1 Reply Latest reply on Apr 13, 2011 3:23 AM by txetxuda
    Indesign Server CS5 crashes at launch
    jerpeters
      Indesign Server 7.03 on OSX 10.5.8 Intel Xserve.
      When Indesign server CS5 is launched at boot (or with launchctl) it crashes with the following errror in the system log:
      Nov 20 13:32:00 ams1ps01 com.adobe.ids.launchd.8888[799]: /Applications/Adobe InDesign CS5 Server/InDesignServer: line 13:   801 Trace/BPT trap          "$installed_name" "$@"
      Nov 20 13:32:00 ams1ps01 com.apple.launchd[1] (com.adobe.ids.launchd.8888[799]): Exited with exit code: 133
      Nov 20 13:32:00 ams1ps01 com.apple.launchd[1] (com.adobe.ids.launchd.8888): Throttling respawn: Will start in 3 seconds
      Nov 20 13:32:03 ams1ps01 InDesignServer[806]: 3891612: (connectAndCheck) Untrusted apps are not allowed to connect to or launch Window Server before login.
      Nov 20 13:32:03 ams1ps01 com.adobe.ids.launchd.8888[804]: Sat Nov 20 13:32:03 ams1ps01 InDesignServer[806] <Warning>: 3891612: (connectAndCheck) Untrusted apps are not allowed to connect to or launch Window Server before login.
      Nov 20 13:32:03 ams1ps01 com.adobe.ids.launchd.8888[804]: ================================================================================
      Nov 20 13:32:03 ams1ps01 com.adobe.ids.launchd.8888[804]: .  InDesign CS5 Server Version 7.0
      Nov 20 13:32:03 ams1ps01 com.adobe.ids.launchd.8888[804]: .  Copyright 1999-2010 Adobe Systems Incorporated and its licensors.
      Nov 20 13:32:03 ams1ps01 com.adobe.ids.launchd.8888[804]: .  All rights reserved. See the other legal notices in the ReadMe.
      Nov 20 13:32:04 ams1ps01 InDesignServer[806]: _RegisterApplication(), FAILED TO establish the default connection to the WindowServer, _CGSDefaultConnection() is NULL.
      Nov 20 13:32:04 ams1ps01 com.adobe.ids.launchd.8888[804]: _RegisterApplication(), FAILED TO establish the default connection to the WindowServer, _CGSDefaultConnection() is NULL.
      Nov 20 13:32:05 ams1ps01 kernel[0]: unknown SIGSEGV code 0
      Nov 20 13:32:05: --- last message repeated 1 time ---
      Nov 20 13:32:05 ams1ps01 InDesignServer[806]: [soap] Servicing SOAP requests on port 8888 [8888]
      Nov 20 13:32:07 ams1ps01 InDesignServer[806]: An uncaught exception was raised
      Nov 20 13:32:07 ams1ps01 com.adobe.ids.launchd.8888[804]: 2010-11-20 13:32:07.705 InDesignServer[806:10b] An uncaught exception was raised
      Nov 20 13:32:07 ams1ps01 InDesignServer[806]: Error (1002) creating CGSWindow
      Nov 20 13:32:07 ams1ps01 com.adobe.ids.launchd.8888[804]: 2010-11-20 13:32:07.706 InDesignServer[806:10b] Error (1002) creating CGSWindow
      Nov 20 13:32:07 ams1ps01 InDesignServer[806]: *** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'Error (1002) creating CGSWindow'
      Nov 20 13:32:07 ams1ps01 com.adobe.ids.launchd.8888[804]: 2010-11-20 13:32:07.706 InDesignServer[806:10b] *** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'Error (1002) creating CGSWindow'
      When launched while logged on, it launches ok.
      Here's the content of the plist file used to launch ID Server:
      <?xml version="1.0" encoding="UTF-8"?>
      <!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"
      <plist version="1.0"> <dict>
      <key>Label</key>
      <string>com.adobe.ids.launchd.8888</string>
      <key>OnDemand</key>
      <false/>
      <key>ProgramArguments</key>
      <array>
      <string>/Applications/Adobe InDesign CS5 Server/InDesignServer</string>
      <string>-port</string>
      <string>8888</string>
      <string>-LogToApplicationEventLog</string>
      </array>
      <key>RunAtLoad</key>
      <true/>
      </dict>
      </plist>
      Please advice.
      Regards,
      Jeroen Peters
