6 Replies Latest reply on Nov 19, 2010 6:18 AM by jfb00
    item renderer issue
    jfb00 Level 3
      I have a comboBox as item renderer in my datagrid (comboBox item renderer code bellow).
      1. How can I remove the first blank item? My comboBox arrayCollection doesn't have 0 item.
      2. If I come back to the cell that it was already selected with a value from my comboBox, how can I set the selected item of my comboBox to be the same as the previus value? If I leave the comboBox without selection it will be blank as the 0 element.
      Please help.
      Johnny
      <mx:ComboBox xmlns:mx="http://www.adobe.com/2006/mxml"
                   labelField="label" dataProvider="{acCombo}" rowCount="20"
                   change="onSelectionChange(event)" creationComplete="init()">
          <mx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  import mx.controls.dataGridClasses.DataGridListData;
                  import mx.events.ListEvent;
                  import mx.rpc.events.ResultEvent;
                  [Bindable]private var acCombo:ArrayCollection = new ArrayCollection ([{id:1, label:"Item 01"},{id:2, label:"Item 02"},{id:3, label:"Item 03"},
                      {id:4, label:"Item 04"},{id:5, label:"Item 05"}]);
                  private var _ownerData:Object;
                  public function init():void
                      //init code
                  override public function set data(value:Object):void
                      if (value){
                          _ownerData = value as Object;
                          var col:DataGridListData = DataGridListData(listData);
                          var item:Object = new Object;
                          var clabel:String = value[col.dataField];
                          var cid:int = value.id;
                          item.label = clabel;
                          item.id = cid;
                          selectedItem = item;
                  override public function get data():Object
                      return _ownerData;
                  override public function setFocus():void
                      super.setFocus();
                      open();
                  private function onSelectionChange(e:ListEvent):void
                      if(selectedItem && _ownerData){
                          var clabel:String = selectedItem.label;
                          var cid:int = selectedItem.id;
                          _ownerData[col.dataField] = clabel;
                          _ownerData[id] = cid;
          </mx:Script>
      </mx:ComboBox>
        • 1. Re: item renderer issue
          Matt Le Fevre Level 4
          unless i'm missing something, in the mxml set the selected index to 1?
          or you could hardcode in the dataprovider, eg:
          <mx:ComboBox id="comb1">
          <mx:dataProvider>
               <mx:Array>
               <mx:String>Item01</mx:String>
               </mx:Array>
               <mx:Array>
               <mx:String>Item02</mx:String>
               </mx:Array>
               <mx:Array>
               <mx:String>Item03</mx:String>
               </mx:Array>
               <mx:Array>
               <mx:String>Item04</mx:String>
               </mx:Array>
               <mx:Array>
               <mx:String>Item05</mx:String>
               </mx:Array>
               <mx:Array>
                <mx:String>Item06</mx:String>
               </mx:Array>
          </mx:dataProvider>
          </mx:ComboBox>
          • 2. Re: item renderer issue
            jfb00 Level 3
            Hello,
            That doesn't work.
            In the debug, after the step selectedItem = item; the selectedItem is null but I can see values for the label and id.
            I'm probably missing something simple.
            Any other ideas?
            Thanks!
            Johnny
            • 3. Re: item renderer issue
              jfb00 Level 3
              I created a sample, maybe someone can see the issue for me
              Thanks!
