3 Replies Latest reply on Nov 29, 2010 11:26 PM by xxael
    p2p NetConnection stability
    xxael
      Hi everybody,
      i developed a p2p application where users can connect to each other via p2p.
      For this I use NetConnection and NetStream. But sometimes the connection between the to clients disconnects without any assitance.
      I debugged my code and added trace outputs everywhere in the code. But i only get the event of "netstream.closed". So nothing else happend before.
      Now my question is can i get more stability to the p2p connection and how could that be done?
      I hope this is the right forum.
      Thanks in advance
      xxael
        • 1. Re: p2p NetConnection stability
          xxael Level 1
          Is there nobody else who has this problem?
          Is there someting like a puffer or timeout which i can specifiy to bring more stability between two clients connected via netConnection?
          Can the network variations cause the stream to close?
          Thanks in advance
          xxael
          • 2. Re: p2p NetConnection stability
            Michael Thornburgh Adobe Employee
            by "puffer" i assume you mean a keepalive/ping message.
            RTMFP already does this for you automatically.  Cirrus commands its clients to use a keepalive time for P2P connections of 20 seconds (if you're not behind a NAT) or 10 seconds (if you are behind a NAT).
            if your P2P connections come up and are working, but then suddenly die without warning, then i can think of a couple possibilities.  perhaps your NetStreams or NetConnections are being garbage collected because you don't have a solid reference to them?  if this is widespread with your users, it's probably not a network issue, but if it's a small subset of your users, it could be the network.
            • 3. Re: p2p NetConnection stability
              xxael Level 1
              Thanks for the answer,
              what do you mean with "solid reference" ? And what can be other possibilties for this effect? if i am on my local maschine i got this effect very rarely or rather not at all.
              Thanks in advance
              xxael
