007fff827a5616  rfl: 0x0000000000000202  cr2: 0x000000010ca01200
      Binary Images:
             0x100000000 -        0x100004ff3 +com.adobe.AfterEffects 10.0.1 (10.0) <6B57EDE6-8898-E72E-05C0-D54EA9E78EF7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/MacOS/After Effects
             0x100009000 -        0x100022feb +libtbb.dylib ??? (???) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/libtbb.dylib
             0x100033000 -        0x100039feb +libtbbmalloc.dylib ??? (???) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/libtbbmalloc.dylib
             0x100040000 -        0x10004cff5 +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.213330) <7C5184BC-4FE9-56D9-CAE9-49D669C6108B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
             0x10005e000 -        0x10005ffff +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.213330) <5B2E6816-3C31-78F7-A163-368475286EDA> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
             0x100065000 -        0x10006cff3 +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.213330) <784431BB-1A4A-5F0F-4641-0541FE7F4430> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
             0x10007c000 -        0x100081ffd +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <DFFB9A08-8369-D65F-161F-7C61D562E307> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
             0x100086000 -        0x1001c9fef +WRServices ??? (???) <DD50D315-C0EC-C729-AC67-92588187E8C7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
             0x100215000 -        0x100319fef +hydra_filters ??? (???) <177463AB-3833-13B3-20B3-7B228BE9BC9C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/hydra_filters.framework/Versions/A/hydra_filters
             0x10040e000 -        0x10042cfff +image_runtime ??? (???) <5896DB90-E23E-5C6E-98E5-8E52698ACE61> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
             0x100466000 -        0x100467fff +ALOG.dylib ??? (???) <247DF308-661D-FC7A-4A53-C8EA58CB478C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ALOG.dylib
             0x10046a000 -        0x100e3efef +com.adobe.AfterEffectsLib.framework AfterFXLib 1.0 (1.0) <8B3C384E-FD17-7C25-FC5B-2D226C5A30DA> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AfterFXLib.framework/Versions/A/AfterFXLib
             0x101197000 -        0x101197ff7 +AEFX.dylib ??? (???) <87957ABB-824B-D113-11F1-E9950FBC356E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AEFX.dylib
             0x10119a000 -        0x101555fe7 +BEE.dylib ??? (???) <C494E8DB-1734-E409-6792-B49FD70F809F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BEE.dylib
             0x10179e000 -        0x1017adff3 +BEZ.dylib ??? (???) <D478437D-E3E9-DF6F-C269-E4786331B205> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BEZ.dylib
             0x1017b1000 -        0x1017bcff3 +BM.dylib ??? (???) <C3D22738-E352-F136-7EFB-FCA84A8DF3F2> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BM.dylib
             0x1017c3000 -        0x1017fefff +COR.dylib ??? (???) <82A66D1C-3411-28F7-55E4-44F5B23CD179> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/COR.dylib
             0x10181a000 -        0x10183aff7 +FILE.dylib ??? (???) <8D94218F-3D12-5DD1-F7ED-995E32F320D7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FILE.dylib
             0x101848000 -        0x101875fff +FLO.dylib ??? (???) <5ADDC857-45E8-C8CD-38BC-9B1745179E60> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FLO.dylib
             0x10187b000 -        0x10193efff +FLT.dylib ??? (???) <2902EB47-A004-31D1-DC5F-A0E2FF8FECE7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FLT.dylib
             0x1019a1000 -        0x1019a8ff3 +LIST.dylib ??? (???) <EBCE800F-92A6-6DE5-A588-25C7ABE134B1> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/LIST.dylib
             0x1019ac000 -        0x1019bffff +M.dylib ??? (???) <9C5728D1-8641-C50C-65A8-B32357F2C3E6> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/M.dylib
             0x1019c4000 -        0x1019cdff7 +MC.dylib ??? (???) <D14CEF04-2834-3D70-2EA8-80D122832D00> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MC.dylib
             0x1019d4000 -        0x101a34fff +MSK.dylib ??? (???) <E7026CA5-C04F-79F5-FCBC-4EDD42404683> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MSK.dylib
             0x101a48000 -        0x101a5fff7 +OM.dylib ??? (???) <24285638-08B3-5017-BB4C-C352BD01B3A6> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/OM.dylib
             0x101a67000 -        0x101a89ff7 +P.dylib ??? (???) <3ADABBEF-01A7-DC39-A53D-BA41C3FA402D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/P.dylib
             0x101a92000 -        0x101ddbfff +PF.dylib ??? (???) <F5764ECA-0A0D-468F-3320-CDF9E32862F2> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PF.dylib
             0x101e17000 -        0x102020fef +PIN.dylib ??? (???) <0C3F81B8-33B7-D233-3296-1BF9B878761D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PIN.dylib
             0x1020a1000 -        0x1020bbfff +PLUG.dylib ??? (???) <C4AAFD62-C761-417D-2E19-1282372830A3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PLUG.dylib
             0x1020c6000 -        0x1020d9fff +PR.dylib ??? (???) <80E85C07-A375-A91F-8062-88AA924AE278> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PR.dylib
             0x1020e0000 -        0x1020e6fff +PREF.dylib ??? (???) <86484BE5-76F4-4732-7131-8B22A4AB6B47> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PREF.dylib
             0x1020ea000 -        0x102102fff +RG.dylib ??? (???) <73804179-7CFE-B9EB-FE60-28386D472CC3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RG.dylib
             0x10210b000 -        0x10210dff7 +RI.dylib ??? (???) <A4E4E647-4A64-F605-00DD-40954ED0AA00> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RI.dylib
             0x102110000 -        0x102111fff +RND.dylib ??? (???) <CFA19218-EE1C-869B-CB20-A2AC8875CD94> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RND.dylib
             0x102118000 -        0x102177ff7 +SLU.dylib ??? (???) <AD49A5CA-0E54-5427-850E-7C1F6CE19A8D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SLU.dylib
             0x10219d000 -        0x1021b9ffd +SND.dylib ??? (???) <A030E529-FE40-6952-0E2F-116BB4896D6C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SND.dylib
             0x1021c1000 -        0x1021c4ff1 +STR.dylib ??? (???) <6AEB75A1-DC87-589A-9260-B8F8D0FF0186> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/STR.dylib
             0x1021c8000 -        0x1021cbfff +T.dylib ??? (???) <56B3122B-B555-5DE2-578C-28E07782987E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/T.dylib
             0x1021ce000 -        0x10220bff5 +TDB.dylib ??? (???) <F9C692F8-04DE-AF9B-1043-6ED200788D4A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/TDB.dylib
             0x10221f000 -        0x1028cafe5 +TXT.dylib ??? (???) <2406D646-4453-6A1E-E760-9259539A793D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/TXT.dylib
             0x102a69000 -        0x102aa5ff1 +U.dylib ??? (???) <F11F145C-1AF8-9E01-6BA9-CC2914BB8F64> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/U.dylib
             0x102ab9000 -        0x102abdfff +VAL.dylib ??? (???) <643F797E-4BA9-7A56-AD6D-30213837097D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VAL.dylib
             0x102ac0000 -        0x102b70fff +com.adobe.exo.framework exo version 5.0.0 (5.0.0.213330) <E4327151-F451-DD21-0696-CC980D027822> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/exo.framework/Versions/A/exo
             0x102c77000 -        0x102c9dff3 +PREM.dylib ??? (???) <FF94B54D-43D7-D3C8-D9CA-CF3C27E676E0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PREM.dylib
             0x102cb1000 -        0x102d0afff +FRP.dylib ??? (???) <590CA539-77C5-3671-821F-EE1A4B1DF5C5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FRP.dylib
