8 Replies Latest reply on Nov 23, 2010 1:30 AM by tansk02
    My Function is not working (Please help)
    tansk02 Level 1
      var myDialog = new Window('dialog',"MyTool");
      buildWindow();
      myDialog.show();
      function buildWindow(){
      myDialog.alignChildren = "left";
      // Properties for myReportFolder
      myDialog.preferredSize.width=300
      var myReportFolder=myDialog.add('panel',undefined,"Choose folder to save report:", {borderStyle:'raised'});
      myReportFolder.orientation="row"
      // Properties for mySelectedFolder
      // var mySelectedFolder = myReportFolder.add('group',undefined);
      // Properties for mySelectedPath
      var mySelectedPath = myReportFolder.add('edittext',undefined,"~/Report path");
      mySelectedPath.preferredSize.width = 275;
      // Properties for myBrowseFolder
      var myBrowseFolder = myReportFolder.add('button',undefined,"Choose");
      myBrowseFolder.onClick = function ()
      var myfilePath=Folder.selectDialog ("Choose a Report Folder");
      if(myfilePath != null)mySelectedPath.text=myfilePath.fsName;
      var myPanel1 = myDialog.add('statictext',undefined,"Select Document Language:");
      var theLanguages = app.languagesWithVendors.everyItem().name;
      // Properties for myPanel1.dropDownList
      var dropDownList = myDialog.add('dropdownlist',undefined,undefined,{items:theLanguages}) ;
      dropDownList.selection = 1;
      // Properties for myChoice
      var myChoice = myDialog.add('panel',undefined,"Select your option", {borderStyle:'raised'});
      myChoice.alignChildren = "left";
      // Properties for searchDoubleSpace
      // Properties for searchWrongLanguage
      var searchWrongLanguage = myChoice.add('checkbox',undefined,"Find Languages other than above selected Language");
      searchWrongLanguage.value = false;
      var searchDoubleSpace = myChoice.add('checkbox',undefined,"Find Double Spaces");
      searchDoubleSpace.value = false;
      var unusedParaStyle = myChoice.add('checkbox',undefined,"Find Unused Paragraph Styles");
      unusedParaStyle.value = false;
      var myBleed = myChoice.add('checkbox',undefined,"Check Bleed Value");
      myBleed.value = false;
      // Properties for myDialog.myPanel3
      var myPanel4= myDialog.add('panel',undefined,undefined, {borderStyle:'raised'});
      // Properties for myPanel4.closeButton
      myPanel4.orientation="row"
      myPanel4.closeButton = myPanel4.add('button',undefined,"Close",{name:'cancel'});//tan:add name cancel
      // Properties for myPanel4.goButton
      myPanel4.goButton = myPanel4.add('button',undefined,"RUN",{name:'ok'});//tan: add name ok
      myPanel4.goButton.onClick = function (){
      //Bleed
      var myDocName=app.activeDocument.name;
      var myFilePath1=mySelectedPath.text + "/" + myDocName + ".txt";
      var myTextFile = new File(myFilePath1);
      if ( myTextFile.exists )
      myTextFile.remove(myTextFile);
      flag=false;
      if (myBleed.value == true){//running succesfully
      myDoc=app.activeDocument.documentPreferences
      if ((myDoc.documentBleedTopOffset)!=9){
      write("Document TOP Bleed is not correct "+myDoc.documentBleedTopOffset);
      if ((myDoc.documentBleedBottomOffset)!=9){
      write("Document BOTTOM Bleed is not correct "+myDoc.documentBleedBottomOffset);
      if ((myDoc.documentBleedInsideOrLeftOffset)!=9){
      write("Document INSIDE/LEFT Bleed is not correct "+myDoc.documentBleedInsideOrLeftOffset);
      if ((myDoc.documentBleedOutsideOrRightOffset)!=9){
      write("Document OUTSIDE/RIGHT Bleed is not correct "+myDoc.documentBleedOutsideOrRightOffset);
      }//close if
      //Unused Paragraph style
      if (unusedParaStyle.value == true){
      var myParStyles = myDoc.paragraphStyles;
      for (j = myParStyles.length-1; j >= 2; j-- ) {
      removeUnusedParaStyle(myParStyles[j]);
      function removeUnusedParaStyle(myPaStyle) {
      app.findTextPreferences = NothingEnum.nothing;
      app.changeTextPreferences = NothingEnum.nothing;
      app.findTextPreferences.appliedParagraphStyle = myPaStyle;
      var myFoundStyles = myDoc.findText();
      if (myFoundStyles == 0) {
      write(myPaStyle.name);
      }//close if
      //Search for Double Spaces
      if (searchDoubleSpace.value == true){
      app.findGrepPreferences = NothingEnum.nothing;
      app.changeGrepPreferences = NothingEnum.nothing;
      app.findGrepPreferences.findWhat = " ";
      var result = Number(app.activeDocument.findGrep().length);
      if (result>=1){
      write("Double space found in this document " + result);
      }//close if
      //Search for Wrong Language
      if (searchWrongLanguage.value == true){
      //working
      langList = [];
      for (s=0; s<app.activeDocument.stories.length; s++)
      tr = app.activeDocument.stories[s].textStyleRanges;
      for (t=0; t<tr.length; t++)
      if (!inArray (langList, tr[t].appliedLanguage.name))
      langList.push (tr[t].appliedLanguage.name);
      write ("Number of languages: "+langList.length+"\r(And they are: "+langList.join(", ")+")");
      function inArray (arr, items)
      var check;
      for (check=0; check<arr.length; check++)
      if (arr[check] == items)
      return true;
      return false;
      }//close if
      else (searchWrongLanguage.value == false){
      }//close else if
      }//close onClick function
      }//end buildWindow
      //*****Browse Report Folder and Writing file
      function write(text){
      var myDocument=app.activeDocument;
      var myFilePath1=myDocument.filePath + "/" + "myDocument_Report" + ".txt";
      myTextFile.open("e");
      myTextFile.seek(0, 2);
      else {
      myTextFile.open("w");
      myTextFile.write(text+"\r");
      myTextFile.close()
      myTextFile.execute()
      Hi All,
      I have created below script. But there is some problem which I am unable to find.
      My two check boxes 1) Find double Spaces and 2) Find Unused Paragraph Styles is not running in this script. When I run this script on ESTK it gives error "Cannot handle the request because a modal dialog or alert is active."
      But every function is working fine as a single script. Please check.
      Thanks in advance for your effort on this.
      Tan
      See my script code below. Its messy but working.
