1 Reply Latest reply on Oct 13, 2006 10:05 AM by Newsgroup_User
    disjointed rollover
    cm12 Level 1
      i have one image that when i roll my mouse over it i want it to change as well as two other images. i can make the behavior commands but the problem is that only one of the images will change back to its orginial state when i move the mouse off the image. The others stay in the changed state. obviously this has something to do with the swap image back command but i cant figure out to get it right. can anyone help me.
      thanks abunch caleb
        • 1. Re: disjointed rollover
          Level 7
          Select the trigger image in DW. Apply the swap image behavior. In the
          behavior dialog, select the first image to rollover, and browse to and
          select the incoming image. Then without closing the panel, find and select
          the next image to rollover, and browse to and select the incoming image.
          Enable the automtic restore. You're done.
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "cm12" <webforumsuser@macromedia.com> wrote in message
          news:egognr$ahr$1@forums.macromedia.com...
          >well
          > that
          > the
          > this has
          > get
          > thanks abunch caleb
