0 Replies Latest reply on Nov 18, 2010 1:16 AM by Ratchakorn Aphiworaphakin
    I cannot publish file in Adobe Flash Professional CS5
    Ratchakorn Aphiworaphakin Level 1
      Dear All,
                I need help right away.
           I install Adobe Creative Suite 5 Production Premium in iMac (2010) and this software is for Volume License for 21 users
      When I work in Adobe Flash Professional CS5 and I create file via
      file >> New >> Animation (from Category) >> Templates (from top icon) >> choose scripted Snow >> press ok
      and I continued on choose File (from top menu bar) >> Publish
      The Problems are 2 forms
      1.choose publish and then nothing happen.
      2. choose publish and the program quit automatically and the pop-up showed Flash Quit Unexpectedly and the detail as below
      Process:         Adobe Flash CS5 [484]
      Path:            /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/Adobe Flash CS5
      Identifier:      com.adobe.flash
      Version:         11.0.0.485 (11.0.0)
      Code Type:       X86 (Native)
      Parent Process:  launchd [316]
      Date/Time:       2010-11-17 12:55:09.928 +0700
      OS Version:      Mac OS X 10.6.4 (10F569)
      Report Version:  6
      Interval Since Last Report:          291 sec
      Crashes Since Last Report:           1
      Per-App Interval Since Last Report:  34 sec
      Per-App Crashes Since Last Report:   1
      Anonymous UUID:                      31C9EBC7-558C-4060-A869-CBD51818F40B
      Exception Type:  EXC_BAD_ACCESS (SIGBUS)
      Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000048
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Application Specific Information:
      Java information:
      Exception type: Bus Error (0xa) at pc=0000000003104bb7
      Java VM: Java HotSpot(TM) Client VM (17.1-b03-307 mixed mode macosx-x86)
      Current thread (000000004e801400):  JavaThread "main" [_thread_in_native, id=-1607658240, stack(00000000bf800000,00000000c0000000)]
      Stack: [00000000bf800000,00000000c0000000]
      Java Threads: ( => current thread )
        000000004f0bec00 JavaThread "Thread-2" [_thread_blocked, id=-1319813120, stack(00000000b1454000,00000000b1554000)]
        000000004e8d9c00 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1255608320, stack(00000000b518f000,00000000b528f000)]
        000000004e8d9400 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1256665088, stack(00000000b508d000,00000000b518d000)]
        000000004f0f9000 JavaThread "FelixPackageAdmin" daemon [_thread_blocked, id=-1307996160, stack(00000000b1f99000,00000000b2099000)]
        000000004f0f8800 JavaThread "FelixStartLevel" daemon [_thread_blocked, id=-1309052928, stack(00000000b1e97000,00000000b1f97000)]
        000000004e8c1c00 JavaThread "FelixDispatchQueue" [_thread_blocked, id=-1310109696, stack(00000000b1d95000,00000000b1e95000)]
        000000004f0b7800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1312223232, stack(00000000b1b91000,00000000b1c91000)]
        000000004f0b6800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=-1313280000, stack(00000000b1a8f000,00000000b1b8f000)]
        000000004f0b5800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1314336768, stack(00000000b198d000,00000000b1a8d000)]
        000000004f0b4800 JavaThread "Surrogate Locker Thread (CMS)" daemon [_thread_blocked, id=-1315393536, stack(00000000b188b000,00000000b198b000)]
        000000004e805000 JavaThread "Finalizer" daemon [_thread_blocked, id=-1316450304, stack(00000000b1789000,00000000b1889000)]
        000000004e804000 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1317507072, stack(00000000b1687000,00000000b1787000)]
      =>000000004e801400 JavaThread "main" [_thread_in_native, id=-1607658240, stack(00000000bf800000,00000000c0000000)]
      Other Threads:
        000000004f0a8000 VMThread [stack: 00000000b0aff000,00000000b0bff000] [id=-1329598464]
        000000004f0b8c00 WatcherThread [stack: 00000000b1c93000,00000000b1d93000] [id=-1311166464]
      VM state:not at safepoint (normal execution)
      VM Mutex/Monitor currently owned by a thread: None
      Heap
      par new generation   total 14784K, used 11325K [0000000051810000, 0000000052810000, 0000000052810000)
        eden space 13184K,  73% used [0000000051810000, 000000005218f720, 00000000524f0000)
        from space 1600K, 100% used [0000000052680000, 0000000052810000, 0000000052810000)
        to   space 1600K,   0% used [00000000524f0000, 00000000524f0000, 0000000052680000)
      concurrent mark-sweep generation total 49152K, used 5048K [0000000052810000, 0000000055810000, 0000000059810000)
      concurrent-mark-sweep perm gen total 12288K, used 9979K [0000000059810000, 000000005a410000, 000000005d810000)
      Virtual Machine Arguments:
      JVM Args: -Djava.awt.headless=true -Xmx128m
      Java Command: <unknown>
      Launcher Type: generic
      Physical Memory: Page Size = 4k, Total = 3840M, Free = 1677M
      Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
      0   libCoreTypes.dylib            0x03104bb7 CString::operator+=(CString const&) + 13
      1   com.adobe.flash               0x007887d1 CURI::~CURI() + 13775
      2   com.adobe.flash               0x00788bb0 CURI::~CURI() + 14766
      3   com.adobe.flash               0x00789065 CURI::~CURI() + 15971
      4   com.adobe.flash               0x007891c0 CURI::~CURI() + 16318
      5   com.adobe.flash               0x007895f4 CURI::~CURI() + 17394
      6   com.adobe.flash               0x00738035 CBitmapComboBox::GetRuntimeClass() const + 57015
      7   com.adobe.flash               0x0074497d AuthCompilerPlug::AuthCompilerPlug() + 27025
      8   com.adobe.flash               0x0046a4a6 CTypedPtrList<CObList, CViewStatusObj*>::CTypedPtrList(int) + 28116
      9   com.adobe.flash               0x0049c81b AudioFrameRecorder::GetData(char**, int*) + 30001
      10  com.adobe.flash               0x00126cc6 std::vector<CPicObj*, std::allocator<CPicObj*> >::push_back(CPicObj* const&) + 87656
      11  com.adobe.flash               0x00127f9d std::vector<CPicObj*, std::allocator<CPicObj*> >::push_back(CPicObj* const&) + 92479
      12  com.adobe.flash               0x001281c0 std::vector<CPicObj*, std::allocator<CPicObj*> >::push_back(CPicObj* const&) + 93026
      13  com.adobe.flash               0x0012824e std::vector<CPicObj*, std::allocator<CPicObj*> >::push_back(CPicObj* const&) + 93168
      14  com.adobe.flash               0x00d3619b CMiniFrameWnd::~CMiniFrameWnd() + 993
      15  com.adobe.flash               0x00d67f73 non-virtual thunk to CScrollViewImpl::ListenToMessage(long, void*) + 6749
      16  com.adobe.flash               0x00d130d3 non-virtual thunk to CButtonOwnerDrawImpl::~CButtonOwnerDrawImpl() + 9541
      17  com.adobe.flash               0x00d7e390 non-virtual thunk to CStdioFile::~CStdioFile() + 20822
      18  com.adobe.flash               0x00d7d63f non-virtual thunk to CStdioFile::~CStdioFile() + 17413
      19  com.adobe.flash               0x00d7a0e7 non-virtual thunk to CStdioFile::~CStdioFile() + 3757
      20  com.adobe.flash               0x00d79fb2 non-virtual thunk to CStdioFile::~CStdioFile() + 3448
      21  com.adobe.flash               0x00f1b319 CList<MMUI::DocumentFrame*, MMUI::DocumentFrame*>::~CList() + 4453
      22  com.adobe.flash               0x00d7d63f non-virtual thunk to CStdioFile::~CStdioFile() + 17413
      23  com.adobe.flash               0x00102f9f non-virtual thunk to CFlashDocTemplate::ActivateAccelerators(TAcceleratorVector) + 3787
      24  com.adobe.flash               0x00d7a0e7 non-virtual thunk to CStdioFile::~CStdioFile() + 3757
