0 Replies Latest reply on Nov 19, 2010 9:02 AM by Brian Russel Davis
    Problems with ActionScript Proxy for ColdFusion I/O Errors in Sample and Invoke Errors
    Brian Russel Davis
      Hello!
      I am going to try to be as explict as possible ( hopefully this gets some traction in Google so others who run into the same error will benefit )
      I am trying to use the ActionScript Proxy for ColdFusion : http://help.adobe.com/en_US/ColdFusion/9.0/Developing/WS45F7E41F-825B-4fcd-B96D-D5B7E2107E 7E.html .  In particular the <cf:Pdf/> tag ( PDF (cfpdf) )
      Here is my code:
         xmlns:mx="library://ns.adobe.com/flex/mx"
         xmlns:cf="coldfusion.service.mxml.*"
         minWidth="955" minHeight="600" applicationComplete="application1_applicationCompleteHandler(event)">
      <fx:Script>
      <![CDATA[
      import coldfusion.service.events.ColdFusionServiceFaultEvent;
      import coldfusion.service.events.ColdFusionServiceResultEvent;
      import mx.events.FlexEvent;
      protected function pdf1_faultHandler(event:ColdFusionServiceFaultEvent):void
      // TODO Auto-generated method stub
      trace(event)
      protected function pdf1_resultHandler(event:ColdFusionServiceResultEvent):void
      trace(event)
      protected function application1_applicationCompleteHandler(event:FlexEvent):void
      pdfGetInfoTest.execute();
      </fx:Script>
      <fx:Declarations>
      <cf:Config servicePassword="service" serviceUserName="service" cfPort="8500" cfServer="localHost"/>
      <cf:Pdf id="pdfGetInfoTest" action="GETINFO" fault="pdf1_faultHandler(event)" result="pdf1_resultHandler(event)" source="my_pdf.pdf"/>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      </s:Application>
      The "my_pdf.pdf" is right beside the code.
      The user "service" has been given all the right permissions in the CF Admin Panel.
      The IP addresses : 127.0.0.0, *.*.*.* and 0:0:0:0:0:0:0:1 have been set as allowed IP's in CF Admin.
      In both Security>Administrator and Security>RDS has been selected.
      I have rebooted the CF Server.
      But still I get this error:
      [FaultEvent fault=[RPC Fault faultString="User service is not authorized to invoke pdf service from 0:0:0:0:0:0:0:1%0." faultCode="Server.Processing" faultDetail="null"] messageId="5BC1B3D0-0108-DF05-442F-3EDFCB13048C" type="fault" bubbles=false cancelable=true eventPhase=2]
      If I add this to allowed IPS's : 0:0:0:0:0:0:0:*
      I then get this error:
      [FaultEvent fault=[RPC Fault faultString="Could not read file from URL my_pdf.pdf" faultCode="Server.Processing" faultDetail="null"] messageId="62AE7923-9F08-E46F-46C8-EB01C4E8E5D7" type="fault" bubbles=false cancelable=true eventPhase=2]
      So then I have to specify the ABSOLUTE path to the pdf in the source tag: <cf:Pdf id="pdfGetInfoTest" action="GETINFO" fault="pdf1_faultHandler(event)" result="pdf1_resultHandler(event)" source="http://localhost:8500/TestPDF-debug/my_pdf.pdf"/>
      Then ( thank you big baby jesus! ) I get rid of errors!  And I get a normal trace action:
      (mx.messaging.messages::AcknowledgeMessage)#0
        body = (Object)#1
          application = "Adobe Acrobat 9.4"
          author = ""
          centerWindowOnScreen = ""
          changingDocument = "Allowed"
          commenting = "Allowed"
          contentExtraction = "Allowed"
          copyContent = "Allowed"
          created = "D:20101119083823-08'00'"
          documentAssembly = "Allowed"
          encryption = "No Security"
          filePath = "/Applications/ColdFusion9/tmpCache/CFFileServlet/_cfservicelayer/_cf-4138005669036998691 .pdf"
          fillingForm = "Allowed"
          fitToWindow = ""
          hideMenubar = ""
          hideToolbar = ""
          hideWindowUI = ""
          keywords = ""
          language = ""
          modified = "D:20101119084020-08'00'"
          pageLayout = "SinglePage"
          pageSizes = (Array)#2
            [0] (Object)#3
              height = 435
              rotation = 0
              width = 525
          printing = "Allowed"
          producer = "Adobe Acrobat 9.4 Image Conversion Plug-in"
          properties = "[]"
          secure = "Allowed"
          showDocumentsOption = ""
          showWindowsOption = ""
          signing = "Allowed"
          subject = ""
          title = ""
          totalPages = 1
          trapped = ""
          version = "1.6"
        clientId = "62C45809-7E0F-9B72-790D-640A530A04FA"
        correlationId = "373D4D96-BC39-5734-9326-65136425B3D2"
        destination = (null)
        headers = (Object)#4
        messageId = "62C4581F-770E-F9B4-E0E7-C0E72A4D6BD4"
        timestamp = 1290185958503
        timeToLive = 0
      But will someone, somewhere explain WHY have to add this strange IP address and what that means AND WHY the source can't be a relative path if "my_pdf.pdf" is RIGHT THERE next to the SWF.  Seems like a lot of pain to get something that is supposed to be a time saver to work??
      Brian Russel Davis
      "Giving it to you raw in 1's and 0's"
      brian@brianrusseldavis.com | brian@nurdymuny.com