             0x102d27000 -        0x102e85ff7 +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.213330) <2ED41E92-CA4E-F981-0A73-EECDD22BAE5D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
             0x102ff9000 -        0x103340ff7 +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.213330) <26699551-C5FE-77C5-D6B9-0C6034B41E3F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
             0x103701000 -        0x1037affff +com.adobe.dvaworkspace.framework dvaworkspace version 5.0.0 (5.0.0.213330) <705E0390-9563-FA39-9AD1-4328B2C9E1C0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
             0x10388b000 -        0x1038abfef +com.adobe.dvaunittesting.framework dvaunittesting version 5.0.0 (5.0.0.213330) <7ADEF3C2-30B8-547F-3E1D-BB80B4D6509A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
             0x1038d4000 -        0x1038e4ff8 +com.adobe.ahclientframework 1.5.0.30 (1.5.0.30) <5D6FFC4E-7B81-3E8C-F0D4-66A3FA94A837> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
             0x1038ef000 -        0x103967fef +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <4A355686-1451-B19A-0C55-DFE49FD2539E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
             0x10397d000 -        0x1039e2fff +aif_core ??? (???) <568D781D-2C64-2929-2D54-4D5ED733BA5A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
             0x103a24000 -        0x103c53fff +aif_ogl ??? (???) <8B39A818-2295-27C0-C7CC-23205863A910> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
             0x103e17000 -        0x103e2dfff +data_flow ??? (???) <773FBF60-436C-D83C-70C3-DF184CE733AE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
             0x103e60000 -        0x104355fef +image_compiler ??? (???) <B5099546-A56B-24C4-F073-37A7AE81AA24> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/image_compiler.framework/Versions/A/image_compiler
             0x104895000 -        0x10492bfff +image_flow ??? (???) <2752F430-8256-E728-D11B-5F0734CD3D0D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flow
             0x104a11000 -        0x104a50ff7 +com.adobe.dynamiclinkui.framework dynamiclinkui version 5.0.0 (5.0.0.213330) <BD01B92F-BA04-F1A9-6155-1B42C24C4526> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
             0x104aa6000 -        0x104c6ffff +com.adobe.dynamiclink.framework dynamiclink version 5.0.0 (5.0.0.213330) <B56BCABE-8A7D-DFC3-F188-63102A103BEA> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
             0x104d8d000 -        0x104defff5 +com.adobe.MediaCore.Frameworks.ASL.Foundation 1.0 (1.0) <8A37AB47-7613-9C3E-227F-7D9B7BC874E9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
             0x104ed6000 -        0x104eecfff +ASLMessaging ??? (???) <FF6E2081-5AFD-3A38-E302-E59229FD8C1D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
             0x104f0b000 -        0x104f1cffe +ASLUnitTesting ??? (???) <B08CF505-E518-72F2-6BD3-2F8220F4A9D8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
             0x104f34000 -        0x104f4eff3 +com.adobe.MediaCore.Frameworks.AudioFilterHost 1.0 (1.0) <77D98EE7-4093-301B-31C8-6304642AC4DE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
             0x104f76000 -        0x104faefff +com.adobe.MediaCore.Frameworks.AudioFilters ??? (1.0) <78471468-4C7F-0CF6-140D-798FCAF1AECB> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
             0x105019000 -        0x105091fe3 +com.adobe.MediaCore.Frameworks.AudioRenderer ??? (1.0) <D121C229-4251-5D3A-595F-650A02AE5B90> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
             0x10512c000 -        0x10516afe1 +com.adobe.MediaCore.Frameworks.AudioSupport 1.0 (1.0) <B082D5D2-92C2-4038-3583-6E624C2A0533> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
             0x1051b3000 -        0x105c24fef +com.adobe.MediaCore.Frameworks.Backend ??? (1.0) <0BB48068-8E97-BF23-C679-6AE5DFDCD49B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
             0x10694b000 -        0x106aefff3 +com.adobe.MediaCore.Frameworks.ImageRenderer ??? (1.0) <B4CCC972-CADD-7751-7F46-7F28674F4DBF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
             0x106c1f000 -        0x106da9ff7 +com.adobe.MediaCore.Frameworks.ImporterHost 1.0 (1.0) <F34576C9-5DF6-9085-4804-8C5A074A512E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
             0x106f6b000 -        0x106f9ffff +com.adobe.MediaFoundation ??? (1.0) <2237E626-39E2-4FC7-0886-7385E9A0D827> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
             0x106fe2000 -        0x106fe5fff +com.adobe.MediaCore.Frameworks.MediaUtils 1.0 (1.0) <DE5FE590-E42C-70DA-0872-6FB725861729> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
             0x106fea000 -        0x106febfff +com.adobe.MediaCore.Frameworks.Memory 1.0 (1.0) <E6A57F34-8922-5D13-B6BE-1D53C0675555> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
             0x106ff0000 -        0x10702bfff +com.adobe.MediaCore.Frameworks.MLFoundation 1.0 (1.0) <F9C61C12-0EA0-EA53-5AF0-81381E8C782B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
             0x10707b000 -        0x1070adfff +com.adobe.MediaCore.Frameworks.PluginSupport 1.0 (1.0) <D60E282B-70B2-2A0F-AFAE-EC4C84AE27CB> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
             0x1070ec000 -        0x1070edfff +PRM ??? (???) <BDF8EC3E-8EA0-FCB1-8A7B-38CEF4020BE1> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
             0x1070f1000 -        0x107129fff +com.adobe.MediaCore.Frameworks.SweetPeaSupport 1.0 (1.0) <CD2EBF6A-F10E-2B20-9F57-D6F49E5883B0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
             0x10717a000 -        0x1071c3fff +com.adobe.MediaCore.VideoFrame 1.0 (1.0) <271EA98F-DEB4-932F-3F78-1E76BFE5B8F1> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
             0x107211000 -        0x10732dfff +com.adobe.MediaCore.Frameworks.VideoRenderer 1.0 (1.0) <3DA8F0D4-6E35-7EE4-EA45-E31F3B4D34FB> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
             0x107497000 -        0x10753ffe1 +com.adobe.dvaeve.framework dvaeve version 5.0.0 (5.0.0.213330) <3320F862-69F9-91B9-77B3-58638E9A5F57> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
             0x10763c000 -        0x1076affff +com.adobe.MediaCore.Frameworks.PlayerHost 1.0 (1.0) <B285C74F-2478-5536-7936-CD061F43A182> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
             0x10774a000 -        0x10781cfff +com.adobe.MediaCore.Frameworks.VideoFilterHost 1.0 (1.0) <6A71B201-FF19-4B17-E188-48B7AE5F3A3E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
             0x1078df000 -        0x107949ff7 +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <6B2F73C2-10AB-08B3-4AB0-A31C83D1E5E0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
             0x10797c000 -        0x107a1aff2 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <5651FB7C-24ED-8CC8-2ADE-A5CB7CA493C3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
             0x107a3a000 -        0x107a55fff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <FEF83A1C-8D48-66B4-BED6-B91835D1AA68> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
             0x107a58000 -        0x107ab2fff +com.adobe.dvametadata.framework dvametadata version 5.0.0 (5.0.0.213330) <18F7D94A-F4DB-1721-FBDF-1ED970BCF942> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
             0x107b34000 -        0x107bb8fff +com.adobe.dvametadataUI.framework dvametadataUI version 5.0.0 (5.0.0.213330) <73A09435-12CC-3B38-8681-B72FED6E4D9D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
             0x107c4f000 -        0x107c93ff7 +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 5.0.0 (5.0.0.213330) <83DDA3DF-57A0-AEDF-2793-685ABA6E8CCE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
             0x107cb3000 -        0x107cccfff +com.adobe.dvamediatypes.framework dvamediatypes version 5.0.0 (5.0.0.213330) <5859F2A1-3BFC-8EAD-F008-AF0333FF44B8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
