13 Replies Latest reply on Dec 17, 2010 3:37 PM by hhansard
    Jerky F4V playback in IE -- Firefox seems OK.
    hhansard Level 1
      Seen multiple threads for “jerky playback in flash”, but nothing posted seems to help.
      I’ve tried in the Flash forum, but No Joy.
      6 different videos – all with same results all using Adobe presets.
      Using the F4v/FLV .5 Mbs export preset from PP to media encoder
      All F4V/FLV exports show “jerky” playback in flash/IE, but fine in FireFox  (so sounds like a Flash player or IE issue –right, but this is one of the largest combos on the net, so I figure someone has gotten this to work).
      Audio is OK.
      Same behavior on 2 different systems (Win7 x64 with lots of RAM and good CPU)
      Systems all have latest updates, etc, etc. CPU/memory is low usage.
      Hardware and systems are high-end and well-tuned.
      Using VBR 1pass and CBR target in the 0.50 Mbs range.
      Have used a variety of export presets in the 0.4 to 1.5 Mbs – all with same results.  So my test set exceeds 20 exports – all with identical behavior.
      Internet connection is 20Mbs to desktop.
      Locally-hosted F4Vs play OK.
      Hosted MOVs are downloaded and play very well.
      Same behavior on 2 separate hosted ISPs for all videos.  Non-dedicated flash servers.
      Uninstalled/reinstalled Flash.  Hardware acceleration on/off, AVP on/off, etc.
      Any suggestions?
      If folks are having success with flash, can you provide export settings in the 0.5 to 1.x Mbs range that work for you?
      Since I have seen lots of “jerky” playback posts associated with Flash, is this some sort of “known issue”?
      PP CS5, latest AME, latest Flash 10.x
      Thanks, H
        • 1. Re: Jerky F4V playback in IE -- Firefox seems OK.
          hhansard Level 1
          I have updated this post with more detailed information to hopefully get some help.
          I have read multiple posts/threads on “jerky playback in flash”, but nothing posted seems to help my situation.  I have tried in the Flash and PP forums, but to date no responses.
          6 different videos – all Encoded with AME and produce the same results all using the Adobe F4V (h.264 Flash) presets from PP.
          Started with the F4V/Web presets (same as source at 29.97), and then adjusted the output size to reduce Mbps until I got something to work.  Tried all settings from about 1.5Mbps down to about 0.4 Mbps, but all showed the same result.
          All AME encodes show “jerky” playback in flash/IE, but smooth in FireFox.  Audio is OK
          The video plays smoothly for a second, then shudders for about 3 frames, then smooth, then shudders, etc.
          Local playback on AMP looks fine, this bypasses the browser completely, so not really a valid test.  I have attached a MediaInfo for a sample encode below.  The HTTP code for playback is generated by DW and very simple, so I doubt it is that.
          Same behavior on 2 different systems (Win7 x64).  Systems have latest updates, etc, etc. Hardware and systems are high-end and well-tuned.  CPU never exceeds 5% and memory never above 10%.
          Have used a variety of export presets in the 0.4 to 1.5 Mbps – all with same results.  So my test set exceeds 20 exports – all with identical behavior.
          Tried VBR 1pass and CBR.
          Same behavior on 2 separate hosted ISPs and local playback. All with identical behavior, but local playback is less pronounced.  Dedicated UNIX servers with high-speed connections, but not flash servers. Internet connection is 50+Mbps to desktop – but again, local playback also shows the shuttering behavior, just not as much.
          It sounds like a Flash player or IE issue, but this is one of the largest combos on the net today, so I figure someone has gotten this to work using AME.
          Since I have seen so many “jerky” playback posts associated with Flash, is this some sort of “known issue”?  I know that millions use h.264/Flash and IE daily, so I must be doing something wrong.  I realize the difference between IE and Mozilla Flash, but I can’t reconcile what I am seeing to just IE.  This is not a minor playback difference, but dramatic on 2 well-tuned systems.
          PP CS5, latest AME, latest Flash 10.x, etc
          Does anyone have examples of h.264 Flash output that hosts OK in the 512x288 to 786x432 range on IE? Can you provide link to output and settings that got you there.
