0 Replies Latest reply on Nov 19, 2010 7:26 AM by deepak venkatachalam
    Challenges with Compare Pdf
      Hi Friends
      I am using the following code to compare two versions of pdf in my web application.
      I have the following challenges with it.
      1) I need to suppress the Compare Dialog box that opens on calling DIGSIG:CompareDocuments.
      2)How the output pdf can be shown on the client machine as this is a server code that runs on the server side.Also client machine would not have Acrobat installed on it.
      3)Also how far the output pdf can be customized.Ex,Is there a possiblity to remove the first page of the output pdf.
      Kindly help me out.  Related URLs are welcome
      Thanks in advance. Refer the code below.
      Function
      CompareTwoPdfFiles(ByVal OldFileName As String, ByVal NewFileName As String) As Boolean
      Dim AcrobatApp As Acrobat.CAcroApp
      AcrobatApp = CreateObject(
      "AcroExch.App")
      AcrobatApp.Show()
      Dim OpenPdfCount As Integer
      Dim PDSaveFull As Short
      OpenPdfCount = AcrobatApp.GetNumAVDocs
      Dim DocumentWasOpen As Boolean
      DocumentWasOpen = (OpenPdfCount > 0)
      Dim ok As Boolean
      ok =
      True
      ' Open the "New" file first,
      ' so it appears on the right side in the comparison output.
      Dim NewPd As Acrobat.CAcroPDDoc
      Dim NewAv As Acrobat.CAcroAVDoc
      If ok Then
      NewPd = CreateObject(
      "AcroExch.PDDoc")
      ok = NewPd.Open(NewFileName)
      If ok Then
      NewAv = NewPd.OpenAVDoc(NewFileName)
      Else
      MsgBox(
      "Could not open PDF file: " & NewFileName)
      End If
      End If
      ' Open the "Old" file second,
      ' so it appears on the left side in the comparison output.
      Dim OldPd As Acrobat.CAcroPDDoc
      Dim OldAv As Acrobat.CAcroAVDoc
      If ok Then
      OldPd = CreateObject(
      "AcroExch.PDDoc")
      ok = OldPd.Open(OldFileName)
      If ok Then
      OldAv = OldPd.OpenAVDoc(OldFileName)
      Else
      MsgBox(
      "Could not open PDF file: " & OldFileName)
      End If
      End If
      If ok Then
      ok = AcrobatApp.MenuItemExecute(
      "DIGSIG:CompareDocuments")
      If Not ok Then
      MsgBox(
      "Could not compare files")
      End If
      End If
      Dim NoSave As Boolean
      NoSave =
      True
      If ok Then
      Dim DiffAv As Acrobat.CAcroAVDoc
      DiffAv = AcrobatApp.GetActiveDoc
      Dim DiffPd As Acrobat.CAcroPDDoc
      DiffPd = DiffAv.GetPDDoc
      ok = DiffPd.Save(PDSaveFull,
      "C:\Deepak\TED Pdfs\Comparison.pdf")
      If Not ok Then
      MsgBox(
      "Could not save comparison output file")
      End If
      End If
      CompareTwoPdfFiles = ok
      End Function
      Regards
      Deepak.
