15 Replies Latest reply on Nov 24, 2010 2:17 AM by Mylenium
    After Effects will not register any sound files.
    Audard_1
      Problem - When ever i bring a sound file or any file that contains sound into AE, the sound is non existent.
      Below is a link to a image so you can see what i mean
      http://i67.photobucket.com/albums/h310/Audard/no_sound.png
      As you can see, the wave file has no option to mute the file. I can not use the drop down arrow to view the wave length since the file is empty.
      History - Just recently the computer i work on at my workplace was hit with a trojan and we had to do a reformat and install everything again.
      Prior to this i had been working on numerous projects that ranged fro 15 secs to 2 mins.
      All of these projects used .wav files for sound and in some cases a .mov was present in which i would simply hide the video and have the sound running.
      I have tried using every sound or mov file that i had used in the past for projects that worked but the same result keeps appearing.
      PC specs -
      Intel Core 2 Duo
      E8400 @ 3.00 ghz
      3.00ghz, 3.25 gb RAM
      Windows XP Pro Service Pack 3
      After Effects CS4
      Updated : I opened a old project that had a .mov with sound in it and the sound icon was their to mute the .mov.
      When i tried to ram preview the following error came up.
      After Effects Debug Event
      After Effects has encountered an error
      [..\..\Src\Component\AudioComponentImpl.cpp-92]
