2 Replies Latest reply on Nov 18, 2010 2:23 AM by Magesh R
    If you have any possible with in the itemrender have one is label control and onther one is data gri
    Magesh R
      Hi Friends,
                      If you have any possible with in the itemrender have one is label control and onther one is data grid control.
      In my application i was using list control.The list control have item renderer. In my case if i click list control of label name, the corresponding releated data of data grid need to display and list control label also.
      <mx:List width="750" id="Lst_userlist" verticalScrollPolicy="off"  horizontalScrollPolicy="off" rowCount="20"
      labelField="sec_user_first_name+sec_user_last_name" labelFunction="BindUserName" buttonMode="true" itemClick="Click_UserList(event)" >
      <mx:itemRenderer>
        <fx:Component>
         <mx:VBox  horizontalScrollPolicy="off" verticalScrollPolicy="off" >
           <s:Label id="lbl_userhead" name="{data.sec_user_first_name+data.sec_user_last_name}" buttonMode="true" color="#000000"/>
                <mx:DataGrid height="100%" id="membershipGrid" alternatingItemColors="[#DCDCDC,#F8F8FF]"  paddingLeft="5"  horizontalScrollPolicy="off" color="black"
            horizontalGridLines="false" verticalScrollPolicy="auto"  verticalGridLines="false"   rowCount="{membershipArrColl.length}" rowHeight="25"
                  borderSkin="{null}" showHeaders="true" borderVisible="false" dataProvider="{membershipArrColl}" width="750"  visible="false" includeInLayout="false">
      <mx:columns>
        <mx:DataGridColumn width="180" headerText="Name" minWidth="150" sortable="true"  wordWrap="true" >
         <mx:itemRenderer>
          <fx:Component>
           <mx:HBox horizontalScrollPolicy="off"   >
            <fx:Script>
             <![CDATA[
             override public function set data(value:Object):void{
             super.data = value;
             if(data.home_sec_organization_id==data.sec_organization_id)
              fileimg.load("/ist_shared/ist_images/ist_icons/Modern/gif/16/hot/user_favorites_16_hot.gi f");
             else
              fileimg.load("/ist_shared/ist_images/ist_icons/Modern/gif/16/dis/user_remove_16_dis.gif") ;
             lbl_Gridcloumn_name.text=data.sec_user_first_name+" "+data.sec_user_last_name;
            </fx:Script>
            <mx:Image id="fileimg"    buttonMode="true"  toolTip="This is the User's Home Organization"/>
            <s:Label  id="lbl_Gridcloumn_name"  width="200" buttonMode="true" textDecoration="underline" toolTip="User Menu [{data.sec_user_name}]" click="outerDocument.Click_Name(event);"    />
           </mx:HBox>
          </fx:Component>
         </mx:itemRenderer>
        </mx:DataGridColumn>
        <mx:DataGridColumn width="120" minWidth="110" headerText="UserName" sortable="true"  dataField="sec_user_name"  />
        <mx:DataGridColumn width="100" minWidth="80"  headerText="OrgName"  dataField="sec_org_name">
      </mx:columns>
      </mx:DataGrid>
         </mx:VBox>
        </fx:Component>
      </mx:itemRenderer>
      </mx:List>
      Please Any One Help to me...
      Magesh R.
        • 1. Re: If you have any possible with in the itemrender have one is label control and onther one is data gri
          drkstr_1 Level 4
          If I understand correctly, you want to display a different set of data in a DataGrid for each item selected in a List?
          I would just use binding:
          <mx:List id="list" />
          <mx:DataGrid id="dg" dataProvider="{list.selectedItem.data}" />
          This assumes that list is populated with data items in a format similar to this:
            label : "List Label 1",
            data : [
               { col1 : "col1", col2: "col2"},
          • 2. Re: If you have any possible with in the itemrender have one is label control and onther one is data gri
            Magesh R Level 1
            Hi Friend,
            The list values are display Even if i click perticular data list value ,the corresponind data grid are display in blow line data list...
            can u see below sample.
            Blue colotr items are List values
            Green Color items are Data Grid values... If click Blue color name then only correspond data grid items are display...
            Canvass360 01
            Canvass360 01
            canvass360-01
            HR Demo
            System Wide Auth Admin UT
            Canvass360 01
            canvass360-01
            HR Demo
            System Wide DocStor Admin UT
            Andrew Addison
            Andrew Addison
            AAddison
            HR Demo
            Andrew Addison
            AAddison
            HR Demo
            System Admin
            System Admin
            Admin
            HR Demo
            MyOrg Administrator UT
            System Admin
            Admin
            HR Demo
            Regional Manager UT
            System Admin
            Admin
            HR Demo
            Site Manager UT
            System Admin
            Admin
            HR Demo
            System Admin
            Admin
            HR Demo
            Ben Affleck
            Ben Affleck
            Ben
            HR Demo
            Site Manager UT
            Jennifer Aniston
            Jennifer Aniston
            JenniferA
            HR Demo
            Site Manager UT
            Christian Bale
            Christian Bale
            Christian Bale
            HR Demo
            Site Manager UT
            Brad Burgess
            Brad Burgess
            BBurgess
            HR Demo
            Sean Connery
            Sean Connery
            SConnery
            HR Demo
            Site Manager UT
            Harrison Ford
            Harrison Ford
            HFord
            HR Demo
            Regional Manager UT
            Megan Fox
            Megan Fox
            MFox
            HR Demo
            Regional Manager UT
            Chuck Gamble
            Chuck Gamble
            CGamble
            HR Demo
            Chuck Gamble
            CGamble
            HR Demo
            Regional Manager UT
            Chuck Gamble
            CGamble
            HR Demo
            Site Manager UT
            Chuck Gamble
            CGamble
            HR Demo
            Chuck Gamble
            CGamble
            HR Demo
            Chuck Gamble
            CGamble
            HR Demo
            OnBoarding UT
            Magesh R.
            Amiee Mann
            AMann
            HR Demo
            Regional Manager UT
            Jennifer Smith
            JenniferSmith
            HR Demo
            Site Manager UT
            Reese Witherspoon
            Reese
            HR Demo
            Site Manager UT