      25  com.adobe.flash               0x00d79fb2 non-virtual thunk to CStdioFile::~CStdioFile() + 3448
      26  com.adobe.flash               0x00d67765 non-virtual thunk to CScrollViewImpl::ListenToMessage(long, void*) + 4687
      27  com.adobe.flash               0x00e0879a non-virtual thunk to LCarbonApp::MakeSelfSpecifier(AEDesc&, AEDesc&) const + 698
      28  com.apple.HIToolbox           0x96426f2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
      29  com.apple.HIToolbox           0x964261f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
      30  com.apple.HIToolbox           0x964489bb SendEventToEventTarget + 52
      31  com.apple.HIToolbox           0x96474fa7 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
      32  com.apple.HIToolbox           0x96499d1c SendMenuCommandWithContextAndModifiers + 66
      33  com.apple.HIToolbox           0x96499cd1 SendMenuItemSelectedEvent + 121
      34  com.apple.HIToolbox           0x96499bda FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 152
      35  com.apple.HIToolbox           0x964692e4 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 454
      36  com.apple.HIToolbox           0x9661b911 MenuSelect + 190
      37  com.apple.HIToolbox           0x965d498c HIMenuBar::HandleMouseEvent(OpaqueEventRef*) + 92
      38  com.apple.HIToolbox           0x9642752b HIObject::EventHook(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 173
      39  com.apple.HIToolbox           0x96426f2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
      40  com.apple.HIToolbox           0x964261f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
      41  com.apple.HIToolbox           0x964489bb SendEventToEventTarget + 52
      42  com.apple.HIToolbox           0x9645a57b ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1417
      43  com.apple.HIToolbox           0x96427380 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
      44  com.apple.HIToolbox           0x964261f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
      45  com.apple.HIToolbox           0x964489bb SendEventToEventTarget + 52
      46  com.apple.HIToolbox           0x965d1cc3 ToolboxEventDispatcher + 86
      47  com.apple.HIToolbox           0x965d1dfb RunApplicationEventLoop + 243
      48  com.adobe.flash               0x00d6f8ba non-virtual thunk to CFileDialogImpl::~CFileDialogImpl() + 4302
      49  com.adobe.flash               0x00d460df CTimerImpl::~CTimerImpl() + 297
      50  com.adobe.flash               0x00d4618b CTimerImpl::~CTimerImpl() + 469
      51  com.adobe.flash               0x00004036 0x1000 + 12342
      Thread 1:  Dispatch queue: com.apple.libdispatch-manager
      0   libSystem.B.dylib             0x92b91942 kevent + 10
      1   libSystem.B.dylib             0x92b9205c _dispatch_mgr_invoke + 215
      2   libSystem.B.dylib             0x92b91519 _dispatch_queue_invoke + 163
      3   libSystem.B.dylib             0x92b912be _dispatch_worker_thread2 + 240
      4   libSystem.B.dylib             0x92b90d41 _pthread_wqthread + 390
      5   libSystem.B.dylib             0x92b90b86 start_wqthread + 30
      Thread 2:
      0   libSystem.B.dylib             0x92b6b142 semaphore_wait_signal_trap + 10
      1   libSystem.B.dylib             0x92b98cbc _pthread_cond_wait + 1089
      2   libSystem.B.dylib             0x92be1203 pthread_cond_wait + 48
      3   com.adobe.amt.services        0x0af01126 AMTConditionLock::LockWhenCondition(int) + 46
      4   com.adobe.amt.services        0x0aef9db0 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 116
      5   com.adobe.amt.services        0x0af0118c AMTThread::Worker(void*) + 24
      6   libSystem.B.dylib             0x92b9881d _pthread_start + 345
      7   libSystem.B.dylib             0x92b986a2 thread_start + 34
      Thread 3:
      0   libSystem.B.dylib             0x92b99066 __semwait_signal + 10
      1   libSystem.B.dylib             0x92b98d22 _pthread_cond_wait + 1191
      2   libSystem.B.dylib             0x92b9a9b8 pthread_cond_wait$UNIX2003 + 73
      3   ...ple.CoreServices.CarbonCore 0x9693ea3a TSWaitOnCondition + 126
      4   ...ple.CoreServices.CarbonCore 0x9692a38d TSWaitOnConditionTimedRelative + 202
      5   ...ple.CoreServices.CarbonCore 0x96925d67 MPWaitOnQueue + 250
      6   AdobeACE                      0x0533e6f1 0x5304000 + 239345
      7   AdobeACE                      0x0533e0ed 0x5304000 + 237805
      8   ...ple.CoreServices.CarbonCore 0x96909dee PrivateMPEntryPoint + 68
      9   libSystem.B.dylib             0x92b9881d _pthread_start + 345
      10  libSystem.B.dylib             0x92b986a2 thread_start + 34
      Thread 4:
      0   libSystem.B.dylib             0x92ba838a recvfrom$UNIX2003 + 10
      1   libSystem.B.dylib             0x92bc8147 recv$UNIX2003 + 54
      2   ServiceManager-Launcher.dylib 0x228576cf Invoke + 54887
      3   ServiceManager-Launcher.dylib 0x2285676e Invoke + 50950
      4   ServiceManager-Launcher.dylib 0x2285561f Invoke + 46519
      5   ServiceManager-Launcher.dylib 0x22855671 Invoke + 46601
      6   ServiceManager-Launcher.dylib 0x228556fb Invoke + 46739
      7   ServiceManager-Launcher.dylib 0x2284fafe Invoke + 23190
      8   ServiceManager-Launcher.dylib 0x2284fce7 Invoke + 23679
      9   ServiceManager-Launcher.dylib 0x228508c7 Invoke + 26719
      10  ServiceManager-Launcher.dylib 0x228509c5 Invoke + 26973
      11  ServiceManager-Launcher.dylib 0x22853db0 Invoke + 40264
      12  ServiceManager-Launcher.dylib 0x22854059 Invoke + 40945
      13  ServiceManager-Launcher.dylib 0x22854687 Invoke + 42527
      14  ServiceManager-Launcher.dylib 0x22854884 Invoke + 43036
      15  ServiceManager-Launcher.dylib 0x22846826 Login + 1654
      16  ServiceManager-Launcher.dylib 0x22847c71 Login + 6849
      17  ServiceManager-Launcher.dylib 0x22854df3 Invoke + 44427
      18  ServiceManager-Launcher.dylib 0x22857341 Invoke + 53977
      19  libSystem.B.dylib             0x92b9881d _pthread_start + 345
      20  libSystem.B.dylib             0x92b986a2 thread_start + 34
      Thread 5:
      0   libSystem.B.dylib             0x92b909d2 __workq_kernreturn + 10
      1   libSystem.B.dylib             0x92b90f68 _pthread_wqthread + 941
      2   libSystem.B.dylib             0x92b90b86 start_wqthread + 30
      Thread 6:  Java: Exception Handler Thread
      0   libSystem.B.dylib             0x92b6b0fa mach_msg_trap + 10
      1   libSystem.B.dylib             0x92b6b867 mach_msg + 68
      2   libSystem.B.dylib             0x92bd6e18 mach_msg_server + 520
      3   libjvm.dylib                  0x27c0fa03 JNI_CreateJavaVM_Impl + 56827
      4   libjvm.dylib                  0x27c0f9b2 JNI_CreateJavaVM_Impl + 56746
      5   libjvm.dylib                  0x27c0e9a9 JNI_CreateJavaVM_Impl + 52641
      Thread 7:  Java: Gang worker#0 (Parallel GC Threads)
      2   libjvm.dylib                  0x27e88d6f JVM_RaiseSignal + 359375
      3   libjvm.dylib                  0x27c0ee84 JNI_CreateJavaVM_Impl + 53884
      4   libjvm.dylib                  0x27e7f2e7 JVM_RaiseSignal + 319815
      5   libjvm.dylib                  0x27e7f3ac JVM_RaiseSignal + 320012
      6   libjvm.dylib                  0x27c0eb28 JNI_CreateJavaVM_Impl + 53024
      7   libjvm.dylib                  0x27c21b1f jio_vsnprintf + 299
      8   libjvm.dylib                  0x27c21a66 jio_vsnprintf + 114
      9   libjvm.dylib                  0x27c0e9a9 JNI_CreateJavaVM_Impl + 52641
      10  libSystem.B.dylib             0x92b9881d _pthread_start + 345
      11  libSystem.B.dylib             0x92b986a2 thread_start + 34
