1 Reply Latest reply on Jul 14, 2007 2:35 AM by Tom Sugden
    Cannot install FB 3 Plugin
    ken_wave
      I'm getting a bunch of errors in the log when I try to install FB plugin 3 on Eclipse 3.3. I tried deleting the workspace and starting with fresh copies of Eclipse and FB. I downloaded FB 3 twice.
      I'm behind an http proxy and it seems like the installer can't connect. I have configured the proxy info into Eclipse. The installer says to check the last log file.
      I get seven log files the last two are:
      eclipse.buildId=I20070625-1500
      java.version=1.5.0_11
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=gtk, NL=en_US
      Framework arguments: -application org.eclipse.update.core.standaloneUpdate -command install -from file:\C:\Program Files\Adobe\Flex Builder 3 Plug-in\eclipse.osu.mirror.slim\datatools.slim -featureId org.eclipse.datatools.enablement.feature -version 1.0.0.200612201
      Command-line arguments: -application org.eclipse.update.core.standaloneUpdate -command install -from file:\C:\Program Files\Adobe\Flex Builder 3 Plug-in\eclipse.osu.mirror.slim\datatools.slim -featureId org.eclipse.datatools.enablement.feature -version 1.0.0.200612201
      !ENTRY org.eclipse.update.core 4 0 2007-07-06 18:41:20.891
      !MESSAGE Error processing update site mirror. [Connection timed out: connect]
      !STACK 0
      java.net.ConnectException: Connection timed out: connect
      at java.net.PlainSocketImpl.socketConnect(Native Method)
      at java.net.PlainSocketImpl.doConnect(Unknown Source)
      at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
      at java.net.PlainSocketImpl.connect(Unknown Source)
      at java.net.Socket.connect(Unknown Source)
      at sun.net.NetworkClient.doConnect(Unknown Source)
      at sun.net.www.http.HttpClient.openServer(Unknown Source)
      at sun.net.www.http.HttpClient.<init>(Unknown Source)
      at sun.net.www.http.HttpClient.New(Unknown Source)
      at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
      at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
      at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
      at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
      at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.setupCurrentEntity(Unknown Source)
      at com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.determineDocVersion(Unknown Source)
      at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
      at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
      at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(Unknown Source)
      at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(Unknown Source)
      at javax.xml.parsers.DocumentBuilder.parse(Unknown Source)
      at org.eclipse.update.core.model.DefaultSiteParser.getMirrors(DefaultSiteParser.java:820)
      at org.eclipse.update.core.model.DefaultSiteParser.processSite(DefaultSiteParser.java:505)
      at org.eclipse.update.core.model.DefaultSiteParser.handleInitialState(DefaultSiteParser.java :387)
      at org.eclipse.update.core.model.DefaultSiteParser.startElement(DefaultSiteParser.java:196)
      at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
      at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(Unknown Source)
      at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl$NSContentDispatcher.scan RootElementHook(Unknown Source)
      at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDis patcher.dispatch(Unknown Source)
      at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unkno wn Source)
      at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
      at javax.xml.parsers.SAXParser.parse(Unknown Source)
      at org.eclipse.update.core.model.DefaultSiteParser.parse(DefaultSiteParser.java:152)
      at org.eclipse.update.core.model.SiteModelFactory.parseSite(SiteModelFactory.java:81)
      at org.eclipse.update.internal.core.SiteURLFactory.createSite(SiteURLFactory.java:80)
      at org.eclipse.update.internal.core.InternalSiteManager.createSite(InternalSiteManager.java: 334)
      at org.eclipse.update.internal.core.InternalSiteManager.createSite(InternalSiteManager.java: 326)
      at org.eclipse.update.internal.core.InternalSiteManager.createSite(InternalSiteManager.java: 305)
      at org.eclipse.update.internal.core.InternalSiteManager.attemptCreateSite(InternalSiteManage r.java:222)
      at org.eclipse.update.internal.core.InternalSiteManager.getSite(InternalSiteManager.java:162 )
      at org.eclipse.update.core.SiteManager.getSite(SiteManager.java:80)
      at org.eclipse.update.search.UpdateSearchRequest.searchOneSite(UpdateSearchRequest.java:452)
      at org.eclipse.update.search.UpdateSearchRequest.performSearch(UpdateSearchRequest.java:323)
      at org.eclipse.update.standalone.InstallCommand.run(InstallCommand.java:144)
      at org.eclipse.update.standalone.ScriptedCommand.run(ScriptedCommand.java:64)
      at org.eclipse.update.standalone.StandaloneUpdateApplication.run(StandaloneUpdateApplication .java:47)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
      at java.lang.reflect.Method.invoke(Unknown Source)
      at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethod(EclipseAppContainer.java: 533)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:155)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:106)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:76)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:504)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
      at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
      at org.eclipse.core.launcher.Main.main(Main.java:30)
      !ENTRY org.eclipse.update.core 4 0 2007-07-06 18:41:20.922
      !MESSAGE Featureorg.eclipse.datatools.enablement.feature 1.0.0.200612201cannot be found onfile:/C:/Program Files/Adobe/Flex Builder 3 Plug-in/eclipse.osu.mirror.slim/datatools.slim
      or a newer version is already installed.
      !SESSION 2007-07-06 18:41:21.344 -----------------------------------------------
      Framework arguments: -application org.eclipse.update.core.standaloneUpdate -command install -from file:\C:\Program Files\Adobe\Flex Builder 3 Plug-in\com.adobe.flexbuilder.update.site/ -featureId com.adobe.flexbuilder.feature.core -version 3.0.172437
      Command-line arguments: -application org.eclipse.update.core.standaloneUpdate -command install -from file:\C:\Program Files\Adobe\Flex Builder 3 Plug-in\com.adobe.flexbuilder.update.site/ -featureId com.adobe.flexbuilder.feature.core -version 3.0.172437
      !ENTRY org.eclipse.update.core 4 0 2007-07-06 18:41:26.438
      !MESSAGE Featurecom.adobe.flexbuilder.feature.core 3.0.172437cannot be found onfile:/C:/Program Files/Adobe/Flex Builder 3 Plug-in/com.adobe.flexbuilder.update.site/
