Does anybody know how to remove all "copy" word from AI layers name line?
Robes Baum Nov 18, 2010 12:15 PMI downloaded a PSD script that auto remove the word "copy" from all layers. Inside AI, I can't do that. Does anyone can help me? Here is the jsx PSD script file:
// Script Name: RenameLayers.jsx
// Version: 1.0
// Date: 2/27/08
// Usage: Removes 'copy 1, copy 2, etc' from name of all layers
#target photoshop
//$.localize = true;
var displayDialogMode = app.displayDialogs;
app.bringToFront();
app.bringToFront();
app.displayDialogs = DialogModes.NO;
processObjects(app.documents, processDocument,function () {alert("You have no documents open")})
app.displayDialogs = displayDialogMode;
// Function: processObjects
// Usage: Runs theMainFunction on every object in list theObjects
// Input: List of objects (documents, layers, etc.), Function to run on each object, Function to run on parent if there are no object
// Return: value returned from function used
function processObjects(theObjects, theMainFunction, theAlternateFunction) {
var returnValue = null;
if (theObjects.length ==0) {
if (!(theAlternateFunction == undefined) && !(theAlternateFunction == null) && !(theAlternateFunction == "")) {
returnValue = theAlternateFunction (theObjects.parent);
} else {
if (!(theMainFunction == undefined) && !(theMainFunction == null) && !(theMainFunction == "")) {
for (var i = theObjects.length -1; i> -1; i--) {
returnValue += theMainFunction (theObjects[i], i);
return returnValue;
// Function: processDocument
// Usage: Processes layers of document with 'processLayer' function
// Input: Document object, Document object index
// Return: none
function processDocument(objectRef, i) {
app.activeDocument = objectRef
processObjects(objectRef.layers, processLayer, null);
// Function: processLayer
// Usage: Removes 'copy' from layer name (processes Layer Set contents)
// Input: Layer object, Layer Object index
// Return: none
function processLayer(objectRef, i) {
if (objectRef.typename == 'LayerSet') {
var layerCount = processObjects(objectRef.layers, processLayer);
renameLayer(objectRef)
return 0
// Function: renameLayer
// Return: none
function renameLayer(objectRef) {
var theRegEx = new RegExp(/(\s*copy\s*\d*)+$/)
if (theRegEx.test(objectRef.name)) {
// save state of layer (visible or invisible)
var layerVisible = objectRef.visible
var indexNumber = 0
indexnumber = objectRef.name.indexOf(" copy")
objectRef.name = objectRef.name.substr(0,indexnumber)
objectRef.visible = layerVisible
return 0
Anyone?