             0x107ceb000 -        0x107d61ff7 +com.adobe.dvatransport.framework dvatransport version 5.0.0 (5.0.0.213330) <DA8FFA3F-BD11-2EE7-A974-228F49E1652D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
             0x107de4000 -        0x107e20ff3 +com.adobe.dvamarshal.framework dvamarshal version 5.0.0 (5.0.0.213330) <625FCBA1-47B3-DAD5-C15B-78E572F6717A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
             0x107e8c000 -        0x107e9afff +com.adobe.MediaCore.Frameworks.ProjectSupport 1.0 (1.0) <57A965FC-3754-BFB3-A1D0-253D5B39E901> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
             0x107eae000 -        0x107ef1fff +DynamicLinkMedia ??? (???) <FF94B2FF-93A5-623E-04A6-125572A95FE3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
             0x107f5e000 -        0x107f5eff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <B146C134-CE18-EC95-12F8-E5C2BCB43A6B> /usr/lib/libmx.A.dylib
             0x107f61000 -        0x107f8cff6 +AdobeAXE8SharedExpat ??? (???) <F5C1010B-CAFF-5290-8B55-6FEB3A287225> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
             0x107f9e000 -        0x107fa4ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <1AB34F57-2E8D-42FB-A484-5CCB928CA456> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
             0x107fab000 -        0x107fc8fff +AdobeBIB ??? (???) <3FF7BFF2-52DF-046A-A081-2BDB1055A1B4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
             0x107fd2000 -        0x107fdaff3 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.213330) <50E5F61F-42D9-1F4D-EBF7-47BE6A864A73> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
             0x107fe9000 -        0x10803ffeb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <03B80698-2C3B-A232-F15F-8F08F8963A19> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
             0x108084000 -        0x108142ffb +filter_graph ??? (???) <3C2316AB-7ACF-A257-97EF-33E00FD5AC67> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/filter_graph.framework/Versions/A/filter_graph
             0x10826a000 -        0x1082c8ffd +AdobeXMP ??? (???) <29839F01-4A21-5B72-FF9A-E030D214F5E2> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
             0x1082d6000 -        0x108362fe3 +AdobeXMPFiles ??? (???) <C4531436-CA4F-8A06-0481-CD1648C20C48> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
             0x10839a000 -        0x10843afef +com.adobe.AdobeScCore ScCore 4.1.25 (4.1.25.10116) <2049AC79-9EFA-1D8B-C577-174B36569A29> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
             0x108480000 -        0x108524ffb +com.adobe.AdobeExtendScript ExtendScript 4.1.25 (4.1.25.10116) <B2464DBF-230E-3187-6004-F8A804ED24A3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
             0x108586000 -        0x108664fef +AdobeAXEDOMCore ??? (???) <8D4592B8-5DA1-D957-B1BA-FB20116514DD> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
             0x1086dc000 -        0x108a0dfe7 +AdobeCoolType ??? (???) <C93152AA-AC85-5157-0B28-AFE1D6CAA31F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
             0x108aa9000 -        0x108df3fe7 +AdobeAGM ??? (???) <E48474D7-E499-6F7A-9F2A-E9A82D075405> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
             0x108ec5000 -        0x108fdafff +AdobeACE ??? (???) <0A896D92-86A5-D870-9BE0-755ADD1B1A33> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
             0x108fff000 -        0x109020fff +AdobeBIBUtils ??? (???) <1468CBC0-B799-0808-91D1-78BAD0320F99> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
             0x10902d000 -        0x109100ffb +AdobeJP2K ??? (???) <8571D9BA-44F9-92A3-0444-5FFAC2994B88> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
             0x109120000 -        0x109161ff7 +AdobeARE ??? (???) <CE1A57E7-5175-C3A7-B644-94B4D149ED13> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
             0x10916b000 -        0x1097c3fef +AdobePDFL ??? (???) <45AA7483-10A6-2DAB-1FF8-62C9E615039E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
             0x109912000 -        0x109e23fff +AdobeMPS ??? (???) <10C4E979-45F3-A7C6-0438-262CE5F595B9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
             0x109ef9000 -        0x109f24fef +AdobeAXE16SharedExpat ??? (???) <F5E56D3B-AE0E-245C-E706-DFA630D6771C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedEx pat
             0x109f36000 -        0x10acf9fff +com.adobe.psl AdobePSL 12.0.0.7667 (12.0.0.7667) <F1C9409D-033E-58D0-B902-6422BC488AA5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
             0x10b069000 -        0x10b114feb +com.adobe.MediaCore.Frameworks.ExporterHost 1.0 (1.0) <6F779FBA-40D3-16A5-D7EC-609CF6450518> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
             0x10b228000 -        0x10b248feb +SegMatServices.dylib ??? (???) <FBBD1251-FEF4-80E8-57EC-919B332187D5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SegMatServices.dylib
             0x10b255000 -        0x10b255ff7 +SAM.dylib ??? (???) <4502C9CF-D856-7BC4-E22A-9BEB4119B2AD> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SAM.dylib
             0x10b258000 -        0x10b33efe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <26FC56A6-EFD6-22FA-E1F1-4E1BA61C85BB> /usr/lib/libcrypto.0.9.7.dylib
             0x10b396000 -        0x10b66efe6 +libxerces-c-3.0.dylib ??? (???) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/libxerces-c-3.0.dylib
             0x10b7e8000 -        0x10b7feff6 +com.adobe.AMEAppFoundation.framework ??? (1.0) <14C553BC-BF4B-C2F1-51E3-0E318D7E727A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
             0x10b81f000 -        0x10b842ff1 +com.adobe.PostEncodeHost.framework ??? (1.0) <45EEDD75-E549-F676-2A8E-B3EEA45FC1D8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostEncodeHost
             0x10b870000 -        0x10b92cff7 +AMEWrapper ??? (???) <21631AD0-2C5F-B73D-22AA-D6712710D6E3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
             0x10b9eb000 -        0x10baf2fff +com.adobe.EncoderHost.framework ??? (1.0) <C7488EFE-B96F-8FD9-5CE5-4EF91C6E0E38> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
             0x10bbf7000 -        0x10bdc4fff +com.adobe.SettingsUI.framework ??? (1.0) <089295DC-226C-B898-9FB7-BA037FE2F56A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
             0x10c021000 -        0x10c07fff7 +com.adobe.MediaCore.Frameworks.Utilities.QT32Client 1.0 (1.0) <93CFE7E1-52A1-95A0-1126-B8CB1304D81F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
             0x10c0ed000 -        0x10c118fff  com.apple.carbonframeworktemplate 1.0 (1.0) <71D2D8B4-2E61-C6D7-B134-5116431765BE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefoundation
             0x10c152000 -        0x10c17bfff +ameproperties ??? (???) <64AA3464-459A-77A6-C400-3D5B957161D4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ameproperties.framework/Versions/A/ameproperties
             0x10c1be000 -        0x10c1c2ff2 +com.adobe.AppServices.framework ??? (1.0) <AA9FAEBA-4D36-1F43-7AE7-F19593D57964> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServices
             0x10c583000 -        0x10c585fef  com.apple.textencoding.unicode 2.3 (2.3) <B254327D-2C4A-3296-5812-6F74C7FFECD9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
             0x10c674000 -        0x10c6e4ff6 +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <52FF1F9B-9991-ECE2-C7E3-09DA1B368CBE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
             0x10fd5a000 -        0x10fd62fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <3D59CB21-F5C7-4232-AB00-DFEB04206024> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
             0x12ff5c000 -        0x12ff7bfe3 +com.adobe.AfterEffects.Jpg ??? (???) <5609A32F-4566-A8BB-057D-27C06DA09D16> /Applications/Adobe After Effects CS5/Plug-ins/Format/JPEG.plugin/Contents/MacOS/Jpg
