2 Replies Latest reply on Nov 19, 2010 8:57 AM by learner_doug
    Tool Tip?
    flex4 Level 2
      Hi All
                      Can any tell me how to use custom component as tool tip? I mean i have a panel that will display some User Information  and i want that panel as ToolTip when i place a cursor on one perticular user..
      Ram.
        • 1. Re: Tool Tip?
          learner_doug
          Here is an example that I use for my custom tooltips utilizing toolTip Manager.  I'm certain you can use some kind of inheritance if you have a lot of these since the code is a bit cumbersome.
          import
          mx.managers.ToolTipManager;
          public
          var owms1Tip:ToolTip;
          private function createBigTip(event:Event):void
          var s:String = "1. Order enters COMIT from the CTS Web Center\n\n2. Assigned Staff queries COMIT Tracking for unassigned\n orders and assigns orders to an Order Writer\n\n(CLICK MILESTONE for more options)"
          owms1Tip = ToolTipManager.createToolTip(s, 110, 110,
          null, IUIComponent(event.currentTarget)) as ToolTip;
          owms1Tip.setStyle(
          "backgroundColor",0x0e21a4);
          owms1Tip.setStyle(
          "cornerRadius", 8);
          owms1Tip.setStyle(
          "fontFamily", "Verdana");
          owms1Tip.setStyle(
          "color",0xFFFFFF);
          owms1Tip.setStyle(
          "fontSize",12);
          owms1Tip.width=380;
          owms1Tip.height=128;
          ow1.setStyle(
          "contentBackgroundAlpha", 1);
          ow1.setStyle(
          "contentBackgroundColor", 0xFFFFFF);
          private function destroyBigTip():void
          ToolTipManager.destroyToolTip(owms1Tip);
          ow1.setStyle(
          "contentBackgroundAlpha", 0);
          • 2. Re: Tool Tip?
            learner_doug Level 1
            Sorry, I realize this is not a panel.  For a panel you might be able to use the PopUpManager.  Here is one of my example using titleWindow.
            In this case I'm using the TitleWindow, so I hope the Panel will also work, but not sure.  The text/links and images and close handler are actually inside my titleWindow.  I presume you could use the mouseOver instead of click.  Hope this was helpful.
            // Custom PopUp:ow1 //
            private var popup:ow1PopUp = new ow1PopUp();
            Bindable] public var popUpTitle:String = "EBS New: Order Writer - Queue";
            protected function ow1_clickHandler(event:MouseEvent):void
            PopUpManager.addPopUp(popup,
            this, true);
            popup.x=110;
            popup.y=110;
