6 Replies Latest reply on Nov 22, 2010 11:22 AM by kglad
    Time event question
    gaminflash Level 1
      Hi, after watching the thread:
      Repeat function after x seconds?
      I have a question about the time event, can you make something disabled for an amount of seconds too? For an example: you have a variable that you want to go "false;" if you click "Right" or something, and after a second or so the variable go "true;" again. What i actually want to achieve here is that during an animation a variable makes you disable so you can't for an example play the "attack" animation while the "walk" animation is on.
        • 1. Re: Time event question
          yes, you can use setTimeout() to delay a call to any function:
          var bool:Boolean=false;
          setTimeout(resetF,3000);
          funciton resetF(){
          bool=true;
          • 2. Re: Time event question
            If it is a one shot deal, then you can use setTimeout().  When you click whatever intiates setting whatever variable to be false, also initiate a setTimeout(someFunction, 1000); call so that in one second someFunction is called and sets the value true again.
            • 3. Re: Time event question
              gaminflash Level 1
              Sorry but i dont really get it, i tried this in the movieclip:
              onClipEvent(load){
              moveable = true;
              speed = 3;
              onClipEvent(enterFrame){
              if(Key.isDown(Key.UP)){
              moveable = false;
              if(Key.isDown(Key.LEFT) && moveable == true;){
              this._x -= speed;
              and in the frame:
              if(var moveable:Boolean=false){
              setTimeout(resetF,1000);
              function resetF(){
              moveable=true;
              What did i do wrong :S?
              • 4. Re: Time event question
                those two code snippets are in different scopes.
                remove the code from your movieclip and attach it to a frame.  there's never a reason to attach code to an object and there are many reasons to avoid doing that.
                your_mc.speed=3;
                your_mc.moveable=true;
                your_mc.onEnterFrame=function(){
                this.moveable = false;
                setTimeout(resetF,1000,this);
                if(Key.isDown(Key.LEFT) && this.moveable){
                this._x -= speed;
                function resetF(mc:MovieClip){
                mc.moveable=true;
                • 5. Re: Time event question
                  gaminflash Level 1
                  Thank you very much! You solved the problem. There were only a few things in the script that i changed, as you can see in the clear script here:
                  speed=3;
                  moveable=true;
                  a.onEnterFrame=function(){
                  moveable = false;
                  setTimeout(resetF,1000,moveable);
                  if(Key.isDown(Key.LEFT) && moveable == true){
                  this._x -= speed;
                  function resetF(a:MovieClip){
                  moveable=true;
                  P.S the movieclip is "a"
                  • 6. Re: Time event question
                    you're welcome.