             0x12fff5000 -        0x12fff9ff7  libFontRegistryUI.dylib ??? (???) <763B8E8F-8602-2096-7CC8-CEE1F4248028> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
             0x130e4d000 -        0x130e67fff +com.adobe.pip ??? (5.0.0.2021) <47380937-5088-41F7-50FA-ADAC9B15C783> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
             0x130eb6000 -        0x130ebbff7 +com.adobe.AfterEffects.Drop_Shadow ??? (???) <121448D7-2469-8ECD-53EF-38ADADC3E518> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Drop_Shadow.plugin/Contents/MacOS/Drop_Shadow
             0x130f6a000 -        0x130f6bff7 +com.adobe.AfterEffects.Paint ??? (???) <EED2E53D-7D8A-80A0-6C09-2EF2B94076EF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Paint.plugin/Contents/MacOS/Paint
             0x130f6e000 -        0x130f7dfff +com.adobe.AfterEffects.FreePin ??? (???) <34D09883-0648-CEB6-4100-DDCDB8B8B8D4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Puppet.plugin/Contents/MacOS/FreePin
             0x131243000 -        0x131246fef  libLatinSuppConverter.dylib 49.0.0 (compatibility 1.0.0) <227677D0-9CF3-E007-E4C0-8DCECDA1AE9B> /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
             0x1324cc000 -        0x1324d0fff +com.adobe.AfterEffects.EasyEase ??? (???) <BABE30E9-6001-5F0D-8083-6540AAD2DA61> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/EasyEase.plugin/Contents/MacOS/EasyEase
             0x1324d3000 -        0x1324d7ff7 +com.adobe.AfterEffects.ExpScale ??? (???) <5A75FEEA-77D5-EC6F-0EC5-DDA8BD78F058> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/ExpScale.plugin/Contents/MacOS/ExpScale
             0x13272f000 -        0x132755fff  GLRendererFloat ??? (???) <0310BFE5-B3DE-BCD8-EFD7-42C574EBF776> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
             0x1327e7000 -        0x1327e8fff  ATSHI.dylib ??? (???) <F6C4F446-7AC4-7A17-9302-C38A016322B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
             0x133b00000 -        0x133c91fff  GLEngine ??? (???) <BB46BB42-B574-1E54-101B-A68E43576B26> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
             0x133cec000 -        0x133cf0fff  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <F99C2FBC-103D-DB2D-8D53-CFB8CEFA90F8> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
             0x133cf5000 -        0x133cfbfff  com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <933CA4C6-F428-0E2E-DCBE-FA0284914092> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
             0x133ec0000 -        0x133ee7ff1 +com.mainconcept.mc_enc_dv 8.5 (8.5.0.14572) <46AB8404-6892-F7BF-150E-D8249ECFD0B8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
             0x134332000 -        0x13435cff1 +com.mainconcept.mc_dec_dv 8.5 (8.5.0.14572) <CFF0820D-B6C1-0DB8-43DE-35169748FD94> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/mc_dec_dv.framework/mc_dec_dv
             0x1366ff000 -        0x136701ff7 +com.adobe.AfterEffects.Sharpen ??? (???) <754C34A6-14DC-C8AB-10CF-15EFC371079A> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Sharpen.plugin/Contents/MacOS/Sharpen
             0x136711000 -        0x136742fff +com.adobe.MediaCore.ImporterMPEG 1.0 (1.0) <8D4AC3BC-56F7-F8DE-848B-9315997A80EF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ImporterMPEG.bundle/Contents/MacOS/ImporterMPEG
             0x136798000 -        0x13679dfff +com.adobe.MediaCore.ExporterCoreAudio 1.0 (1.0) <C1A74B80-D569-C330-D735-448B4FAC782F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCor eAudio
             0x1367a4000 -        0x1367b3fe7 +com.adobe.MediaCore.Frameworks.AudioConverter 1.0 (1.0) <CCA6D5A2-0C71-5323-7B1C-E072DCE41C2B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioConverter.framework/Versions/A/AudioConverter
             0x13778f000 -        0x1377b5ff3 +com.adobe.MediaCore.ExporterQuickTimeHost 1.0 (1.0) <DCE19C8F-D9C7-0272-0EB2-FC8C2DF63485> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ExporterQuickTimeHost.bundle/Contents/MacOS/Exporte rQuickTimeHost
             0x1377ec000 -        0x1377f8fff +com.adobe.AfterEffects.MThread ??? (???) <E50EF468-274F-D3A0-15A3-B9CB3B9AAF7D> /Applications/Adobe After Effects CS5/Plug-ins/Extensions/Mthread.plugin/Contents/MacOS/MThread
             0x137b0c000 -        0x137cf6fef  com.apple.audio.codecs.Components 2.0.2 (2.0.2) <CC28CC1B-ACD4-151F-BC5B-E842AC7F075F> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
             0x137eeb000 -        0x137ef1ff7 +com.adobe.AfterEffects.Sequence ??? (???) <160CE07F-F2DF-CB1D-A013-D556E4D3AB41> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Sequence.plugin/Contents/MacOS/Sequence
             0x137ef6000 -        0x137efafff +com.adobe.AfterEffects.TRKeys ??? (???) <FF272930-752F-FB11-E057-09DFDCCAB3A8> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/TRKeys.plugin/Contents/MacOS/TRKeys
             0x138000000 -        0x138042fff +com.adobe.MediaCore.ImporterQuickTime 1.0 (1.0) <7A2D8B05-C5A9-E892-CB39-8E69E60390D5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ImporterQuickTime.bundle/Contents/MacOS/ImporterQui ckTime
             0x138081000 -        0x138099ff3 +com.adobe.MediaCore.Frameworks.QTParser 1.0 (1.0) <514A4B12-E7B0-7C96-DBF2-C07C3026B87B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
             0x1380ae000 -        0x13817eff7 +com.adobe.MediaCore.IPPMPEGDecoder 1.0 (1.0) <AE3B4FE4-2BD1-FFE3-3657-390214479EF8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/IPPMPEGDecoder.framework/IPPMPEGDecoder
             0x1381c3000 -        0x13838afef +com.adobe.MediaCore.ImporterRED 1.01 (1.0) <3381CDA1-F8D1-D2D1-E93E-C1B0C82364CE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ImporterRED.bundle/Contents/MacOS/ImporterRED
             0x138a98000 -        0x138b19fff +com.adobe.AfterEffects.AEGPDriver ??? (???) <C7F9ADE5-79D2-A88E-953D-E1AE3B1F0BDC> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/AEGPDriver.plugin/Contents/MacOS/AEGPDriver
             0x138b51000 -        0x138b67fe7 +com.adobe.AfterEffects.PS3Export ??? (???) <1444127E-DF55-B376-ACE5-DDA0C2F3CF54> /Applications/Adobe After Effects CS5/Plug-ins/Format/PS Layer Export.plugin/Contents/MacOS/PS3Export
             0x138b73000 -        0x138b95ff3 +com.adobe.AfterEffects.PS3Import ??? (???) <79DCB388-3CC8-D018-DF14-A3C0F3E7C7D9> /Applications/Adobe After Effects CS5/Plug-ins/Format/PS Layer Import.plugin/Contents/MacOS/PS3Import
             0x138ba6000 -        0x138c1cfff +com.adobe.AfterEffects.Escher ??? (???) <6DE5ADDB-608B-DC6B-F45D-1D7A81B03B26> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Advanced3D.plugin/Contents/MacOS/Escher
             0x138c29000 -        0x138ca7ff3 +com.adobe.AfterEffects.AEDynamicLinkServer ??? (???) <E47693B4-C03B-5DE6-F4D6-C905E1BB7008> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/AEDynamicLinkServer.plugin/Contents/MacOS/AEDynamicLinkServer
             0x138de1000 -        0x138dfefff +com.adobe.AfterEffects.AudioPal ??? (???) <B8A77B49-F592-27C7-000A-9DBA0B1435EA> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Audio Palette.plugin/Contents/MacOS/AudioPal
             0x138e10000 -        0x138e3fffb +com.adobe.AfterEffects.BrushPal ??? (???) <92CBF24B-AF40-3506-61F4-019C623477EA> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Brush Palette.plugin/Contents/MacOS/BrushPal
             0x138e57000 -        0x138e97ff7 +com.adobe.AfterEffects.CharPal ??? (???) <394E75A6-99E0-2866-3E70-8CBD4D4DB82B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Character Palette.plugin/Contents/MacOS/CharPal
             0x138eb8000 -        0x138edafff +com.adobe.AfterEffects.InfoPal ??? (???) <99F70291-C93F-D95A-30FF-4E7871A7ADFD> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Info Palette.plugin/Contents/MacOS/InfoPal
             0x138eee000 -        0x138ef1ff7 +com.adobe.AfterEffects.Durer ??? (???) <41DC9F1C-A47C-DBD2-2982-ABEEA82D1568> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Standard3D.plugin/Contents/MacOS/Durer