      Thread 8:  Java: Gang worker#1 (Parallel GC Threads)
      Thread 9:  Java: Concurrent Mark-Sweep GC Thread
      2   libjvm.dylib                  0x27e88e1d JVM_RaiseSignal + 359549
      3   libjvm.dylib                  0x27e8912c JVM_RaiseSignal + 360332
      4   libjvm.dylib                  0x27e7f304 JVM_RaiseSignal + 319844
      7   libjvm.dylib                  0x27cb87f1 JVM_Write + 3541
      8   libjvm.dylib                  0x27cb873a JVM_Write + 3358
      9   libjvm.dylib                  0x27c27a3f jio_vsnprintf + 24651
      10  libjvm.dylib                  0x27c0e9a9 JNI_CreateJavaVM_Impl + 52641
      11  libSystem.B.dylib             0x92b9881d _pthread_start + 345
      12  libSystem.B.dylib             0x92b986a2 thread_start + 34
      Thread 10:  Java: VM Thread
      7   libjvm.dylib                  0x27c91c75 JVM_Lseek + 148053
      8   libjvm.dylib                  0x27c91a3a JVM_Lseek + 147482
      Thread 11:  Java: Reference Handler
      4   libjvm.dylib                  0x27ec3caa JVM_RaiseSignal + 600842
      5   libjvm.dylib                  0x27ec3e89 JVM_RaiseSignal + 601321
      6   libjvm.dylib                  0x27c9d6ee JVM_MonitorWait + 210
      7   libjvmlinkage.dylib           0x2299be05 JVM_MonitorWait + 69
      8   ???                           0x4f80b959 0 + 1333836121
      9   ???                           0x4f803db1 0 + 1333804465
      10  ???                           0x4f803db1 0 + 1333804465
      11  ???                           0x4f8012d3 0 + 1333793491
      12  libjvm.dylib                  0x27c92d58 JVM_Lseek + 152376
      13  libjvm.dylib                  0x27c92b06 JVM_Lseek + 151782
      14  libjvm.dylib                  0x27c9d4c0 JVM_StartThread + 2654
      15  libjvm.dylib                  0x27c9d3c2 JVM_StartThread + 2400
      16  libjvm.dylib                  0x27c9d30a JVM_StartThread + 2216
      17  libjvm.dylib                  0x27c9d17f JVM_StartThread + 1821
      18  libjvm.dylib                  0x27c9d02b JVM_StartThread + 1481
      19  libjvm.dylib                  0x27c0e9a9 JNI_CreateJavaVM_Impl + 52641
      20  libSystem.B.dylib             0x92b9881d _pthread_start + 345
      21  libSystem.B.dylib             0x92b986a2 thread_start + 34
      Thread 12:  Java: Finalizer
      10  ???                           0x4f803f17 0 + 1333804823
      11  ???                           0x4f803f17 0 + 1333804823
      12  ???                           0x4f8012d3 0 + 1333793491
      13  libjvm.dylib                  0x27c92d58 JVM_Lseek + 152376
      14  libjvm.dylib                  0x27c92b06 JVM_Lseek + 151782
      15  libjvm.dylib                  0x27c9d4c0 JVM_StartThread + 2654
      16  libjvm.dylib                  0x27c9d3c2 JVM_StartThread + 2400
      17  libjvm.dylib                  0x27c9d30a JVM_StartThread + 2216
      18  libjvm.dylib                  0x27c9d17f JVM_StartThread + 1821
      19  libjvm.dylib                  0x27c9d02b JVM_StartThread + 1481
      20  libjvm.dylib                  0x27c0e9a9 JNI_CreateJavaVM_Impl + 52641
      21  libSystem.B.dylib             0x92b9881d _pthread_start + 345
      22  libSystem.B.dylib             0x92b986a2 thread_start + 34
      Thread 13:  Java: Surrogate Locker Thread (CMS)
      6   libjvm.dylib                  0x27c0ea9b JNI_CreateJavaVM_Impl + 52883
      7   libjvm.dylib                  0x27cb0156 JVM_IsPrimitiveClass + 5270
      8   libjvm.dylib                  0x27cb0109 JVM_IsPrimitiveClass + 5193
      9   libjvm.dylib                  0x27c9d17f JVM_StartThread + 1821
      10  libjvm.dylib                  0x27c9d02b JVM_StartThread + 1481
      11  libjvm.dylib                  0x27c0e9a9 JNI_CreateJavaVM_Impl + 52641
      12  libSystem.B.dylib             0x92b9881d _pthread_start + 345
      13  libSystem.B.dylib             0x92b986a2 thread_start + 34
      Thread 14:  Java: Signal Dispatcher
      0   libSystem.B.dylib             0x92b6b136 semaphore_wait_trap + 10
      1   libjvm.dylib                  0x27cb0d60 JVM_IsPrimitiveClass + 8352
      2   libjvm.dylib                  0x27cb0c46 JVM_IsPrimitiveClass + 8070
      3   libjvm.dylib                  0x27c9d17f JVM_StartThread + 1821
      4   libjvm.dylib                  0x27c9d02b JVM_StartThread + 1481
      Thread 15:  Java: CompilerThread0
      7   libjvm.dylib                  0x27cb8328 JVM_Write + 2316
      8   libjvm.dylib                  0x27cb1deb JVM_IsPrimitiveClass + 12587
      9   libjvm.dylib                  0x27cb1ceb JVM_IsPrimitiveClass + 12331
      10  libjvm.dylib                  0x27c9d17f JVM_StartThread + 1821
      11  libjvm.dylib                  0x27c9d02b JVM_StartThread + 1481
      12  libjvm.dylib                  0x27c0e9a9 JNI_CreateJavaVM_Impl + 52641
      13  libSystem.B.dylib             0x92b9881d _pthread_start + 345
      14  libSystem.B.dylib             0x92b986a2 thread_start + 34
      Thread 16:  Java: Low Memory Detector
      7   libjvm.dylib                  0x27cb38ae JVM_IsPrimitiveClass + 19438
      Thread 17:  Java: VM Periodic Task Thread
      3   libjvm.dylib                  0x27e892cb JVM_RaiseSignal + 360747
      4   libjvm.dylib                  0x27cb5725 JVM_IsPrimitiveClass + 27237
      Thread 18:  Java: FelixDispatchQueue
      11  ???                           0x4f803db1 0 + 1333804465
      12  ???                           0x4f803db1 0 + 1333804465
      13  ???                           0x4f80428d 0 + 1333805709
      14  ???                           0x4f8012d3 0 + 1333793491
      15  libjvm.dylib                  0x27c92d58 JVM_Lseek + 152376
      16  libjvm.dylib                  0x27c92b06 JVM_Lseek + 151782
      17  libjvm.dylib                  0x27c9d4c0 JVM_StartThread + 2654
      18  libjvm.dylib                  0x27c9d3c2 JVM_StartThread + 2400
      19  libjvm.dylib                  0x27c9d30a JVM_StartThread + 2216
      20  libjvm.dylib                  0x27c9d17f JVM_StartThread + 1821
      21  libjvm.dylib                  0x27c9d02b JVM_StartThread + 1481
      22  libjvm.dylib                  0x27c0e9a9 JNI_CreateJavaVM_Impl + 52641
      23  libSystem.B.dylib             0x92b9881d _pthread_start + 345
      24  libSystem.B.dylib             0x92b986a2 thread_start + 34
      Thread 19:  Java: FelixStartLevel
      11  ???                           0x4f80428d 0 + 1333805709
      Thread 20:  Java: FelixPackageAdmin
      Thread 21:  Java: Code Model Worker
      3   libjvm.dylib                  0x27e88fca JVM_RaiseSignal + 359978
      4   libjvm.dylib                  0x27d1e2a9 JVM_ActiveProcessorCount + 221
      5   ???                           0x4f80b959 0 + 1333836121
      6   ???                           0x4f803db1 0 + 1333804465
      7   ???                           0x4f803db1 0 + 1333804465
      8   ???                           0x4f80428d 0 + 1333805709
      9   ???                           0x4f8043f3 0 + 1333806067
      Thread 22:  Java: Code Model Worker
      Thread 23:
      1   libSystem.B.dylib             0x92bc4c64 nanosleep$UNIX2003 + 188
      2   com.adobe.flash.flbridge      0x23bbed4b ScObjects::Thread::sleep(unsigned int) + 59
      3   com.adobe.flash.flbridge      0x23bb92d3 ScObjects::BridgeTalkThread::run() + 163
      4   com.adobe.flash.flbridge      0x23bbee58 ScObjects::Thread::go(void*) + 168
      5   libSystem.B.dylib             0x92b9881d _pthread_start + 345
      6   libSystem.B.dylib             0x92b986a2 thread_start + 34
      Thread 24:
      3   ...ia.Flash Player.authplaylib 0x21cfd31f 0x218da000 + 4338463
      4   ...ia.Flash Player.authplaylib 0x218f36ef 0x218da000 + 104175