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" viewSourceURL="srcview/index.html"
                  <mx:Script>
                      <![CDATA[
                          import mx.events.CollectionEvent;
                          import mx.events.DataGridEvent;
                          import com.myItemEditor;
                          [Bindable] private var acExecution:ArrayCollection = new ArrayCollection([
                              {Territory:"Arizona", Territory_Rep:"Barbara Jennings", ITEM_ID:1, ITEM_NAME:"Item 01"},
                              {Territory:"Central California", Territory_Rep:"Joe Smith", ITEM_ID:2, ITEM_NAME:"Item 02"},
                              {Territory:"Nevada", Territory_Rep:"Bethany Pittman", ITEM_ID:2, ITEM_NAME:"Item 02"},
                              {Territory:"Northern California", Territory_Rep:"T.R. Smith", ITEM_ID:1, ITEM_NAME:"Item 01"},
                              {Territory:"Southern California", Territory_Rep:"Jane Grove", ITEM_ID:3, ITEM_NAME:"Item 03"}
                          private function init():void
                          private function onItemEditEnd(e:DataGridEvent):void
                              var cEditor:myItemEditor = dgCustomEditor.itemEditorInstance as myItemEditor;
                              var item:Object = cEditor.selectedItem;
                              acExecution.refresh();
                  </mx:Script>
                  <mx:DataGrid id="dgCustomEditor" dataProvider="{acExecution}" height="160"
                               editable="true" itemEditEnd="onItemEditEnd(event)">
                      <mx:columns>
                          <mx:DataGridColumn headerText="Territory" dataField="Territory" width="60"
                                             editable="false"/>
                          <mx:DataGridColumn headerText="Territory Rep" dataField="Territory_Rep" width="60"
                                             editable="false"/>
                          <mx:DataGridColumn headerText="Item ID" dataField="ITEM_ID" width="60"
                                             editable="false"/>
                          <mx:DataGridColumn headerText="Item Name" dataField="ITEM_NAME" width="160" itemEditor="com.myItemEditor" />
                      </mx:columns>
                  </mx:DataGrid>
              </mx:Application>
              Item Editor component
                           labelField="LABEL" dataProvider="{acCombo}" rowCount="20"
                  <mx:Script>
                      <![CDATA[
                          [Bindable]private var acCombo:ArrayCollection = new ArrayCollection ([{ID:1, LABEL:"Item 01"},{ID:2, LABEL:"Item 02"},{ID:3, LABEL:"Item 03"},
                              {ID:4, LABEL:"Item 04"},{ID:5, LABEL:"Item 05"}]);
                              //init code
                              if (value){
                                  var cid:int = value["ITEM_ID"];
                                  item.LABEL = clabel;
                                  item.ID = cid;
                              return _ownerData;
                              super.setFocus();
                              open();
                                  var clabel:String = selectedItem.LABEL;
                                  var cid:int = selectedItem.ID;
                                  _ownerData["ITEM_ID"] = cid;
                  </mx:Script>
              </mx:ComboBox>
              • 4. Re: item renderer issue
                as i thought, can be resolved by messing around with the components selectedIndex
                small alteration to make (in bold), try this for the itemEditor
                             change="onSelectionChange(event)" creationComplete="init(); this.selectedIndex = 0;">
                <mx:Script>
                        <![CDATA[
                                //init code
                                if (value){
                                    item.ID = cid;
                                return _ownerData;
                                super.setFocus();
                                open();
                    </mx:Script>
                </mx:ComboBox>
                that will remove the blank value, however i imagine a bug will remain where eg:
                you have Item 03 as the value, you go to edit it, it'll immediately switch to Item 01.
                to fix this you'll need to create a small function determine which one was previously stored as the value and then alter the selectedIndex depending on that.
                something like
                switch(storedValue)
                case("Item 01")
                     break;
                case("Item 02")
                     this.selectedIndex = 1;
                etc.....
                • 5. Re: item renderer issue
                  jfb00 Level 3
                  Got the idea, thanks for your reply and help!
                  I have many items in my comboBox. Here is the solution:
                                  selectItemFromCombo(_ownerData["ITEM_ID"]);
                                  super.setFocus();
                                  open();
                              public function selectItemFromCombo(ID:Number):void{
                                  var arrayIndex:Number = acCombo.length;
                                  for(var i:Number=0; i< arrayIndex; i++) {
                                      if(ID == acCombo[i].ID){
                                          this.selectedIndex = i;
                                          break;
                                      }else{
                  Johnny
                  • 6. Re: item renderer issue
                    jfb00 Level 3
                    This is close.
