1. Re: Why is a simple swap image so difficult to do!!!!
Newsgroup_User Jul 11, 2007 2:53 AM (in response to CShockr)I've never tried doing this with Fireworks, but it is very simple with
Dreamweaver.
Peter
_______________________
"MGD/PHO/JOU" <webforumsuser@macromedia.com> wrote in message
news:f71oh4$9b0$1@forums.macromedia.com...
| All I want to do is create a simple rollover or swap image where the start
or
| Up image is an actual picture and the swap or over image is a box with
text
| links to pages in the site contained inside...This was totally simple in
| ImageReady, but seems impossible with Fireworks!!!!
2. Re: Why is a simple swap image so difficult to do!!!!
CShockr Jul 11, 2007 4:09 PM (in response to Newsgroup_User)Ok...so how do you do it.
It works fine if the text box is the initial up state, but if you want to use an image as an upstate there seems to be no way (neither show/hide or rollover etc.) to call the box with links...
The links are what are important here...I've tried importing from Fireworks, cut and paste with Fireworks HTML, using a Dreamweaver image placeholder and exporting the Fireworks image and html code...) -
3. Re: Why is a simple swap image so difficult to do!!!!
Newsgroup_User Jul 11, 2007 5:47 PM (in response to Newsgroup_User)MGD/PHO/JOU wrote:
Have you looked at the FW help Files? This excerpt and much more is
available by typing "rollovers" into the search box of the help window:
Creating a simple rollover
A simple rollover swaps in the frame directly under the top frame and
involves only one slice.
To attach a simple rollover to a slice:
1. Ensure that the trigger object is not on a shared layer. For more
information, see Sharing layers.
2. Select Edit > Insert > Slice to create a slice on top of the trigger
object.
3. Create a new frame in the Frames panel by clicking the New/Duplicate
Frame button.
4. Create, paste, or import an image to use as the swap image on the new
frame.
Position the image beneath the slice you created in step 2, which is
still visible even though you're in Frame 2. Slices are visible across
all frames.
5. Select Frame 1 in the Frames panel to return to the frame that has
the original image.
6. Select the slice and place the pointer over the behavior handle. The
pointer changes to a hand.
7. Click the behavior handle and select Simple Rollover from the menu.
8. Click the Preview tab and test the simple rollover, or press F12 to
preview it in a browser.
You can also use the button editor to create up to 4-state rollovers.
As for Dreamweaver, there are several ways. A simple one is to go to
Insert > Image Objects > Rollover Image. The images must be available in
order to do this.
HTH
Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
Extending Knowledge, Daily
http://www.communityMX.com/
CommunityMX - Free Resources:
http://www.communitymx.com/free.cfm
.:Adobe Community Expert for Fireworks:.
news://forums.macromedia.com/macromedia.fireworks
news://forums.macromedia.com/macromedia.dreamweaver -
4. Re: Why is a simple swap image so difficult to do!!!!
Newsgroup_User Jul 11, 2007 5:49 PM (in response to Newsgroup_User)MGD/PHO/JOU wrote:
It's also helpful if yo can post a link to the file so we can see things
in detail. Removes the guess work. :-)
5. Re: Why is a simple swap image so difficult to do!!!!
Newsgroup_User Jul 11, 2007 10:33 PM (in response to Newsgroup_User)Nowadays, I would use some kind of CSS to do this, but in the past I used
the Dreamweaver method Jim describes.
Peter
___________________
"Jim Babbage .:CMX:. & .:Adobe Community Expert:."
<jbabbage@newmediaservices.ca> wrote in message
news:f73tnm$1uq$1@forums.macromedia.com...
to use
rollover
Fireworks,
and
| object.
| Frame button.
| frame.
| all frames.
| the original image.
| order to do this.
| HTH
6. Re: Why is a simple swap image so difficult to do!!!!
drubinoff Jul 22, 2009 11:17 AM (in response to Newsgroup_User)I'm doing exactly this (I think), and yet nothing happens when I preview in a browser....the cursor changes to a hand over the affected images, but no roll over action happens. I've tried adding the rollover image on another frame, and I've tried pointing it to a jpeg file.
7. Re: Why is a simple swap image so difficult to do!!!!
Jim_Babbage Jul 22, 2009 11:22 AM (in response to drubinoff)They're not hard to do. Draw a slice over the object, put another
object in a second state in the exact same pixel location, and choose
Add Simple Rollover from the Behaviors handle in the slice.
You might be using a hotspot by accident, and that won't generate the
rollover on its own.
HTH
Jim Babbage
8. Re: Why is a simple swap image so difficult to do!!!!
drubinoff Jul 22, 2009 11:35 AM (in response to Jim_Babbage)You were correct: I was using a hotspot instead of a slice. Now that I have a slice, it is working. I think I need to better understand when to use a hotspot versus a slice.
Hugs!
9. Re: Why is a simple swap image so difficult to do!!!!
Jim_Babbage Jul 22, 2009 12:38 PM (in response to drubinoff)Hotspots can be used for image maps, to add additonal interactivity on
an existing slice or to trigger a remote rollover, but in order for
the rollover to work, the area to be swapped must have a slice placed
over it.
HTH
Jim Babbage