      5   ...ia.Flash Player.authplaylib 0x21cfd40c 0x218da000 + 4338700
      6   ...ia.Flash Player.authplaylib 0x21cfd450 0x218da000 + 4338768
      7   ...ia.Flash Player.authplaylib 0x21cfd53b 0x218da000 + 4339003
      8   libSystem.B.dylib             0x92b9881d _pthread_start + 345
      9   libSystem.B.dylib             0x92b986a2 thread_start + 34
      Thread 25:
      Thread 26:
      0   libSystem.B.dylib             0x92b8a086 select$DARWIN_EXTSN + 10
      1   com.apple.CoreFoundation      0x9840880d __CFSocketManager + 1085
      Thread 27:  Java: Thread-2
      3   libjvm.dylib                  0x27e89225 JVM_RaiseSignal + 360581
      4   libjvm.dylib                  0x27cead1c JVM_Sleep + 242
      5   libjvmlinkage.dylib           0x2299ca18 JVM_Sleep + 72
      6   ???                           0x4f80b959 0 + 1333836121
      9   ???                           0x4f8012d3 0 + 1333793491
      10  libjvm.dylib                  0x27c92d58 JVM_Lseek + 152376
      11  libjvm.dylib                  0x27c92b06 JVM_Lseek + 151782
      12  libjvm.dylib                  0x27c9d4c0 JVM_StartThread + 2654
      13  libjvm.dylib                  0x27c9d3c2 JVM_StartThread + 2400
      14  libjvm.dylib                  0x27c9d30a JVM_StartThread + 2216
      15  libjvm.dylib                  0x27c9d17f JVM_StartThread + 1821
      16  libjvm.dylib                  0x27c9d02b JVM_StartThread + 1481
      17  libjvm.dylib                  0x27c0e9a9 JNI_CreateJavaVM_Impl + 52641
      18  libSystem.B.dylib             0x92b9881d _pthread_start + 345
      19  libSystem.B.dylib             0x92b986a2 thread_start + 34
      Thread 28:
      0   libSystem.B.dylib             0x92b6b15a semaphore_timedwait_signal_trap + 10
      1   libSystem.B.dylib             0x92b98ca5 _pthread_cond_wait + 1066
      2   libSystem.B.dylib             0x92bc7848 pthread_cond_timedwait_relative_np + 47
      3   ...ia.Flash Player.authplaylib 0x21cfd2e7 0x218da000 + 4338407
      4   ...ia.Flash Player.authplaylib 0x21aaf38e 0x218da000 + 1921934
      Thread 29:
      Thread 0 crashed with X86 Thread State (32-bit):
        eax: 0x00000048  ebx: 0x00000000  ecx: 0x00000001  edx: 0x4c22de38
        edi: 0x00000000  esi: 0x4c22de38  ebp: 0xbfffc018  esp: 0xbfffc000
         ss: 0x0000001f  efl: 0x00010286  eip: 0x03104bb7   cs: 0x00000017
         ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
        cr2: 0x00000048
      Binary Images:
          0x1000 -  0x17c5fe0 +com.adobe.flash 11.0.0.485 (11.0.0) <2343CC5D-89F9-6FED-DC01-7365A3714AB8> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/Adobe Flash CS5
      0x20e9000 -  0x2261ffb +com.adobe.PlugPlug 2.0.0.746 (2.0.0.746) <08AD22E3-34C0-6749-E497-616C66A246AD> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
      0x2305000 -  0x23d2fe7 +AdobeAXEDOMCore ??? (???) <F76D74DC-FD5A-9783-C447-2E58773DA7E1> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
      0x2441000 -  0x24d2ff7 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <581475CC-C039-1B42-49BA-71811D8B4E15> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
      0x24f1000 -  0x25beff3 +libicui18n.dylib.36.0 36.0.0 (compatibility 36.0.0) <08F15219-7F35-574E-7725-1ACAA1B18A00> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUInternationalization.framework/Versions/3.6/libicui18n.dyl ib.36.0
      0x2621000 -  0x26fbfef +libicuuc.dylib.36.0 36.0.0 (compatibility 36.0.0) <5EE72009-40B3-7FB7-3A49-576AEDE0D400> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUUnicode.framework/Versions/3.6/libicuuc.dylib.36.0
      0x273b000 -  0x30ebfff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <02108DEA-3DD2-14BE-DAEB-BE522B619C1D> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
      0x30ee000 -  0x30f9fef +libChar16.dylib ??? (???) <0221EB9E-35A8-64CC-5A72-FC3CB24D9854> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/libChar16.dylib
      0x3101000 -  0x3118fe0 +libCoreTypes.dylib ??? (???) <6CE8917C-AB39-4A09-2E6B-59C4AEF06701> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/libCoreTypes.dylib
      0x3135000 -  0x3144fef +ZLib.dylib ??? (???) /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/frameworks/ZLib.dylib
      0x3149000 -  0x3344ff7  com.apple.carbonframeworktemplate 1.0 (1.0) <C10F12ED-AEA6-63FA-7212-A170F37FE049> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/frameworks/Xerces.framework/Versions/A/Xerces
      0x35e6000 -  0x35eeff7  com.apple.JavaVM 13.3.0 (13.3.0) <305C2162-CCF2-1D2A-EE2B-B7D666DEA849> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
      0x35f8000 -  0x4383fe7 +com.adobe.illustrator 382 (15.0.0) <64F68532-0311-6BBA-1F50-246CAF917549> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
      0x5168000 -  0x51acfff +com.adobe.illustrator.aiport AIPort version 1.0 (1.0) <69EDC44E-D7BB-A259-282D-C42725AE0E26> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AIPort.framework/Versions/A/AIPort
      0x520f000 -  0x5255fff +FilterPort ??? (???) <23FAE9D1-9376-1E71-21F7-D3EB2BFD50EE> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/FilterPort.framework/Versions/A/FilterPort
      0x52ca000 -  0x52cafff +SPBasic ??? (???) <5D1760D8-C910-C641-0BC9-CF74A1A5190D> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
      0x52ce000 -  0x52eaff9 +AdobePDFSettings ??? (???) /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
      0x5304000 -  0x5418fff +AdobeACE ??? (???) <DD291A17-ECF4-FE20-5837-AC1F5BC76940> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
      0x543b000 -  0x593dfef +AdobeAGM ??? (???) <5B8478AC-5DD0-F116-5B3E-45596CF551C6> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
      0x5a79000 -  0x5ab4fff +AdobeARE ??? (???) <CEE507DA-9B96-FAF9-7894-445C427C3D7A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
      0x5abd000 -  0x5ad7fff +AdobeBIB ??? (???) <5533CDC7-676C-0CF0-97B7-8EDD26837FFC> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
      0x5ae0000 -  0x5b01ff7 +AdobeBIBUtils ??? (???) <726B8463-9301-CE6C-0F2C-5CA81795A4CA> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
      0x5b0d000 -  0x5dffff7 +AdobeCoolType ??? (???) <2BF62C8A-D715-FDE8-650C-1984CFFCE33C> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
      0x5e87000 -  0x625fff7 +AdobeMPS ??? (???) <272DAEDE-FC7E-B412-7C97-CF47FF6BF242> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
      0x638e000 -  0x646cfef +AdobePDFPort ??? (???) <324E65FD-0011-F93F-9B92-FB4E17968181> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
      0x64a2000 -  0x6ad6feb +AdobePDFL ??? (???) <1A619F3E-A9D4-A99C-791E-92B564F64609> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
      0x6c02000 -  0x6c28ff6 +AdobeAXE8SharedExpat ??? (???) <5848BBCE-3A3E-66EE-5527-97A96F0CA4CC> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
      0x6c39000 -  0x6c60fed +AdobeAXE16SharedExpat ??? (???) <66F4E782-C848-AD92-686D-5A479A4B333A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedEx pat
      0x6c72000 -  0x6ccaff7 +AdobeXMP ??? (???) <73329999-C364-2451-6574-4D0277057D19> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
      0x6cd9000 -  0x6d46fef +FileInfo ??? (???) <4A4C74F9-CA83-B174-F56D-F7671DC61389> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
      0x6d61000 -  0x6f00fe7 +com.adobe.owl AdobeOwl version 3.0.81 (3.0.81) <9C261D9E-9BD7-5DE6-5676-AEEF4828D17B> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
      0x6f69000 -  0x7cacfff +com.adobe.psl AdobePSL 12.0.0.7524 (12.0.0.7524) <CFBCB19A-03F7-D095-1F48-8D68F05A25C5> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
