• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Is it possible to dynamically replace text in the WebHelp output?
New Here ,
Nov 22, 2010 Nov 22, 2010
RoboHelp HTML Version 8
I am currently implementing a WebHelp solution for a web application. I would like to use a variable to tailor information to specific customers. Is it possible to do so without having to generate multiple outputs? In other words, is there some way to replace text when WebHelp is displayed to an end-user?
Views
529
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Nov 23, 2010 Nov 23, 2010
As allways, you can do it with JavaScript, but you (probably) don't want to go that way. Using scripting take a lot of setting up, a lot of maintaining and may be very difficult for other authors.You need to have some way to determine what text you want to show and you need a script to change all the occurances of a viewed page. If you also want to use those variables in the TOC, you'll need to add you're own script to the WebHelp scripts.
From a usability perspective: use variables
Greet,
Willam
Votes
Translate
Translate
Report
Report
New Here ,
Hi William,
Thank you for your reply. However, I'm still a little confused by your last sentence. Are you saying that there is a way to configure variables so that they persist in the WebHelp output? If so, can you provide a little more information as to how to accomplish that?
P.S. My limited experience with variables seems to indicate that the variable gets replaced with text when the project gets compiled. It would be ideal if the variable can persist to the WebHelp output and I could then set the variable on a per session basis.
Joe
Votes
Translate
Translate
Report
Report
LEGEND ,
Nov 24, 2010 Nov 24, 2010
Variables get replace with text when you create your output. In RH8 you have variable sets, so you can create different outputs with different text in your variables.
Dynamically changing content is done trough JavaScript. This involves a lot of scripting in your RH project and asking the question means that you don't want that.
Greet,
Willam
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thanks for taking the time to answer my question. I was looking for an alternative to using a custom script to display dynamic text.
Joe
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
