0 Replies Latest reply on Nov 19, 2010 1:47 AM by ravi burila
    network access probelm.........
    ravi burila
      i created a simple application by integrating flex-java and blaze DS.while accessing in other system within network iam getting an error message
      Error while connecting to database.Please,try after some time.         //user defined error message
      [FaultEvent fault=[RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend" faultDetail="Channel.Security.
      Error error Error #2048 url: 'http://localhost:9081/remote/messagebroker/amf'"]
      messageId="D1EAB63F-0B55-DEDA-AEE0-637E036F718D" type="fault" bubbles=false cancelable=true eventPhase=2]
      and my services and remote config files are.....
      service-config.xml
      <?xml version="1.0" encoding="UTF-8"?>
      <services-config>
          <services>
              <service-include file-path="remoting-config.xml" />
              <service-include file-path="proxy-config.xml" />
              <service-include file-path="messaging-config.xml" />
          </services>
          <security>
              <login-command class="flex.messaging.security.TomcatLoginCommand" server="Tomcat"/>
              <!-- Uncomment the correct app server
              <login-command class="flex.messaging.security.TomcatLoginCommand" server="JBoss">
        <login-command class="flex.messaging.security.JRunLoginCommand" server="JRun"/>
              <login-command class="flex.messaging.security.WeblogicLoginCommand" server="Weblogic"/>
              <login-command class="flex.messaging.security.WebSphereLoginCommand" server="WebSphere"/>
              <security-constraint id="basic-read-access">
                  <auth-method>Basic</auth-method>
                  <roles>
                      <role>guests</role>
                      <role>accountants</role>
                      <role>employees</role>
                      <role>managers</role>
                  </roles>
              </security-constraint>
          </security>
          <channels>
              <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
                  <endpoint url="http://172.18.3.80:9081/remote/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
              </channel-definition>
              <channel-definition id="my-secure-amf" class="mx.messaging.channels.SecureAMFChannel">
                  <endpoint url="https://172.18.3.80:9081/remote/messagebroker/amfsecure" class="flex.messaging.endpoints.SecureAMFEndpoint"/>
                  <properties>
                      <add-no-cache-headers>false</add-no-cache-headers>
                  </properties>
              <channel-definition id="my-polling-amf" class="mx.messaging.channels.AMFChannel">
                  <endpoint url="http://172.18.3.80:9081/remote/messagebroker/amfpolling" class="flex.messaging.endpoints.AMFEndpoint"/>
                  <properties>
                      <polling-enabled>true</polling-enabled>
                      <polling-interval-seconds>4</polling-interval-seconds>
                  </properties>
              <channel-definition id="my-http" class="mx.messaging.channels.HTTPChannel">
                  <endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/http" class="flex.messaging.endpoints.HTTPEndpoint"/>
              <channel-definition id="my-secure-http" class="mx.messaging.channels.SecureHTTPChannel">
                  <endpoint url="https://{server.name}:{server.port}/{context.root}/messagebroker/httpsecure" class="flex.messaging.endpoints.SecureHTTPEndpoint"/>
                  <properties>
                  </properties>
          </channels>
          <logging>
              <target class="flex.messaging.log.ConsoleTarget" level="Error">
                  <properties>
                      <prefix>[BlazeDS] </prefix>
                      <includeDate>false</includeDate>
                      <includeTime>false</includeTime>
                      <includeLevel>false</includeLevel>
                      <includeCategory>false</includeCategory>
                  </properties>
                  <filters>
                      <pattern>Endpoint.*</pattern>
                      <pattern>Service.*</pattern>
                      <pattern>Configuration</pattern>
                  </filters>
              </target>
          </logging>
          <system>
              <redeploy>
                  <enabled>false</enabled>
                  <watch-interval>20</watch-interval>
                  <watch-file>{context.root}/WEB-INF/flex/services-config.xml</watch-file>
                  <watch-file>{context.root}/WEB-INF/flex/proxy-config.xml</watch-file>
                  <watch-file>{context.root}/WEB-INF/flex/remoting-config.xml</watch-file>
                  <watch-file>{context.root}/WEB-INF/flex/messaging-config.xml</watch-file>
                  <watch-file>{context.root}/WEB-INF/flex/data-management-config.xml</watch-file>
                  <touch-file>{context.root}/WEB-INF/web.xml</touch-file>
              </redeploy>
          </system>
      </services-config>
      please quick response needed..
      thanks in advance