             0x138ef4000 -        0x138ef8ff7 +com.adobe.AfterEffects.RPFImport ??? (???) <E30E57A5-1DFE-915C-EB88-B33CE9F6E05E> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/RPFImport.plugin/Contents/MacOS/RPFImport
             0x139000000 -        0x13902cffb +com.adobe.AfterEffects.PaintPal ??? (???) <F7F81EDD-5E6B-B38C-56B9-D71768D31A5B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Paint Palette.plugin/Contents/MacOS/PaintPal
             0x139044000 -        0x139065ff7 +com.adobe.AfterEffects.ParaPal ??? (???) <38D78DA1-664C-EEA6-703C-2A110897B406> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Paragraph Palette.plugin/Contents/MacOS/ParaPal
             0x139079000 -        0x139210fff +com.adobe.AfterEffects.SnapCut ??? (???) <D3827117-B036-C6B8-8A22-C207C78044DC> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Roto Brush.plugin/Contents/MacOS/SnapCut
             0x13923f000 -        0x139261fff +com.adobe.AfterEffects.TimePal ??? (???) <9D721EAD-2BA9-9BDC-6E1B-42BBBFDF7D77> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Time Palette.plugin/Contents/MacOS/TimePal
             0x139277000 -        0x1392bafff +com.adobe.AfterEffects.ToolPal ??? (???) <CA44FE3D-6552-5F3D-A1AE-B71EC5A264EA> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Tool Palette.plugin/Contents/MacOS/ToolPal
             0x1392db000 -        0x1392fbffb +com.adobe.AfterEffects.TrackerPal ??? (???) <C7DB4C26-39A7-5F9B-2E47-6520A00BF339> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Tracker Palette.plugin/Contents/MacOS/TrackerPal
             0x13930d000 -        0x13a0dfff7 +com.ImagineerSystems.mochashapeconverter4ae 1 (1.0.0) <3C1F5D08-D515-9E24-35ED-CC76FCCA9675> /Applications/Adobe After Effects CS5/Plug-ins/Effects/Imagineer/mocha shape converter for AE.plugin/Contents/MacOS/mochashapeconverter4ae
             0x13a2ac000 -        0x13a312fff +com.adobe.AfterEffects.AE_OpenGL ??? (???) <76576A65-32D6-7092-59E3-F6A20F48A617> /Applications/Adobe After Effects CS5/Plug-ins/Extensions/AE_OpenGL.plugin/Contents/MacOS/AE_OpenGL
             0x13a526000 -        0x13a532ff7 +com.adobe.AfterEffects.LocalizePresets ??? (???) <38093080-3398-168D-C9AA-11F046EA3ED2> /Applications/Adobe After Effects CS5/Plug-ins/Extensions/LocalizePresets.plugin/Contents/MacOS/LocalizePresets
             0x13a53b000 -        0x13a5bdfe3 +com.adobe.AfterEffects.FlashExporter ??? (???) <4DCFBC46-FCA2-D963-4979-E0FB994F5108> /Applications/Adobe After Effects CS5/Plug-ins/Format/FlashExporter.plugin/Contents/MacOS/FlashExporter
             0x13a5ea000 -        0x13a73bfeb +com.adobe.AfterEffects.OpenEXR ??? (???) <E570DDA8-8CD5-5C4B-A8EA-38B63E89231A> /Applications/Adobe After Effects CS5/Plug-ins/Format/OpenEXR.plugin/Contents/MacOS/OpenEXR
             0x13aba4000 -        0x13abd4fff +com.adobe.AfterEffects.PNGIO ??? (???) <DC8B178A-5AF7-6219-CDC2-4F757FC0DAAF> /Applications/Adobe After Effects CS5/Plug-ins/Format/PNGIO.plugin/Contents/MacOS/PNGIO
             0x13abe0000 -        0x13ac95fff +com.adobe.AfterEffects.PremiereProImport ??? (???) <F1237486-5CCC-04C4-98F8-78449851498D> /Applications/Adobe After Effects CS5/Plug-ins/Format/PremiereProImport/PremiereProImport.plugin/Contents/MacOS/PremierePro Import
             0x13acc2000 -        0x13ad30fff +com.adobe.MediaCore.Frameworks.UI 1.0 (1.0) <E878778B-7ACB-28FA-2535-D2852B4CE1D2> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
             0x13ada1000 -        0x13adfdfff +com.adobe.AfterEffects.TIFFIO ??? (???) <9CF4A767-872F-0D4D-8A6C-AEEE4019B2B9> /Applications/Adobe After Effects CS5/Plug-ins/Format/TIFF.plugin/Contents/MacOS/TIFFIO
             0x13ae0d000 -        0x13aed1feb +com.adobe.AfterEffects.Vic ??? (???) <6FFC5C50-4976-9665-3D39-EEE7438A7CB1> /Applications/Adobe After Effects CS5/Plug-ins/Format/Vector Output.plugin/Contents/MacOS/Vic
             0x13af28000 -        0x13af41ff3 +com.adobe.AfterEffects.Align ??? (???) <249E6544-947A-121D-46A7-1061A4B3A088> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Align.plugin/Contents/MacOS/Align
             0x13af50000 -        0x13af5bfff +com.adobe.AfterEffects.Analyzer ??? (???) <12EF3B3B-A7E5-9413-6DBB-16DC078B0A58> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Analyzer.plugin/Contents/MacOS/Analyzer
             0x13af60000 -        0x13af70fff +com.adobe.AfterEffects.MayaImport ??? (???) <6E4E0B7B-3551-90E3-CEB3-FAC2125876E9> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/MayaImport.plugin/Contents/MacOS/MayaImport
             0x13af73000 -        0x13af8aff7 +com.adobe.AfterEffects.MetaPal ??? (???) <4CE0F462-1B67-3A32-C24F-A7921D090017> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/MetaPal.plugin/Contents/MacOS/MetaPal
             0x13af9b000 -        0x13afc5fff +com.adobe.AfterEffects.Moka ??? (???) <8E21D291-BF16-644F-4526-D3256CDBDF21> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Moka.plugin/Contents/MacOS/Moka
             0x13afd6000 -        0x13afeaffb +com.adobe.AfterEffects.MotionSketch ??? (???) <F4C3B429-E11E-C7EF-E9F1-6FAA97F274D3> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/MotionSketch.plugin/Contents/MacOS/MotionSketch
             0x13aff8000 -        0x13b44cfff +com.adobe.AfterEffects.Scripting ??? (???) <5C90290F-9EBA-D6B1-D6CB-08E4757E5AA9> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Scripting.plugin/Contents/MacOS/Scripting
             0x13b5d8000 -        0x13b5dcff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <0C380604-C686-C2E4-0535-C1FAB230187E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
             0x13b5e0000 -        0x13b600ffb +com.adobe.ape adbeapecore version 3.1.70.10055 (3.1.70.10055) <66373ADB-0865-ECDB-D3D0-B3373FC43919> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
             0x13cda4000 -        0x13cde6ff3 +libMXF_SDK_XML_r.4.2.319.dylib 4.2.0 (compatibility 4.2.0) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_XML_r.4.2.319.dylib
             0x13ceaa000 -        0x13cebeffb +com.adobe.AfterEffects.Smoother ??? (???) <A59E60FC-9404-BC72-E08B-FD37A9FF887C> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Smoother.plugin/Contents/MacOS/Smoother
             0x13cecc000 -        0x13cee2ff3 +com.adobe.AfterEffects.Wiggler ??? (???) <FD0E7F65-6500-B0D9-CE8D-B3E43ACC4E73> /Applications/Adobe After Effects CS5/Plug-ins/Keyframe/Wiggler.plugin/Contents/MacOS/Wiggler
             0x13cf39000 -        0x13cf76feb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <CD8BD7C7-0F66-29B6-C158-A6EF8DF69996> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
             0x13cf91000 -        0x13cfbafff +libMOG_Framework_r.2.0.8.dylib 2.0.8 (compatibility 2.0.8) <F686FD64-AF59-C0EA-F3E4-FA05E4144F73> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMOG_Framework_r.2.0.8.dylib
             0x13d2e7000 -        0x13d3e4fff +com.adobe.AfterEffects.RefineMatte ??? (???) <E75264FC-E965-9BE7-F268-DA8B88A0A2FA> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/RefineMatte.plugin/Contents/MacOS/RefineMatte
             0x13d40a000 -        0x13d474fe7 +libMXF_SDK_Modules_r.1.1.34.dylib 1.1.0 (compatibility 1.1.0) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_Modules_r.1.1.34.dylib
             0x13d800000 -        0x13d861fef +com.mainconcept.mc_mfimport 8.5 (8.5.0.14572) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/mc_mfimport.framework/Versions/8.5/mc_mfimport
             0x13db92000 -        0x13ddb3fef +libMXF_SDK_r.4.2.319.dylib 4.2.0 (compatibility 4.2.0) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_r.4.2.319.dylib
             0x13df4a000 -        0x13e216ff6 +libxerces-c-3.0.dylib ??? (???) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libxerces-c-3.0.dylib