      0x7feb000 -  0x81d1ff7 +com.adobe.linguistic.LinguisticManager 5.0.0 (11696) <AF804353-8B13-7180-F2C8-832361EB2D5A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
      0x825f000 -  0x8263ffc +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <E6437929-0E69-8A56-E69F-F64305E82DD9> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
      0x826a000 -  0x8523fe7 +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.150919) <54AE7B13-C660-531F-B508-33372008A21E> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
      0x8824000 -  0x8979fff +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.150919) <5BEA3AAE-2865-D8AF-F798-704D00DACC17> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
      0x8ace000 -  0x8de3fe7 +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.150919) <AFDABF21-752A-2341-6A4E-62DA544BEA94> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
      0x92a8000 -  0x930effb +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <DD471011-9120-1BC2-F1B5-D6FF09D0859F> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
      0x933e000 -  0x9391ffb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <4F2BFF03-01D2-A07D-E5E2-7F88D4C2DEC4> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
      0x93d9000 -  0x93ebfff +com.adobe.pip ??? (5.0.0.2021) <5251926B-C2C0-282C-B3A9-94A9FEF0FCB8> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
      0x93f4000 -  0x952cfe7 +WRServices ??? (???) <87183F9D-17F4-6BDC-66A9-8FD34F320118> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
      0x956e000 -  0x9574fef +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.150919) <44362FE9-5F8A-A2EE-88E4-6876D6D8507F> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
      0x9585000 -  0x9590ff3 +com.adobe.boost_filesystem.framework boost_filesystem version 5.0.0 (5.0.0.150919) <27F6A491-0234-ED1A-CC83-A792D5865E97> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
      0x95a4000 -  0x9622fe2 +com.adobe.boost_regex.framework boost_regex version 5.0.0 (5.0.0.150919) <4B98FD95-A873-1A50-FFC7-BC6D90759A1A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
      0x9686000 -  0x9690fff +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.150919) <6D8C35A9-703F-852C-6CF0-D7DC36796BC6> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
      0x96a3000 -  0x96a5ffb +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.150919) <CE5A959A-AA4D-5983-79B3-8C47CFDDC446> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
      0x96ad000 -  0x96b4ff2 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.150919) <E752F69B-EA07-7079-CFF1-118E97A4A8FD> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
      0x96c4000 -  0x9855ff3 +aflamingo ??? (???) <C4136948-FE16-15C4-F1B9-040E014AF2CA> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
      0x9a18000 -  0x9a1bff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <FFDDAB7A-220F-7344-F12B-010CA0C41DAB> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
      0x9a21000 -  0x9b19ff7 +FlashIK Framework ??? (1.0) <3982AF5C-BAE4-1FC6-DB73-4EF99B23994A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/FlashIK.framework/Versions/A/FlashIK
      0x9bb0000 -  0x9bf0ffb +PFF Framework ??? (1.0) <8DB6CAC7-8E77-7FD0-140B-D60BE8D0556E> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/PFF.framework/Versions/A/PFF
      0x9c1d000 -  0xa619fef +aflame ??? (???) <B07806FD-0449-CBC6-FB92-0745A6D914D5> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/aflame.framework/Versions/A/aflame
      0xa7dc000 -  0xa81cff7  com.apple.vmutils 4.2 (106) <7AAF9FDA-AC1E-09FD-889E-68FFB5F94BA8> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
      0xa835000 -  0xa8eafe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
      0xa9a5000 -  0xa9a6ff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
      0xaedc000 -  0xaf43fea +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <EE468E2C-A6BD-E2EE-7ABE-69168B143B44> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
      0xaf82000 -  0xaff2feb +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <50675115-BEDC-72F9-C42D-374196E83EC2> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
      0x1fcd6000 - 0x1fcdefff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
      0x202d0000 - 0x202d2ff3  com.apple.LiveType.component 2.1.4 (2.1.4) <D60E2537-3B47-EA99-0077-6CE394378D07> /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
      0x202d8000 - 0x2033cfe2  com.apple.LiveType.framework 2.1.4 (2.1.4) <C9D29156-2471-2A9D-3657-EF06204229C6> /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
      0x2035c000 - 0x203a2ffb  com.apple.motion.component 1.0 (729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
      0x203a8000 - 0x203aaff7  Motion 729.0.0 (compatibility 1.0.0) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
      0x203b0000 - 0x2044dff8  com.apple.procore.framework 4.0.2 (757) <D3146F1E-F86D-F2A2-509B-E3F9640CBE40> /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
      0x210d0000 - 0x210d2ffd +com.macromedia.Flash.FLfile 11.0.0.485 (11.0.0) <5DA72BFA-D78D-94E0-0F0F-9EAC705646C6> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/FLfile.bundle/Contents/MacOS/FLfile
      0x210f0000 - 0x21267fe7  GLEngine ??? (???) <0FC1F7CA-5C84-A7F6-105B-169383B50A94> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
      0x21299000 - 0x2129aff7  ATSHI.dylib ??? (???) <A7A8E224-2579-BD3B-7281-86342D077252> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
      0x2129f000 - 0x216a4fe7  libclh.dylib 3.1.1 C  (3.1.1) <4A445142-1AD3-2F3C-FF95-E835B49B33DE> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
      0x216c8000 - 0x216d6fe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <8F5FA7F7-840D-C5EF-C6E6-E2AF7CE43CD2> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
      0x216da000 - 0x216ecff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <026B8702-B0A6-1D90-BBD6-AAAD2E14810D> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
      0x21744000 - 0x21767fe7  GLRendererFloat ??? (???) <D71788AA-645A-02CF-201F-E44F073F98D7> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
      0x217a2000 - 0x217a6ff3  com.apple.audio.AudioIPCPlugIn 1.1.2 (1.1.2) <5570694E-039D-7970-6083-1C8A7B7C937B> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
      0x217ab000 - 0x217b1ffb  com.apple.audio.AppleHDAHALPlugIn 1.8.7 (1.8.7f1) <0FE8B697-6D19-69C6-FA94-E18064ACFAEC> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
      0x217bb000 - 0x217bbfff +com.macromedia.Flash.flastoragelib 9.0 (9.0) <2A65AAC2-2EEF-8618-244A-13ECFF24E16E> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/PlugIns/FLAStorageLib.bundle/Contents/MacOS/FLAStorageLib
      0x217c0000 - 0x217d4ff7 +AdobeSFL ??? (???) <D6D44AC1-8AEC-56BB-8CDD-9059711B3485> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
      0x218da000 - 0x22229ff3 +com.macromedia.Flash Player.authplaylib 10.1.52.14 (1.0.1d333) <23ED9968-F20E-1132-26B1-0BC42DC14A05> /Applications/Adobe Flash CS5/Common/Configuration/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib
      0x227e7000 - 0x227ecff7  libFontStreams.A.dylib 543.50.0 (compatibility 64.0.0) <9D14A07D-1EA2-77D6-C0ED-DB73107750E2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
      0x22844000 - 0x22867fe7 +ServiceManager-Launcher.dylib ??? (???) <12CEC4C0-8682-A5FD-BAD4-A3E4A4F6218A> /Library/Application Support/Adobe/CS5ServiceManager/lib/ServiceManager-Launcher.dylib
      0x22874000 - 0x22888ffb +com.yourcompany.PointGrid ??? (1.0) <97938B0E-FD0E-BC24-12A5-90D33523249D> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/PointGrid.bundle/Contents/MacOS/PointGrid
