1. Re: Effect "string" parameter...
shachar carmi Nov 21, 2010 10:16 AM (in response to david van brink)hello david.
the reason you didn't find such a param is because there is none.
what you see in effects like "basic text" is actually an os level window with standard text controls.
most effects that do that use the "options" button (which can be renamed), to launch the os level window.
you can also create a param with a custom UI to which AE will send you mouse click events, from which you could launch that window.
another solution would be to create a param with a custom UI, which you can get to act like a string input param (not going to be easy).
the last solution i can think of is to use either the "options" button or a custom param UI to launch a java script (AEGP_ExecuteScript), which will in turn, launch a window with a text control.
for a simple task like you describe, that might be the easiest way.
2. Re: Effect "string" parameter...
david van brink Nov 21, 2010 10:39 AM (in response to shachar carmi)Hi Shachar --
Thanks for the notes. (I didn't know about the third option, running JS from a plugin. Interesting.)
I'll be going with one of the first two.
Notice that Text Layers really do have a first-class string parameter in them, expressions and all. Maybe PF_ParamtypeString, someday.
/d