             0x13e3ac000 -        0x13e781fef +libxqilla.5.0.0.dylib 6.0.0 (compatibility 6.0.0) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libxqilla.5.0.0.dylib
             0x200000000 -        0x200517fef  com.apple.GeForce7xxxGLDriver 1.6.24 (6.2.4) <B0D43194-6CD9-DD0A-441D-C43007CEC648> /System/Library/Extensions/GeForce7xxxGLDriver.bundle/Contents/MacOS/GeForce7xxxGLDriver
          0x7fff5fc00000 -     0x7fff5fc3bdef  dyld 132.1 (???) <B536F2F1-9DF1-3B6C-1C2C-9075EA219A06> /usr/lib/dyld
          0x7fff80003000 -     0x7fff80046ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <7E30B5F6-99FD-C716-8670-5DD4B4BAED72> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
          0x7fff80054000 -     0x7fff800e4fff  com.apple.SearchKit 1.3.0 (1.3.0) <4175DC31-1506-228A-08FD-C704AC9DF642> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
          0x7fff80108000 -     0x7fff80afefff  com.apple.AppKit 6.6.7 (1038.35) <9F4DF818-9DB9-98DA-490C-EF29EA757A97> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
          0x7fff80aff000 -     0x7fff80b5ffe7  com.apple.framework.IOKit 2.0 (???) <D107CB8A-5182-3AC4-35D0-07068A695C05> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
          0x7fff80b60000 -     0x7fff80b62fff  libRadiance.dylib ??? (???) <76438F90-DD4B-9941-9367-F2DFDF927876> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
          0x7fff80d7d000 -     0x7fff80da0fff  com.apple.opencl 12.3 (12.3) <D30A45FC-4520-45AF-3CA5-092313DB5D54> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
          0x7fff80def000 -     0x7fff811c9fff  com.apple.RawCamera.bundle 3.4.1 (546) <F7865FD2-4869-AB19-10AA-EFF1B3BC4178> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
          0x7fff81215000 -     0x7fff81293fff  com.apple.CoreText 3.5.0 (???) <4D5C7932-293B-17FF-7309-B580BB1953EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
          0x7fff81297000 -     0x7fff81298ff7  com.apple.audio.units.AudioUnit 1.6.5 (1.6.5) <14F14B5E-9287-BC36-0C3F-6592E6696CD4> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
          0x7fff812b1000 -     0x7fff812f2fef  com.apple.QD 3.36 (???) <5DC41E81-32C9-65B2-5528-B33E934D5BB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
          0x7fff812f3000 -     0x7fff813befe7  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <3C223A94-EF14-28C5-844B-C25DFC87FB42> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
          0x7fff813bf000 -     0x7fff81474fe7  com.apple.ink.framework 1.3.3 (107) <FFC46EE0-3544-A459-2AB9-94778A75E3D4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
          0x7fff816b7000 -     0x7fff81875fff  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <781E7B63-2AD0-E9BA-927C-4521DB616D02> /usr/lib/libicucore.A.dylib
          0x7fff81876000 -     0x7fff8199cfff  com.apple.audio.toolbox.AudioToolbox 1.6.5 (1.6.5) <B51023BB-A5C9-3C65-268B-6B86B901BB2C> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
          0x7fff8199d000 -     0x7fff819e4ff7  com.apple.coreui 2 (114) <D7645B59-0431-6283-7322-957D944DAB21> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
          0x7fff819e5000 -     0x7fff81a51ff7  com.apple.CorePDF 1.3 (1.3) <6770FFB0-DEA0-61E0-3520-4B95CCF5D1CF> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
          0x7fff81a52000 -     0x7fff81a53fff  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <5062DACE-FCE7-8E41-F5F6-58821778629C> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
          0x7fff81a54000 -     0x7fff81cbefef  com.apple.QuartzComposer 4.2 ({156.28}) <7586E7BD-D3BD-0EAC-5AC9-0BFA3679017C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
          0x7fff81cbf000 -     0x7fff81d04fff  com.apple.CoreMediaIOServices 133.0 (1158) <53F7A2A6-78CA-6C34-0BB6-471388019799> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
          0x7fff81d05000 -     0x7fff81d26fff  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <6993F348-428F-C97E-7A84-7BD2EDC46A62> /usr/lib/libresolv.9.dylib
          0x7fff81d76000 -     0x7fff81e02fef  SecurityFoundation ??? (???) <6860DE26-0D42-D1E8-CD7C-5B42D78C1E1D> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
          0x7fff81e03000 -     0x7fff81e03ff7  com.apple.CoreServices 44 (44) <DC7400FB-851E-7B8A-5BF6-6F50094302FB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
          0x7fff81e4e000 -     0x7fff81e7dff7  com.apple.quartzfilters 1.6.0 (1.6.0) <9CECB4FC-1CCF-B8A2-B935-5888B21CBEEF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
          0x7fff81e7e000 -     0x7fff81eb8fff  libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <C7153747-50E3-32DA-426F-CC4C505D1D6C> /usr/lib/libssl.0.9.8.dylib
          0x7fff81f43000 -     0x7fff81fb4ff7  com.apple.AppleVAFramework 4.10.12 (4.10.12) <1B68BE43-4C54-87F5-0723-0B0A14CD21E8> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
          0x7fff82127000 -     0x7fff82176ff7  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <14FD0978-4BE0-336B-A19E-F388694583EB> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
          0x7fff8219c000 -     0x7fff82539fe7  com.apple.QuartzCore 1.6.3 (227.34) <215222AF-B30A-7CE5-C46C-1A766C1D1D2E> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
          0x7fff8253a000 -     0x7fff82540fff  libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <4EE16374-A094-D542-5BC5-7E846D0CE56E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
          0x7fff82541000 -     0x7fff82541ff7  com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
          0x7fff82542000 -     0x7fff82603fe7  libFontParser.dylib ??? (???) <8B12D37E-3A95-5A73-509C-3AA991E0C546> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
          0x7fff82604000 -     0x7fff8261afe7  com.apple.MultitouchSupport.framework 207.10 (207.10) <1828C264-A54A-7FDD-FE1B-49DDE3F50779> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
          0x7fff8261b000 -     0x7fff826d4fff  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150> /usr/lib/libsqlite3.dylib
          0x7fff82731000 -     0x7fff82747fff  com.apple.ImageCapture 6.0.1 (6.0.1) <09ABF2E9-D110-71A9-4A6F-8A61B683E936> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
          0x7fff82748000 -     0x7fff82755fe7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <397B9057-5CDF-3B19-4E61-9DFD49369375> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
          0x7fff82756000 -     0x7fff82917fff  libSystem.B.dylib 125.2.1 (compatibility 1.0.0) <71E6D4C9-F945-6EC2-998C-D61AD590DAB6> /usr/lib/libSystem.B.dylib
          0x7fff82979000 -     0x7fff82a4bfe7  com.apple.CFNetwork 454.11.5 (454.11.5) <B3E2BE12-D7AA-5940-632A-1E5E7BF8E6E3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
          0x7fff82a4c000 -     0x7fff82a4cff7  com.apple.vecLib 3.6 (vecLib 3.6) <08D3D45D-908B-B86A-00BA-0F978D2702A7> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
          0x7fff82a4d000 -     0x7fff82afcfff  edu.mit.Kerberos 6.5.10 (6.5.10) <F3F76EDF-5660-78F0-FE6E-33B6174F55A4> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
          0x7fff82afd000 -     0x7fff82b39fe7  libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <1E041185-131C-C237-C250-38BE933A269A> /usr/lib/libcurl.4.dylib
          0x7fff82b3a000 -     0x7fff82b3dfff  com.apple.help 1.3.1 (41) <54B79BA2-B71B-268E-8752-5C8EE00E49E4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
          0x7fff82bd0000 -     0x7fff82c21fef  com.apple.HIServices 1.8.1 (???) <BE479ABF-3D27-A5C7-800E-3FFC1731767A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
          0x7fff82c22000 -     0x7fff82c5fff7  libFontRegistry.dylib ??? (???) <8C69F685-3507-1B8F-51AD-6183D5E88979> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
          0x7fff82c60000 -     0x7fff82d15fe7  com.apple.ColorSync 4.6.3 (4.6.3) <AA93AD96-6974-9104-BF55-AF7A813C8A1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
