8 Replies Latest reply on Nov 18, 2010 6:01 PM by YuHsin4221123
    Retrieve return value from method
    YuHsin4221123 Level 1
      I am doing a if else statement my flex component. this is how it looks like
      <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                      xmlns:mx="library://ns.adobe.com/flex/mx"
                      autoDrawBackground="true" width="169" height="24">
          <s:layout>
              <s:HorizontalLayout/>
          </s:layout>
          <fx:Script>
              <![CDATA[
                  [Bindable]
                  private function starRating():String{
                      if (data.rating == "1"){
                          return "images/1star.gif";
                      else if (data.rating == "2"){
                          return "images/2star.gif";
                      else if (data.rating == "3") {
                          return "images/3star.gif";
                      else if (data.rating == "4") {
                          return "images/4star.gif";
                      else {
                          return "images/5star.gif";
          </fx:Script>
          <s:Label text="{data.expertdetail}" x="1" y="7" height="23"/>
          <mx:Image x="119" y="-1" width="25" height="24" source="starRating()"/>
      </s:ItemRenderer>
      i wanted my image component to be dynamic. to get the image based on the data.rating value. I believe the problem lies on my source="" code.
      Could I know what is the exact way to fix this problem? Thanks
        • 1. Re: Retrieve return value from method
          drkstr_1 Level 4
          You cannot bind to a function, but you can bind to data and pass it through a function to return a result.
          source="{starRating(_data.raiting)}"
          [Bindable]
          private var _data:Object;
          private function starRating(raiting:String):String
              if (rating == "1")
          • 2. Re: Retrieve return value from method
            thanks for the reply. but I would like to know how can i retrieve the return value to the img component. i want my img component to display the return img.
            • 3. Re: Retrieve return value from method
              Arun Ganesh Level 3
              starRating() - method is not bindable here
              try,
                  <mx:Image x="119" y="-1" width="25" height="24" source="{starRating()}"/>
              • 4. Re: Retrieve return value from method
                thanks. I am able to get the retrieve data. but there an issue with my code
                I am only able to get last loop "images/5star.gif"
                I suspect that the problem lies on the data.rating, for this component it is actually a item renderer from list.
                • 5. Re: Retrieve return value from method
                  SashaKeith Adobe Employee
                  You can override the data setter. Something like this may work for you:
                      <s:layout>
                      </s:layout>
                      <fx:Script>
                          <![CDATA[
                              override public function set data(value:Object):void
                                  super.data = value;
                                  if (value == null)
                                      return;
                                  lblExpertDetail.text = value.expertdetail ;
                                  if (value.rating == "1"){
                                      imgStarRating.source="images/1star.gif";
                                  else if (value.rating == "2"){
                                      imgStarRating.source="images/2star.gif";
                                  else if (value.rating == "3") {
                                      imgStarRating.source="images/3star.gif";
                                  else if (value.rating == "4") {
                                      imgStarRating.source="images/4star.gif";
                                  else {
                                      imgStarRating.source="images/5star.gif";
                      </fx:Script>
                      <s:Label id="lblExpertDetail" x="1" y="7" height="23"/>
                      <mx:Image id="imgStarRating" x="119" y="-1" width="25" height="24"/>
                  </s:ItemRenderer>
                  • 6. Re: Retrieve return value from method
                    all my image are setted to the 5star.gif no matter what value i set. I believe the issue still lies on value.rating
                    but lblExpertDetail.text = value.expertdetail; isn't encountering any issue from this code.
                    • 7. Re: Retrieve return value from method
                      Can you debug, set breakpoints before the if..else.. block and examine the rating value? Is it a number or int instead of a String by any chance? That should give you some clues maybe.
                      • 8. Re: Retrieve return value from method
                        yeah. i managed to fix the problem using the debugger, something is wrong with my getter and setter. thanks alot!