      0x2299b000 - 0x229a2ff3  libjvmlinkage.dylib ??? (???) <5EC4F027-FDF1-C828-6419-F51B9BE15B03> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjvmlinkage.dylib
      0x229ab000 - 0x229d4feb +com.adobe.ape adbeapecore version 3.1.70.10055 (3.1.70.10055) <F3239526-C171-AD3C-835E-FC9998EEFB28> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
      0x22b00000 - 0x22b39ffb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <C64CCBDC-B8E9-45E8-53E7-8577CFE9F2F0> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
      0x22c1e000 - 0x22c26ff7  libverify.dylib 1.0 (1.0) <5E6D4960-086E-AC8B-5428-8271E5757EB4> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libverify.dylib
      0x22c71000 - 0x22c79ff7  JavaNativeFoundation ??? (???) <2969E61F-2A16-2A87-1B39-777B86F8230A> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.fr amework/Versions/A/JavaNativeFoundation
      0x22f89000 - 0x22f95ff7  libzip.jnilib ??? (???) <3C06C8CF-FACA-8D51-BAD3-17882A5BE9E2> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libzip.jnilib
      0x2353c000 - 0x23559ff7  libjava.jnilib ??? (???) <153634A3-2CC3-8ED3-7DD8-6A9A7499B7C5> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjava.jnilib
      0x23b9e000 - 0x23bdcffb +com.adobe.flash.flbridge 11.0.0.485 (11.0.0) <10AA8563-6870-61EE-1CEE-0FB603AD2BE4> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/FLBridge.bundle/Contents/MacOS/FLBridge
      0x24ed9000 - 0x24f40ffb +com.yourcompany.Brush ??? (1.0) <25E6C744-6FCC-CF39-C01F-C14BAA743519> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/Brush.bundle/Contents/MacOS/Brush
      0x253ce000 - 0x25459feb +com.yourcompany.Collision ??? (1.0) <258F5AD8-2C92-833F-1076-105635401C53> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/Collision.bundle/Contents/MacOS/Collision
      0x27c00000 - 0x27f3ffe7  libjvm.dylib ??? (???) <7F24D205-A978-B11A-4845-24248381CACC> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bundle/Libraries/libjvm. dylib
      0x33c84000 - 0x33d8dff7 +com.yourcompany.Stroke ??? (1.0) <42A62A75-F5EB-27E7-47B3-B14FEABA4693> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/Stroke.bundle/Contents/MacOS/Stroke
      0x40000000 - 0x400d1fe7 +AdobeJP2K ??? (???) <EF392886-5A95-6A96-C95D-43DA0322925C> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
      0x8f050000 - 0x8f711fef  com.apple.GeForceGLDriver 1.6.18 (6.1.8) <2E4BD283-8E9B-6AB7-2945-F92F5015DA02> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
      0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <A4F6ADCC-6448-37B4-ED6C-ABB2CD06F448> /usr/lib/dyld
      0x9003f000 - 0x90057ff7  com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
      0x90058000 - 0x90058ff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
      0x90059000 - 0x90069ff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
      0x901e6000 - 0x9020aff7  libJPEG.dylib ??? (???) <5CE96981-6B2A-D15B-4A17-E7BD329095B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
      0x9020b000 - 0x9026fffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
      0x90270000 - 0x90729ffb  com.apple.VideoToolbox 0.484.11 (484.11) <6AB58081-F7C4-46F9-2C05-CFED9E38F0A0> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
      0x9072a000 - 0x9090cfff  com.apple.imageKit 2.0.3 (1.0) <BF2ECA4D-FCD8-AD5D-E100-22370F2C7EE0> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
      0x90940000 - 0x909c2ffb  SecurityFoundation ??? (???) <3670AE8B-06DA-C447-EB14-79423DB9C474> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
      0x90b24000 - 0x90bbfff7  com.apple.ApplicationServices.ATS 275.11.1 (???) <5FF65EC7-F512-530A-7771-3DE240EE6E43> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
      0x90bc0000 - 0x90bd4ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <0DBE17D5-17A2-8A0E-8572-5A78408B41C9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
      0x90bd5000 - 0x90bd5ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
      0x90bd6000 - 0x90c7effb  com.apple.QD 3.35 (???) <B80B64BC-958B-DA9E-50F9-D7E8333CC5A2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
      0x90c7f000 - 0x90fe7ff7  com.apple.QuartzCore 1.6.2 (227.22) <4288F0D2-0C87-F054-C372-8764B44DE024> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
      0x9102e000 - 0x91327fef  com.apple.QuickTime 7.6.6 (1742) <89720F2A-F33B-FF09-3D81-F9F25A99F3EB> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
      0x9143f000 - 0x9154efe7  com.apple.WebKit 6533.18 (6533.18.1) <157D0DD9-F3CE-4339-858B-B0EFFAA3B008> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
      0x9158a000 - 0x915ceff3  com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
      0x915ef000 - 0x9163cfeb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <52906E26-3D22-6F37-8C90-E50BBCDEA5D0> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
      0x9163d000 - 0x9164dff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
      0x9164e000 - 0x91742ff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <9EC28185-D26F-533F-90C4-FBAA13A15947> /usr/lib/libiconv.2.dylib
      0x91743000 - 0x917bcff7  com.apple.PDFKit 2.5.1 (2.5.1) <CEF13510-F08D-3177-7504-7F8853906DE6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
      0x917bd000 - 0x919b4feb  com.apple.JavaScriptCore 6533.18 (6533.18.1) <EE3897A8-E1C0-DE28-A631-4B0C32DF737B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
      0x91ae3000 - 0x91b8cff7  com.apple.CFNetwork 454.9.8 (454.9.8) <DB2A5C33-E833-1B3A-4DE0-5FF172B2048B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
      0x91b8d000 - 0x91bbdff7  com.apple.MeshKit 1.1 (49.2) <ECFBD794-5D36-4405-6184-5568BFF29BF3> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
      0x91bbe000 - 0x91bffff7  libRIP.A.dylib 543.50.0 (compatibility 64.0.0) <8BAE1FC1-A478-F151-17C7-2D5DE470AC4F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
      0x91c51000 - 0x91d7dfff  com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) <F0D7256E-0914-8E77-E37B-9720430422AB> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
      0x91d7e000 - 0x91fe2fef  com.apple.security 6.1.1 (37594) <3F68A006-6B30-85D5-1A75-8D748F72A6D5> /System/Library/Frameworks/Security.framework/Versions/A/Security
      0x91fe3000 - 0x91fe3ff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
      0x91fe4000 - 0x92017ff7  com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
      0x92018000 - 0x9205eff7  libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
      0x9205f000 - 0x9207ffe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib
      0x92080000 - 0x92acbff7  com.apple.WebCore 6533.18 (6533.18.1) <B96BFDB8-3D11-E220-1148-206D8A176352> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
      0x92acc000 - 0x92b69fe3  com.apple.LaunchServices 362.1 (362.1) <885D8567-9E40-0105-20BC-42C7FF657583> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
      0x92b6a000 - 0x92d10feb  libSystem.B.dylib 125.2.0 (compatibility 1.0.0) <3441F338-2218-6D36-3F95-3A16FBF6713D> /usr/lib/libSystem.B.dylib
      0x92d11000 - 0x92e3ffe7  com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
      0x92e6c000 - 0x92ed6fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
      0x92ed7000 - 0x92edbff7  IOSurface ??? (???) <66E11D8E-CF4B-EFD0-37F9-20177C647021> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
      0x92efb000 - 0x93126ff3  com.apple.QuartzComposer 4.1 (156.16) <578A1842-8B62-00BF-B2E8-4C0AA8E6A938> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
      0x9341e000 - 0x93454fff  libtidy.A.dylib ??? (???) <DDFAB560-3883-A6A2-7BDD-D91730982B48> /usr/lib/libtidy.A.dylib
