1 Reply Latest reply on Nov 22, 2010 4:39 AM by Ned Murphy
    frame per seconds
    LeeXiaoLoong
      hi, im new on this forum, i have a question about frame per seconds
      example
      ive created a stickman
      this animation hase example 50 frames
      i set frame per seconds 14
      BUT
      how i can set different speed for different frame?
      example
      frame 1-22 speed 14
      frame 23-41 spped 18
      frame 42-50 speed 5
      is this possible?
      if yes, how?
        • 1. Re: frame per seconds
          If you are using AS3 you can change the speed dynamically using the stage.frameRate property.  So if you start with it at 14, then at frame 23 you would use...
          stage.frameRate = 18;
          and at frame 42 you would use..
          stage.frameRate = 5;
          If you are using AS2, it is not possible to change the frame rate.