          0x7fff82d16000 -     0x7fff82d16ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <DA9BFF01-40DF-EBD5-ABB7-787DAF2D77CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
          0x7fff82d17000 -     0x7fff82e21ff7  com.apple.MeshKitIO 1.1 (49.2) <F296E151-80AE-7764-B969-C2050DF26BFE> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
          0x7fff82ee7000 -     0x7fff83056fe7  com.apple.QTKit 7.6.6 (1756) <250AB242-816D-9F5D-94FB-18BF2AE9AAE7> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
          0x7fff8339b000 -     0x7fff83435fff  com.apple.ApplicationServices.ATS 4.4 (???) <395849EE-244A-7323-6CBA-E71E3B722984> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
          0x7fff8346b000 -     0x7fff834b3ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <170DE04F-89AB-E295-0880-D69CAFBD7979> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
          0x7fff834b4000 -     0x7fff834e5fff  libGLImage.dylib ??? (???) <57DA0064-4581-62B8-37A8-A07ADEF46EE2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
          0x7fff834e6000 -     0x7fff834faff7  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <621B7415-A0B9-07A7-F313-36BEEDD7B132> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
          0x7fff83502000 -     0x7fff83502ff7  com.apple.quartzframework 1.5 (1.5) <B182B579-BCCE-81BF-8DA2-9E0B7BDF8516> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
          0x7fff83503000 -     0x7fff83515fe7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
          0x7fff83516000 -     0x7fff83559fef  libtidy.A.dylib ??? (???) <2F4273D3-418B-668C-F488-7E659D3A8C23> /usr/lib/libtidy.A.dylib
          0x7fff835a5000 -     0x7fff835c5ff7  com.apple.DirectoryService.Framework 3.6 (621.9) <FF6567B5-56BD-F3EC-E59D-1EC583C3CF73> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
          0x7fff83809000 -     0x7fff8381afff  com.apple.DSObjCWrappers.Framework 10.6 (134) <3C08225D-517E-2822-6152-F6EB13A4ADF9> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
          0x7fff83820000 -     0x7fff8382ffff  com.apple.opengl 1.6.11 (1.6.11) <43D5BE71-E1F6-6974-210C-17C68919AE08> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
          0x7fff83830000 -     0x7fff83836ff7  IOSurface ??? (???) <04EDCEDE-E36F-15F8-DC67-E61E149D2C9A> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
          0x7fff83837000 -     0x7fff838bcff7  com.apple.print.framework.PrintCore 6.3 (312.7) <CDFE82DD-D811-A091-179F-6E76069B432D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
          0x7fff838bd000 -     0x7fff8393afef  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
          0x7fff8393b000 -     0x7fff839a3fff  com.apple.MeshKitRuntime 1.1 (49.2) <1F4C9AB5-9D3F-F91D-DB91-B78610562ECC> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
          0x7fff839a4000 -     0x7fff839a9ff7  com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
          0x7fff839aa000 -     0x7fff839bfff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <DC999B32-BF41-94C8-0583-27D9AB463E8B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
          0x7fff839c0000 -     0x7fff839dbff7  com.apple.openscripting 1.3.1 (???) <FD46A0FE-AC79-3EF7-AB4F-396D376DDE71> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
          0x7fff839f2000 -     0x7fff83e35fef  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <0CC61C98-FF51-67B3-F3D8-C5E430C201A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
          0x7fff83e6c000 -     0x7fff83fe3fe7  com.apple.CoreFoundation 6.6.4 (550.42) <770C572A-CF70-168F-F43C-242B9114FCB5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
          0x7fff83fe4000 -     0x7fff840c9fef  com.apple.DesktopServices 1.5.9 (1.5.9) <27890B2C-0CD2-7C27-9D0C-D5952C5E8438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
          0x7fff840ca000 -     0x7fff840d3ff7  com.apple.DisplayServicesFW 2.3.0 (283) <3D05929C-AB17-B8A4-DC81-87C27C59E664> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
          0x7fff840d4000 -     0x7fff840fafe7  libJPEG.dylib ??? (???) <6690F15D-E970-2678-430E-590A94F5C8E9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
          0x7fff840fb000 -     0x7fff84134fef  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <97F968EB-80ED-36FB-7819-D438B489E46E> /usr/lib/libcups.2.dylib
          0x7fff84151000 -     0x7fff84339ff7  com.apple.JavaScriptCore 6533.18 (6533.18.1) <C6F7B4E1-1DF6-414A-5A17-B334A814B2A0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
          0x7fff8433a000 -     0x7fff84340ff7  com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
          0x7fff843f8000 -     0x7fff845affef  com.apple.ImageIO.framework 3.0.4 (3.0.4) <2CB9997A-A28D-80BC-5921-E7D50BBCACA7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
          0x7fff845b0000 -     0x7fff845beff7  libkxld.dylib ??? (???) <4016E9E6-0645-5384-A697-2775B5228113> /usr/lib/system/libkxld.dylib
          0x7fff845bf000 -     0x7fff845d5fef  libbsm.0.dylib ??? (???) <42D3023A-A1F7-4121-6417-FCC6B51B3E90> /usr/lib/libbsm.0.dylib
          0x7fff845d6000 -     0x7fff84611fff  com.apple.AE 496.4 (496.4) <CBEDB6A1-FD85-F842-4EB8-CC289FAE0F24> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
          0x7fff84612000 -     0x7fff84616ff7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
          0x7fff84781000 -     0x7fff847b1fef  com.apple.shortcut 1.1 (1.1) <A99C9D8E-290B-B1E4-FEA5-CC5F2FB9C18D> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
          0x7fff847e2000 -     0x7fff8481ffff  com.apple.LDAPFramework 2.0 (120.1) <16383FF5-0537-6298-73C9-473AEC9C149C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
          0x7fff8482c000 -     0x7fff848e9ff7  com.apple.CoreServices.OSServices 357 (357) <718F0719-DC9F-E392-7C64-9D7DFE3D02E2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
          0x7fff848ea000 -     0x7fff84979fff  com.apple.PDFKit 2.5.1 (2.5.1) <7B8A187A-F0BB-44E7-FBD4-9E1C5F9D5E85> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
          0x7fff8497a000 -     0x7fff84a54ff7  com.apple.vImage 4.0 (4.0) <354F34BF-B221-A3C9-2CA7-9BE5E14AD5AD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
          0x7fff84a7f000 -     0x7fff84a9cff7  libPng.dylib ??? (???) <14043CBC-329F-4009-299E-DEE411E16134> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
          0x7fff84a9d000 -     0x7fff84aa8ff7  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <F0DDF27E-DB55-07CE-E548-C62095BE8167> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
          0x7fff84aa9000 -     0x7fff84aadff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <63F77AC8-84CB-0C2F-8D2B-190EE5CCDB45> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
          0x7fff84ac7000 -     0x7fff84b46fe7  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <1DD64A62-0DE4-223F-F781-B272FECF80F0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
          0x7fff84b47000 -     0x7fff84b4cfff  libGFXShared.dylib ??? (???) <A94DE483-A586-A172-104F-1CFC5F0BFD57> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
          0x7fff84b4d000 -     0x7fff84b72ff7  com.apple.CoreVideo 1.6.2 (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
          0x7fff84bc5000 -     0x7fff84bc8ff7  com.apple.securityhi 4.0 (36638) <38935851-09E4-DDAB-DB1D-30ADC39F7ED0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
          0x7fff84bc9000 -     0x7fff84c1efef  com.apple.framework.familycontrols 2.0.1 (2010) <239940AC-2427-44C6-9E29-998D0ABECDF3> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
          0x7fff84c1f000 -     0x7fff84f53fff  com.apple.CoreServices.CarbonCore 861.23 (861.23) <08F360FA-1771-4F0B-F356-BEF68BB9D421> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
          0x7fff84f54000 -     0x7fff84f9eff7  com.apple.Metadata 10.6.3 (507.12) <9231045A-E2E3-B0C2-C81A-92C9EA98A4DF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
