4 Replies Latest reply on Nov 20, 2010 7:20 PM by Miggl
    ZendAMF Server Class Throwing Errors
    Miggl Level 1
      (mx.messaging.messages::ErrorMessage)#0
        body = (Object)#1
        clientId = (null)
        correlationId = "14E5A70F-0829-9D09-D237-61B6A51ED666"
        destination = ""
        extendedData = (null)
        faultCode = "Client.Error.MessageSend"
        faultDetail = "Channel.Connect.Failed error NetConnection.Call.BadVersion: : url: 'http://[servername]/development/'"
        faultString = "Send failed"
        headers = (Object)#2
        messageId = "55E31D60-FFC1-82EB-A00A-61B6A7F95FAF"
        rootCause = (mx.messaging.events::ChannelFaultEvent)#3
          bubbles = false
          cancelable = false
          channel = (mx.messaging.channels::AMFChannel)#4
            authenticated = false
            channelSets = (Array)#5
            connected = false
            connectTimeout = -1
            enableSmallMessages = true
            endpoint = "http://[servername]/development/"
            failoverURIs = (Array)#6
            id = "zend-endpoint"
            mpiEnabled = false
            netConnection = (flash.net::NetConnection)#7
              client = (mx.messaging.channels::AMFChannel)#4
              connected = false
              maxPeerConnections = 8
              objectEncoding = 3
              proxyType = "none"
              uri = "http://[servername]/development/"
            piggybackingEnabled = false
            polling = false
            pollingEnabled = true
            pollingInterval = 3000
            protocol = "http"
            reconnecting = false
            recordMessageSizes = false
            recordMessageTimes = false
            requestTimeout = -1
            url = "http://[servername]/development/"
            useSmallMessages = false
          channelId = "zend-endpoint"
          connected = false
          currentTarget = (mx.messaging.channels::AMFChannel)#4
          eventPhase = 2
          faultCode = "Channel.Connect.Failed"
          faultDetail = "NetConnection.Call.BadVersion: : url: 'http://[servername]/development/'"
          faultString = "error"
          rejected = false
          rootCause = (Object)#8
            code = "NetConnection.Call.BadVersion"
            description = ""
            details = ""
            level = "error"
          target = (mx.messaging.channels::AMFChannel)#4
          type = "channelFault"
        timestamp = 0
        timeToLive = 0
      I'm getting this error message when trying to use a RemoteObject that ties to ZendAMF server class.
      This is the RemoteObject:
                     [Bindable]
                     private var companyResults:ArrayCollection;
                     private function findAll_companyServiceHandler(event:ResultEvent):void
                          this.companyResults = new ArrayCollection(event.result as Array);
                          Alert.show(this.companyResults.length.toString());
                          for (var i:uint = 0; i < this.companyResults.length; i++)
                               Alert.show(CompanyVO(this.companyResults[i]).name);
                     protected function button1_clickHandler(event:MouseEvent):void
                          this.leadlawService.CompanyAmfService.findAll();
                          this.leadlawService.findAll();
                     protected function leadlawService_faultHandler(event:FaultEvent):void
                          Alert.show(event.message.toString());
           </fx:Script>
           <fx:Declarations>
                <s:RemoteObject
                     id="leadlawService"
                     destination="zend"
                     showBusyCursor="true"
                     fault="leadlawService_faultHandler(event)"
                     <s:method name="findAll" result="findAll_companyServiceHandler(event)" />
                </s:RemoteObject>
           </fx:Declarations>
      And here's the corresponding controller code using Zend Framework:
      <?php
       * ServicesController
       * @author
       * @version
      require_once 'Zend/Controller/Action.php';
      class ServicesController extends Zend_Controller_Action
           public function init()
                $this->_helper->viewRenderer->setNoRender();
           public function amfAction()
                $server = new Zend_Amf_Server();
                $server->addDirectory(APPLICATION_PATH . '/services/');
                echo $server->handle();
      And here the class that is in the services directory:
      <?php
      require_once APPLICATION_PATH . '/models/CompanyVO.php';
      class CompanyAmfService
            * @return array
           public function findAll()
                $results = array();
                $companyVO = new CompanyVO();
                $companies = $companyVO->fetchAll($companyVO->select());
                foreach ($companies as $company)
                     array_push($results, $company);
                return $results;
      And here the CompanyVO model class:
      <?php
      class CompanyVO extends Zend_Db_Table
           protected $_name = "company";
           public $_explicitType = "CompanyVO";
           public $id;
           public $name;
      Everything appears to look in order, and I tried to create my code according to the example in ZendAMF documentation. Can anyone see what is amiss here?
      Thanks for all your help!
      ~Mike
      Update 1:
      I forgot to add my services-config.xml:
      <?xml version="1.0" encoding="UTF-8"?>
      <services-config>
           <services>
                <service id="zend-service" class="flex.messaging.services.RemotingService" messageTypes="flex.messaging.messages.RemotingMessage">
                     <destination id="zend">
                          <channels>
                               <channel ref="zend-endpoint" />
                          </channels>
                          <properties>
                               <source>*</source>
                          </properties>
                     </destination>
                </service>
           </services>
           <channels>
                <channel-definition id="zend-endpoint" class="mx.messaging.channels.AMFChannel">
                     <endpoint uri="http://[servername]/development/" class="flex.messaging.endpoints.AMFEndpoint" />
                </channel-definition>
           </channels>
      </services-config>