      0x93455000 - 0x93497ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <29E5ABCF-6D8A-0CE0-B480-C7D240FF8575> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
      0x93498000 - 0x934a2ff7  com.apple.HelpData 2.0.4 (34) <9128FFEB-0F6C-B273-FCF4-D87A20227345> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
      0x935d9000 - 0x935eefff  com.apple.ImageCapture 6.0 (6.0) <0E86F45E-E656-9015-7AD4-A2C5F8D8A2FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
      0x935ef000 - 0x9360aff7  libPng.dylib ??? (???) <36A3D75E-5178-4358-7F02-444E276D61AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
      0x93652000 - 0x9372fff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
      0x93730000 - 0x93736ff7  com.apple.DisplayServicesFW 2.2.2 (251) <6E4020F6-4DD0-F137-F226-F396807E3C3B> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
      0x93737000 - 0x93738ff7  com.apple.TrustEvaluationAgent 1.1 (1) <FEB55E8C-38A4-CFE9-A737-945F39761B4C> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
      0x93764000 - 0x93772fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
      0x9377b000 - 0x937d6ff7  com.apple.framework.IOKit 2.0 (???) <A013B850-6ECB-594A-CBD6-DB156B11871B> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
      0x937d7000 - 0x93820fe7  libTIFF.dylib ??? (???) <9CFF48CC-4852-4D06-17AC-3C947C824159> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
      0x93895000 - 0x9389aff7  com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
      0x9389b000 - 0x93a1dfe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <2314BD12-0821-75BB-F3BC-98D324CFD30A> /usr/lib/libicucore.A.dylib
      0x93a1e000 - 0x93a24fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
      0x94976000 - 0x94d8cff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
      0x94d8d000 - 0x94ddeff7  com.apple.HIServices 1.8.0 (???) <10C85B88-C6AF-91DB-2546-34661BA35AC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
      0x94ddf000 - 0x94e1cff7  com.apple.CoreMedia 0.484.11 (484.11) <0346F9E5-AEFE-B751-7D85-88D156C01385> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
      0x94e1d000 - 0x956fdff7  com.apple.AppKit 6.6.6 (1038.29) <6F28C335-6DC2-AE0E-B79A-F256DBD0BB45> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x956fe000 - 0x9596effb  com.apple.Foundation 6.6.3 (751.29) <E77D3906-99F4-FEF4-FBB0-86FB3C94073E> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x9596f000 - 0x959c7fe7  com.apple.datadetectorscore 2.0 (80.7) <18C2FB6A-BF60-F838-768C-0306151C21DA> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
      0x95a5f000 - 0x95a66ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <6877F0D8-0DCF-CB98-5304-913667FF50FA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
      0x95a67000 - 0x95afffe7  edu.mit.Kerberos 6.5.10 (6.5.10) <8B83AFF3-C074-E47C-4BD0-4546EED0D1BC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
      0x95b33000 - 0x95b33ff7  com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
      0x95b34000 - 0x95be4ff3  com.apple.ColorSync 4.6.3 (4.6.3) <AA1076EA-7665-3005-A837-B661260DBE54> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
      0x95be5000 - 0x95c04ff7  com.apple.CoreVideo 1.6.1 (45.5) <EA39D59C-018E-E6EE-6323-809CDA61E3CE> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
      0x95c13000 - 0x95c16ff7  libCoreVMClient.dylib ??? (???) <CA0BA8DC-0159-A808-A300-750358A6970C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
      0x95c5b000 - 0x95c5fff7  libGIF.dylib ??? (???) <3ECD4D2C-40FE-E9A0-A2D2-E36D1C00D3A8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
      0x95ce3000 - 0x95cf4ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
      0x95cf5000 - 0x95d00ff7  libCSync.A.dylib 543.50.0 (compatibility 64.0.0) <4FA0CE4A-BDE5-0E3D-37F0-03B41F0C2637> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
      0x95e08000 - 0x95e43feb  libFontRegistry.dylib ??? (???) <A102F61F-25D5-001A-20C3-56304C585072> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
      0x95e44000 - 0x95e75ff3  libTrueTypeScaler.dylib ??? (???) <7601D717-236D-8F4E-91F5-E69BB2920478> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
      0x95e76000 - 0x95e9cfff  com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
      0x95ea8000 - 0x95efeff7  com.apple.MeshKitRuntime 1.1 (49.2) <F1EAE9EC-2DA3-BAFD-0A8C-6A3FFC96D728> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
      0x95eff000 - 0x95f03ff7  libGFXShared.dylib ??? (???) <2D32BDBF-C941-93FD-E233-F03D28DB9E94> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
      0x95f04000 - 0x95f0dff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
      0x960ab000 - 0x960b5fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
      0x960b6000 - 0x96270fe3  com.apple.ImageIO.framework 3.0.3 (3.0.3) <A93A514B-C1BF-21D0-FB03-CB775DE4FFAA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
      0x96271000 - 0x96372fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib
      0x96373000 - 0x96373ff7  com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
      0x96374000 - 0x96375ff7  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
      0x96394000 - 0x963d7ff7  libGLU.dylib ??? (???) <2093A1FB-67BD-39E0-CDE5-A97A77BDDBCE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
      0x963d8000 - 0x9641effb  com.apple.CoreMediaIOServices 130.0 (1035) <F5E6F93D-6844-9FD7-8769-44503DFD5363> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
      0x9641f000 - 0x96743fef  com.apple.HIToolbox 1.6.3 (???) <0A5F56E2-9AF3-728D-70AE-429522AEAD8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
      0x967b8000 - 0x967bbffb  com.apple.help 1.3.1 (41) <EF92C648-2085-C085-8EA7-A1AF37AE94F4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
      0x967bc000 - 0x967f9ff7  com.apple.SystemConfiguration 1.10.2 (1.10.2) <398BB007-41FD-1A30-26D8-CB86ED5E467E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
      0x967fb000 - 0x968c5fef  com.apple.CoreServices.OSServices 357 (357) <CF9530AD-F581-B831-09B6-16D9F9283BFA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
      0x968c6000 - 0x968c9fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
      0x968e3000 - 0x96c03feb  com.apple.CoreServices.CarbonCore 861.13 (861.13) <52803668-3669-36BD-57DD-078FBA835081> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
      0x96e0b000 - 0x96e0dff7  libRadiance.dylib ??? (???) <AB06F616-E3EA-5966-029A-8AA44BBE5B28> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
      0x96e0e000 - 0x96e19ff7  libGL.dylib ??? (???) <B87E0676-F5EF-8DA3-6DEE-13C43B3832A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
      0x96eca000 - 0x96f2bfe7  com.apple.CoreText 3.1.0 (???) <1372DABE-F183-DD03-03C2-64B2464A4FD5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
      0x96f2c000 - 0x96f4dfe7  com.apple.opencl 12.1 (12.1) <DA2AC3FA-ED11-2D10-21E9-7BDF4778B228> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
      0x96f4e000 - 0x9773d557  com.apple.CoreGraphics 1.545.0 (???) <DCED8E1A-7504-C31A-B6EF-98BFF1A61060> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
      0x977ba000 - 0x97873fe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
      0x97874000 - 0x978b3ff7  com.apple.ImageCaptureCore 1.0.2 (1.0.2) <18E338B0-D82E-2ADC-FB9E-8909E765C41B> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
      0x978c7000 - 0x978e9fef  com.apple.DirectoryService.Framework 3.6 (621.4) <B88E98EF-7F17-F988-62A4-3DEC0832B3B7> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
      0x978ea000 - 0x97ac5ff3  libType1Scaler.dylib ??? (???) <6FBA8250-3271-6ED4-052D-E27C2136E38F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