          Thanks, H
          General
          Complete name                    : T:\VIDEO_Project_Exports\F4V432\Gaskin.f4v
          Format                           : MPEG-4
          Format profile                   : Adobe Flash
          Codec ID                         : f4v
          File size                        : 23.5 MiB
          Duration                         : 3mn 30s
          Overall bit rate                 : 934 Kbps
          Encoded date                     : UTC 2010-11-20 15:52:46
          Tagged date                      : UTC 2010-11-20 15:52:46
          ©TIM                             : 00;00;00;00
          ©TSC                             : 30000
          ©TSZ                             : 1001
          Video
          Format                           : AVC
          Format/Info                      : Advanced Video Codec
          Format profile                   : Main@L4.1
          Format settings, CABAC           : Yes
          Format settings, ReFrames        : 3 frames
          Codec ID                         : avc1
          Codec ID/Info                    : Advanced Video Coding
          Duration                         : 3mn 30s
          Bit rate mode                    : Constant
          Bit rate                         : 850 Kbps
          Width                            : 768 pixels
          Height                           : 432 pixels
          Display aspect ratio             : 16:9
          Frame rate mode                  : Constant
          Frame rate                       : 29.970 fps
          Standard                         : NTSC
          Color space                      : YUV
          Chroma subsampling               : 4:2:0
          Bit depth                        : 8 bits
          Scan type                        : Progressive
          Bits/(Pixel*Frame)               : 0.085
          Stream size                      : 22.0 MiB (94%)
          Title                            : MainConcept
          Language                         : English
          Audio
          Format                           : AAC
          Format/Info                      : Advanced Audio Codec
          Format version                   : Version 4
          Format profile                   : LC
          Codec ID                         : 40
          Duration                         : 3mn 30s
          Bit rate                         : 48.0 Kbps
          Channel(s)                       : 2 channels
          Channel positions                : Front: L R
          Sampling rate                    : 22.05 KHz
          Stream size                      : 1.21 MiB (5%)
          Language                         : English
          Preset
          Output: 762x432, same as source fps, de-interlaced, AAC+ Version 2, 48kps, 44.1kHz, Stereo, CBR, Target 0.85Mbs
          Source: Sequence, Gaskin_HDV, 1440x1080(1.333), 29.97fps, Upper, 0;03;19, 48000Hz, Stereo
          • 2. Re: Jerky F4V playback in IE -- Firefox seems OK.
            Jim_Simon Level 8
            Well, which is it?
            Post a link so others can test it on their systems.
            • 3. Re: Jerky F4V playback in IE -- Firefox seems OK.
              hhansard Level 1
              Thanks for looking, sorry about the confusion.  I though the the local playback was fine, but i realized i was comparing
              apples to oranges (1.5mbs -v- 0.3 mbs) a couple of hours later.
              local playback is also jerky, but less obvious than hosted.
              here is the link.
              http://www.hansard.org/video_gaskin.htm
              all advice very welcome.
              Thanks, H
              • 4. Re: Jerky F4V playback in IE -- Firefox seems OK.
                hhansard Level 1
                Updated with more test results.
                Testing repeated on 2 XP/SP3 systems running both IE and FireFox.  Both additional systems show identical results with six different encoded videos as outlined in previous post.
                • 5. Re: Jerky F4V playback in IE -- Firefox seems OK.
                  Stan Jones Adobe Community Professional & MVP
                  Tried on a WinXP SP3, IE 7, Firefox 3.6.11.  A jerky (I might call it "pulsing") appearance was more apparent on IE, but there were significant pauses every 5 to 20 seconds on both.
                  Ran speedtest on my system: 5.91 Megabits.
                  • 6. Re: Jerky F4V playback in IE -- Firefox seems OK.
                    hhansard Level 1
                    Interesting, my speedtedt is between 30 and 50+.  I see problems in IE, but not in FireFox.  I think there are utilities to choke the pipe.  I'll give it a try to achieve a level to choke firefox as well.
                    Do you encode h.264 flash for remote hosting?  if you get good results, what settings do you you use?
                    • 7. Re: Jerky F4V playback in IE -- Firefox seems OK.
                      Jim_Simon Level 8
                      I got smooth playback using the nightly build of Minefield (4.0b8Pre), but jerky playback on IE 8.
                      Playback of other web sites is fine on IE8, however.  I wonder if the embeded player is making a difference here.
                      • 8. Re: Jerky F4V playback in IE -- Firefox seems OK.
                        hhansard Level 1
                        Thanks for taking a look.
                        The embedded player code in the html is the FLVPlayer_Progressive.swf that is included as part of Dreamweaver.  The code is inserted in the HTML when you insert the video. I "assume" most folks deploying with an Adobe-centric solution are using identical code.
                        I'll do some research to see if there are other players.
                        When you say you looked at other sites that look OK, can you give me a link or to so that I can eliminate anything local on my side.
                        Again, thanks for taking a look.
                        H
                        • 9. Re: Jerky F4V playback in IE -- Firefox seems OK.
                          hhansard Level 1
                          Found the answer.  The player provided by Adobe with Dreamweaver is dog-awful-slow in IE and only a little better in FireFox.  By switching to FLV Player, the problem disappears completely.
                          I posted this help request in 4 forums and received only 1 response that was a “hunch”.  It put me on the right path.  Thanks.
                          H
                          • 11. Re: Jerky F4V playback in IE -- Firefox seems OK.
                            Eizenn
                            Wow....I was cracking my head with this one...
                            Mostly on trying to find an answer using google because searching for slow flv playback on IE comes back with so much stuff that isn't related.
                            Until I searced adobe media encoder that is...
                            So I too was having this problem of only IE playing back my FLV's slow while firefox, safari and chrome played it perfectly fine! That made me try different encoding options and such. My next step was to use another flv player. I was going to do it yesterday but now I found this post.
                            Care to share what other player you used instead of the one provided with Dreamweaver?
                            Is there an update to dreamweaver that resolves this? I think the problem is both in CS4 and CS5.
                            Thanks!
                            • 12. Re: Jerky F4V playback in IE -- Firefox seems OK.
                              Jim_Simon Level 8
                              Since it works fine in other browsers, it may be IE that needs the update.
                              • 13. Re: Jerky F4V playback in IE -- Firefox seems OK.
                                hhansard Level 1
                                By switching to a third-party player, the problem disappears completely.
                                There are a number of third-party players on the market.
                                I ended-up with WEBstunning.
