3 Replies Latest reply on Nov 20, 2010 7:22 AM by shredderPi
    Multiple fields from array in one colum
    shredderPi
      hi there,
      have started working in Flex 4 and quite enjoying it, I'm a designer with years of background in HTML-CSS and decided to shift to Flex.
      While testing on a DataGrid with an ArrayCollection as a data provider, I have a firstName and LastName item in my array, is it possible to display it as one column in my DataGrid, what I did to display just both item from the array is
      <mx:DataGridColumn headerText="Name" dataField="firstName" />
      <mx:DataGridColumn headerText="Name" dataField="lastName" />
      my Array is defined in the Script block..
      would appreciate any help from you guys!
        • 1. Re: Multiple fields from array in one colum
          Peter deHaan Level 4
          Create a custom label function which returns a concatenated firstName and lastName:
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
              <mx:Script>
                  <![CDATA[
                      protected function displayFullName(item:Object, col:DataGridColumn):String {
                          return item.firstName + " " + item.lastName;
              </mx:Script>
              <mx:DataGrid>
                  <mx:columns>
                      <mx:DataGridColumn dataField="firstName" />
                      <mx:DataGridColumn dataField="lastName" />
                      <mx:DataGridColumn labelFunction="displayFullName" headerText="full name" />
                  </mx:columns>
                  <mx:dataProvider>
                      <mx:ArrayCollection>
                          <mx:Object firstName="Xander" lastName="Crews" />
                          <mx:Object firstName="Wendell" lastName="Stamps" />
                          <mx:Object firstName="Grace" lastName="Ryan" />
                          <mx:Object firstName="Arthur" lastName="Watley" />
                      </mx:ArrayCollection>
                  </mx:dataProvider>
              </mx:DataGrid>
          </mx:Application>
          Peter
          • 2. Re: Multiple fields from array in one colum
            Flex harUI Adobe Employee
            Use a labelFunction
            • 3. Re: Multiple fields from array in one colum
              shredderPi Level 1
              wow, thanks very much that was quick, I was reading a book while working through some samples and already came accross labelFunction,
              understood it clearly from your sample..
              thanks big!