      0x97b0f000 - 0x97b1cff7  com.apple.NetFS 3.2.1 (3.2.1) <A6443845-5815-2429-7649-C51A4B5E7DF9> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
      0x97b1d000 - 0x97c0fff7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <D2C86308-F998-C83D-F49B-CD484D4EFE6A> /usr/lib/libcrypto.0.9.8.dylib
      0x97c10000 - 0x97c1cff7  libkxld.dylib ??? (???) <322A4B52-8305-3081-6B74-813C3A87A56D> /usr/lib/system/libkxld.dylib
      0x97c1d000 - 0x97c2fff7  com.apple.MultitouchSupport.framework 204.13 (204.13) <F91A4E32-01AA-49DB-2205-3DBE1FEFFC43> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
      0x97c30000 - 0x97c68ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <76C02F5C-98FD-BD64-B5FB-C698FB76EA25> /usr/lib/libcups.2.dylib
      0x97c69000 - 0x97cc3fe7  com.apple.CorePDF 1.3 (1.3) <696ADD5F-C038-A63B-4732-82E4109379D7> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
      0x97cc4000 - 0x97cecff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
      0x97ced000 - 0x97d9bff3  com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
      0x97d9c000 - 0x97e52ffb  libFontParser.dylib ??? (???) <067DC1A2-764B-41EA-B07E-4205472749B7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
      0x97e53000 - 0x97f55fef  com.apple.MeshKitIO 1.1 (49.2) <34322CDD-E67E-318A-F03A-A3DD05201046> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
      0x97f66000 - 0x98041fe7  com.apple.DesktopServices 1.5.7 (1.5.7) <A69072AD-C47E-A00D-4A69-6E46A7FB2119> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
      0x98042000 - 0x98056fe7  libbsm.0.dylib ??? (???) <821E415B-6C42-D359-78FF-E892792F8C52> /usr/lib/libbsm.0.dylib
      0x98057000 - 0x98073fe3  com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
      0x98074000 - 0x98075ff7  com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) <959DFFAE-A06B-7FF6-B713-B2076893EBBD> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
      0x98076000 - 0x98147fe3  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <8FDB4C40-D453-DA53-2A66-9A53998AB23C> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
      0x98148000 - 0x981dafe3  com.apple.print.framework.PrintCore 6.2 (312.5) <5B9EAAE8-7803-E0B3-9E5B-E9E2CCC8BA0E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
      0x981db000 - 0x982e7ff7  libGLProgrammability.dylib ??? (???) <1B315838-F477-5416-7504-67EC3433AD4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
      0x982f8000 - 0x9833bff7  com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
      0x9838a000 - 0x9838aff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
      0x9838b000 - 0x9838bff7  com.apple.quartzframework 1.5 (1.5) <CEB78F00-C5B2-3B3F-BF70-DD6D578719C0> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
      0x9838c000 - 0x98506fe3  com.apple.CoreFoundation 6.6.3 (550.29) <00373783-3744-F47D-2191-BEEA658F0C3D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x98527000 - 0x98565ff7  com.apple.QuickLookFramework 2.2 (327.4) <88A59C42-A200-FCB6-23EC-E848D0E14963> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
      0x98742000 - 0x98742ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
      0x98743000 - 0x9874aff3  com.apple.print.framework.Print 6.1 (237.1) <97AB70B6-C653-212F-CFD3-E3816D0F5C22> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
      0x9874b000 - 0x9874bff7  com.apple.Carbon 150 (152) <9252D5F2-462D-2C15-80F3-109644D6F704> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
      0x9874c000 - 0x987c4fef  com.apple.AppleVAFramework 4.9.20 (4.9.20) <D8B544CB-9E32-81C2-59BD-C5DDB66DA621> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
      0x987c5000 - 0x987f6ff7  libGLImage.dylib ??? (???) <9340012D-595A-6243-9C97-7D30D76D9D9E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
      0x987f7000 - 0x98865ff7  com.apple.QuickLookUIFramework 2.2 (327.4) <5B6A066B-B867-D3A3-BDEE-3D68FA5385B4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
      0x9887a000 - 0x988f5fe7  com.apple.audio.CoreAudio 3.2.2 (3.2.2) <51D0E2DC-B15F-AF6C-70D8-026DDAD4E2A5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
      0x98900000 - 0x9892aff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
      0x9892b000 - 0x9896ffe7  com.apple.Metadata 10.6.3 (507.10) <630494FA-3BB3-EDD3-E10B-8DAAF4831E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
      0x98970000 - 0x98ab3fef  com.apple.QTKit 7.6.6 (1742) <98ECA8E3-73F0-D21B-8B7E-8FE651E29A7F> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
      0x98ab4000 - 0x98b23ff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <706684C7-AFA0-B036-274A-D02F8961DED5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
      0x98bd5000 - 0x9900aff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
      0x9900b000 - 0x9900dff7  com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
      0x9900e000 - 0x9905eff7  com.apple.framework.familycontrols 2.0.1 (2010) <B9762E20-543D-13B9-F6BF-E8585F04CA01> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
      0x9905f000 - 0x990dffeb  com.apple.SearchKit 1.3.0 (1.3.0) <2F5DE102-A203-7905-7D12-FCBCF17BAEF8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
      0x99107000 - 0x994b5fe3  com.apple.RawCamera.bundle 3.3.0 (533) <05A38D21-8556-434C-8BAA-850A6EC99B37> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
      0x994b6000 - 0x995e2ffb  com.apple.MediaToolbox 0.484.11 (484.11) <B93B175A-2039-2FD2-FBE4-22C9F8C9E223> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
      0x995e3000 - 0x995e6ff7  libCGXType.A.dylib 543.50.0 (compatibility 64.0.0) <3B49AED9-0DBA-9D21-F9AC-8784363AD762> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
      0x99856000 - 0x99903fe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
      0x99904000 - 0x99912ff7  com.apple.opengl 1.6.9 (1.6.9) <4F06C166-00CF-5ACF-77E3-5A960A5E8AD3> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
      0x99913000 - 0x9991dffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
      0x9991e000 - 0x99945ff7  com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
      0xb0000000 - 0xb000fff8 +com.adobe.ahclientframework 1.5.0.30 (1.5.0.30) <24B39C2F-79B0-BDE3-C6D0-1F0E943070C7> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
      0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <12C58901-CCF3-4E8E-30CA-92A10CD55DF1> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
      0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <7FFF4AFA-6522-C7D5-760F-A8F13D6EF032> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
      0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <3441F338-2218-6D36-3F95-3A16FBF6713D> /usr/lib/libSystem.B.dylib
      Model: iMac10,1, BootROM IM101.00CC.B00, 2 processors, Intel Core 2 Duo, 3.06 GHz, 4 GB, SMC 1.52f9
      Graphics: NVIDIA GeForce 9400, NVIDIA GeForce 9400, PCI, 256 MB
      Memory Module: global_name
      AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 2.1.9.8.1
      Bluetooth: Version 2.3.3f8, 2 service, 19 devices, 1 incoming serial ports
      Network Service: AirPort, AirPort, en1
      Serial ATA Device: ST3500418ASQ, 465.76 GB
      Serial ATA Device: OPTIARC DVD RW AD-5680H
      USB Device: DT 101 II, 0x0951  (Kingston Technology Company), 0x1625, 0x24300000
      USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8502, 0x24400000
      USB Device: v100w, 0x03f0  (Hewlett Packard), 0x3207, 0x26400000
      USB Device: Internal Memory Card Reader, 0x05ac  (Apple Inc.), 0x8403, 0x26500000
      USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x04500000
      USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06100000
      USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8215, 0x06110000
