2 Replies Latest reply on Nov 20, 2010 4:23 PM by John Hall
    pendUntilComplete not recognized
    John Hall Level 4
      I posted this to development forum, meant to post it here:
      I'm working through the sequencing example at
      http://docs.flexunit.org/index.php?title=Fluint_Sequences but regardless of what I import, pendUntilComplete in the following method shows as undefined.
      [Before( async, ui )]
              public function setUp() : void {
                  form = new LoginForm();
                  form.addEventListener( FlexEvent.CREATION_COMPLETE, Async.asyncHandler( pendUntilComplete, 100 ), false, 0, true );
                  UIImpersonator.addChild( form );
      Do I have an misspelling that I'm not catching?  My imports currently are:
              import flash.events.Event;
              import flash.events.TextEvent;
              import flash.events.MouseEvent;
              import mx.events.FlexEvent;
              import org.flexunit.asserts.assertEquals;
              import org.flexunit.async.Async;
              import sampleSuite.tests.mxml.LoginForm;
              import org.fluint.sequence.*;
      And it sounded like it should be in  the Async package.
        • 1. Re: pendUntilComplete not recognized
          mlabriola Level 4
          John,
          To get through, put a function in your test for now that reads:
          public function pendUntilComplete( event:Event, passThroughData:Object=null ):void {
          In older version of Fluint you extended a class which had this method. You no longer have to extend a class so this method is not there. Whomever moved that doc over from the old site did not fix that part of it. I will try to get that fixed and a better long term explanation for you on what to do on this, but I had just a moment right now so wanted to at least give you information which would keep you going.
          Mike
          • 2. Re: pendUntilComplete not recognized
            John Hall Level 4
            Thanks Mike.
