7 Replies Latest reply on Dec 1, 2010 10:02 AM by kglad
    Random images
    Miks000
      Hi all, I have a question and need help
      This is basically what i want.
      I have a button and onMouseOut I need my flash to load for example
      4 images horizontally, one after another with a sort of a fade in effect (or let's say a simple animation that I desire), BUT
      without repeating the images. Images are brought through a .xml file (max 50 images)
      I've added a simple sketch of a Press button and loaded images
      Thank You
        • 1. Re: Random images
          take it one step at a time.  what's the first problem you encounter?
          • 2. Re: Random images
            Miks000 Level 1
            First of all, i have made when the button is clicked that random images start to appear
            but one instead of another, and that they can repeat.
            I do not want them to repeat; And with loop, I need let's say only 5 of them to appear.
            And they need to appear one after another from right to left. That's what I can't do.
            And also, I need a simple animation like fade in when they appear
            Thanks!
            • 3. Re: Random images
              copy and paste your code.
              • 4. Re: Random images
                Miks000 Level 1
                I have a pictures.xml code for the pictures
                <xml>
                <images>
                </images>
                </xml>
                and then in flash AS2 a movie clip called image_rdm_mc with the code in actions
                xmlImages = new XML();
                xmlImages.onLoad = loadImages;
                xmlImages.load("pictures.xml");
                function loadImages(loaded) {
                if (loaded) {
                xmlFirstChild = this.firstChild;
                imageFileName = [];
                totalImages = xmlFirstChild.childNodes[0].childNodes.length;
                for (i=0; i<totalImages; i++) {
                imageFileName[i] = xmlFirstChild.childNodes[0].childNodes[i].attributes.title;
                      randomImage();
                function randomImage() {
                if (loaded == filesize) {
                var ran = Math.round(Math.random() * (totalImages - 1));
                image_rdm_mc.loadMovie(imageFileName[ran], 1);
                • 5. Re: Random images
                  Miks000 Level 1
                  help
                  • 6. Re: Random images
                    Miks000 Level 1
                    help
                    • 7. Re: Random images
                      1.  loadMovie() accepts one parameter.   fix that.
                      2.  you're loading one image from that array.  if you want to load more you should encode that.
