1 Reply Latest reply on Nov 22, 2010 3:37 AM by c.pfaffenbichler
    I could use a pointer in the right direction.
    EDDKBAWILLIAMS
      I've got a script that performs a certain number of tasks to the currently selected layer... Works perfectly... What I would like to do is expand on this script and have it perform the same tasks on every single visible layer in the document.
      Sadly I don't know much of anything about scripting. Any chance I could get someone to point me in the right direction? I would be happy to pay someone to write a little script that would either process every single layer, every visible layer or every named layer and run a particular script.
      So I imagine it would be something at the top of the script like this.
      NamedLayer="TESTSample"
      RunScript="NameofScripttoRun"
      ProcessEveryLayer=False
      ProcessEveryVisibleLayer=True
      ProcessEveryNamedLayer=False
      So I can manually type in the Name of the Script to be run. If I were to set the ProcessEveryNamedLayer to True then I could also specify the name of the layer with the NamedLayer= option. I would then set the other two layer options to false.
      Any takers?
      Steve Williams
        • 1. Re: I could use a pointer in the right direction.
          c.pfaffenbichler Level 9
          You could use a function like this to collect the layers:
          var theLayers = collectLayers(app.activeDocument);
          ////// function collect all layers //////
          function collectLayers (theParent) {
          if (!allLayers) {
          var allLayers = new Array}
          else {};
          for (var m = theParent.layers.length - 1; m >= 0;m--) {
          var theLayer = theParent.layers[m];
          // apply the function to layersets;
          if (theLayer.typename == "ArtLayer") {
          allLayers.push(theLayer)
          else {
          allLayers = allLayers.concat(collectLayers(theLayer))
          // this line includes the layer groups;
          allLayers.push(theLayer);
          return allLayers
          Then have a for-operation work through the layers-array.
          for (var m = 0; m < theLayers.length; m++) {
          app.activeDocument.activeLayer = theLayers[m];
          But depending on the operation you may not want to work through all Layers, but only through, for example, pixel layers.
          So you could adapt the collectLayers-function to only return layers that fit certain criteria, which you could put into an additional if-clause.