          0x7fff84f9f000 -     0x7fff84faefff  com.apple.NetFS 3.2.1 (3.2.1) <FF21DB1E-F425-1005-FB70-BC19CAF4006E> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
          0x7fff85023000 -     0x7fff85026ff7  libCoreVMClient.dylib ??? (???) <B1F41E5B-8B59-DB81-1654-C1F9B11E885F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
          0x7fff85027000 -     0x7fff85032ff7  com.apple.HelpData 2.0.4 (34) <B44D2E2A-BC1E-CD63-F8A1-C9465491693A> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
          0x7fff85d5d000 -     0x7fff85d88ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <87A0B228-B24A-C426-C3FB-B40D7258DD49> /usr/lib/libxslt.1.dylib
          0x7fff85d89000 -     0x7fff85dd5fff  libauto.dylib ??? (???) <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib
          0x7fff85dd6000 -     0x7fff85e1dfff  com.apple.QuickLookFramework 2.3 (327.6) <11DFB135-24A6-C0BC-5B97-ECE352A4B488> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
          0x7fff85e1e000 -     0x7fff85e1eff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <2BB7D669-4B40-6A52-ADBD-DA4DB3BC0B1B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
          0x7fff85e9c000 -     0x7fff8611fff7  com.apple.Foundation 6.6.4 (751.42) <9A99D378-E97A-8C0F-3857-D0FAA30FCDD5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
          0x7fff86120000 -     0x7fff86121fff  liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
          0x7fff86122000 -     0x7fff86626fe7  com.apple.VideoToolbox 0.484.20 (484.20) <8B6B82D2-350B-E9D3-5433-51453CDA65B4> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
          0x7fff867a5000 -     0x7fff867a6ff7  com.apple.TrustEvaluationAgent 1.1 (1) <51867586-1C71-AE37-EAAD-535A58DD3550> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
          0x7fff867a7000 -     0x7fff868c0fef  libGLProgrammability.dylib ??? (???) <13E8114C-6E07-A66E-35E6-C185E54840AE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
          0x7fff868c1000 -     0x7fff86961fff  com.apple.LaunchServices 362.1 (362.1) <2740103A-6C71-D99F-8C6F-FA264546AD8F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
          0x7fff86962000 -     0x7fff86a18fff  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <F206BE6D-8777-AE6C-B367-7BEA76C14241> /usr/lib/libobjc.A.dylib
          0x7fff86a24000 -     0x7fff86d22fe7  com.apple.HIToolbox 1.6.3 (???) <CF0C8524-FA82-3908-ACD0-A9176C704AED> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
          0x7fff86d23000 -     0x7fff86d37fff  libGL.dylib ??? (???) <1EB1BD0F-C17F-55DF-B8B4-8E9CF99359D4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
          0x7fff86d38000 -     0x7fff86d60fff  com.apple.DictionaryServices 1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
          0x7fff86d61000 -     0x7fff86d68fff  com.apple.OpenDirectory 10.6 (10.6) <4200CFB0-DBA1-62B8-7C7C-91446D89551F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
          0x7fff86e62000 -     0x7fff86e9bff7  com.apple.MeshKit 1.1 (49.2) <3795F201-4A5F-3D40-57E0-87AD6B714239> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
          0x7fff86eaa000 -     0x7fff86ebbff7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <FB5EE53A-0534-0FFA-B2ED-486609433717> /usr/lib/libz.1.dylib
          0x7fff86ebc000 -     0x7fff86efdfff  com.apple.SystemConfiguration 1.10.5 (1.10.2) <FB39F09C-57BB-D8CC-348D-93E00C602F7D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
          0x7fff86f73000 -     0x7fff8709bff7  com.apple.MediaToolbox 0.484.20 (484.20) <628A7245-7ADE-AD47-3368-CF8EDCA6CC1C> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
          0x7fff87133000 -     0x7fff87177fe7  com.apple.ImageCaptureCore 1.0.3 (1.0.3) <913FFA89-0AC8-0A8D-CC2A-364CB0F303BA> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
          0x7fff8719b000 -     0x7fff871e4fef  libGLU.dylib ??? (???) <EB4255DD-A9E5-FAD0-52A4-CCB4E792B86F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
          0x7fff871e5000 -     0x7fff8726bff3  com.apple.iLifeMediaBrowser 2.1.5 (368) <BC6090D5-47FD-882D-1123-BA40CB821481> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowse r
          0x7fff87274000 -     0x7fff872a6fff  libTrueTypeScaler.dylib ??? (???) <B9ECE1BD-A716-9F65-6466-4444D641F584> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
          0x7fff872a7000 -     0x7fff872a7ff7  com.apple.Carbon 150 (152) <19B37B7B-1594-AD0A-7F14-FA2F85AD7241> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
          0x7fff872a8000 -     0x7fff872a8ff7  com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
          0x7fff872a9000 -     0x7fff873c0fef  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <EE067D7E-15B3-F043-6FBD-10BA31FE76C7> /usr/lib/libxml2.2.dylib
          0x7fff873d0000 -     0x7fff8750efff  com.apple.CoreData 102.1 (251) <32233D4D-00B7-CE14-C881-6BF19FD05A03> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
          0x7fff8750f000 -     0x7fff87630fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <48AEAFE1-21F4-B3C8-4199-35AD5E8D0613> /usr/lib/libcrypto.0.9.8.dylib
          0x7fff87631000 -     0x7fff878b7fef  com.apple.security 6.1.1 (37594) <17CF7858-52D9-9665-3AE8-23F07CC8BEA1> /System/Library/Frameworks/Security.framework/Versions/A/Security
          0x7fff878b8000 -     0x7fff8793afff  com.apple.QuickLookUIFramework 2.3 (327.6) <9093682A-0E2D-7D27-5F22-C96FD00AE970> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
          0x7fff87b1f000 -     0x7fff87b38fff  com.apple.CFOpenDirectory 10.6 (10.6) <CCF79716-7CC6-2520-C6EB-A4F56AD0A207> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
          0x7fff87b39000 -     0x7fff87b3efff  libGIF.dylib ??? (???) <9A2723D8-61F9-6D65-D254-4F9273CDA54A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
          0x7fff87b3f000 -     0x7fff87ba1fe7  com.apple.datadetectorscore 2.0 (80.7) <F9D2332D-0890-2ED2-1AC8-F85CB89D8BD4> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
          0x7fff87ba2000 -     0x7fff87dddfef  com.apple.imageKit 2.0.3 (1.0) <5D18C246-303A-6580-9DC9-79BE79467C95> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
          0x7fff87f31000 -     0x7fff87f80fef  libTIFF.dylib ??? (???) <AE9DC484-1382-F7AD-FE25-C28082FCB5D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
          0x7fff87fb1000 -     0x7fff887bbfe7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <FC941ECB-71D0-FAE3-DCBF-C5A619E594B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
          0x7fff8887a000 -     0x7fff888bbff7  com.apple.CoreMedia 0.484.20 (484.20) <42F3B74A-F886-33A0-40EE-8399B12BD32A> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
          0x7fff888bc000 -     0x7fff888befff  com.apple.print.framework.Print 6.1 (237.1) <CA8564FB-B366-7413-B12E-9892DA3C6157> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
          0x7fff888bf000 -     0x7fff88929fe7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <75A8D840-4ACE-6560-0889-2AFB6BE08E59> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
          0x7fff8892a000 -     0x7fff8902706f  com.apple.CoreGraphics 1.545.0 (???) <356D59D6-1DD1-8BFF-F9B3-1CE51D2F1EC7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
          0x7fffffe00000 -     0x7fffffe01fff  libSystem.B.dylib ??? (???) <71E6D4C9-F945-6EC2-998C-D61AD590DAB6> /usr/lib/libSystem.B.dylib
      Model: MacPro2,1, BootROM MP21.007F.B06, 8 processors, Quad-Core Intel Xeon, 3 GHz, 14 GB, SMC 1.15f3
      Graphics: NVIDIA GeForce 7300 GT, NVIDIA GeForce 7300 GT, PCIe, 256 MB
        • 1. Re: Undo group mismatch, will attempt to fix
          Is anyone getting this error?  I'm getting this over and over.
          And specifically what is it that you do? Sorry, but without telling us what you actually do, this is rather pointless. I have personally experienced the error when working with text layers and a few plug-ins using custom controls, but there could be other things at work in your case...
          Mylenium
