Expand my Community achievements bar.
SOLVED
How to set sub-form to be visible or invisible.
Avatar
Level 3
Dear All.
I'd like to set sub-form which is consisted of drop-down button to be invisible.
when this function is proceeded, the layout of drop-down button is still remained.
Please refer to followings.
-------------------------------------------------------- Code --------------------------------------------------------
setPresence(extPath.Result2_MVS, "invisible");
function setPresence(obj, block){
obj.presence = block;
- in case of visible.
- in case of invisible.
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
Try making it hidden instead of invisible.
Paul
View solution in original post
Avatar
Correct answer by
Paul
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
