11 Replies Latest reply on Nov 23, 2010 4:16 AM by TheGarfunkal
    Object to an ArrayCollection
    TheGarfunkal Level 1
      Hi
      I have an application that takes some database info and shoves it into a datagrid, or chart.
      I've come across this error of having a single row and trying to use it in an array so I can use it in my app.  Its come to my attention that its a pretty common problem that people face, but I don't seem to be able to get around it no matter what a try.
      My actionscript has a fucntion that trots of to the database via ASP, and returns the data in the event - as below (obv i've removed some stuff - load of calls are made to the mssqlQuery function - only the one I have trauma with is below)
      mssqlQuery("SELECT (CASE SLARag ,COUNT (SLARag)  as  Volume  FROM [CMI_ClientMI].[Portal].[BatchUpdate]","BusSegBuildSummary");}
      public static function  mssqlQuery(sql:String,fid:String):void {
      var http:HTTPService = new HTTPService;
      var parm:Object = new Object;
      parm.fas_sql = sql;
      parm.fas_db = mssql_db;
      http.url = mssql_url+"?irand="+Math.random();
      // http.showBusyCursor = true;
      http.request = sql;
      http.addEventListener(ResultEvent.RESULT, mssqlResult);
      http.addEventListener(FaultEvent.FAULT, mssqlFault);
      http.method = "POST";
      sqlToken = http.send(parm);
      sqlToken.param = fid;
      //Var for BusSegBuildSummary arraycollection
      [Bindable]
      public static var _BusSegBuildSummary:ArrayCollection = new ArrayCollection();
      //Case statement for BusSegBuildSummary
      case "BusSegBuildSummary":
      if( event.result.results.record is ObjectProxy ){
      trace("this is object Proxy");
      else{
         trace("this isnt object Proxy");
         _BusSegBuildSummary = event.result.results.record;
      break;
      So - if the result has more than one record in it - then we are fine - its the trace("this is object Proxy"); bit that is troublesome.
      I think that I have to cast the object as an arraycollection and I've tried that a number of different ways with no success.
      Any ideas? I've been struggling for a while now and I'm panicing!
