0 Replies Latest reply on Nov 22, 2010 10:42 PM by gopikrish
    Creating Flex 3.5 components with Flash CS5
    gopikrish
      Is there a way to create components compatible with Flex 3.5 by using  Flash CS5?  Whenever I run the "Convert Symbol to Flex  Component" command and then try to use the resulting .swc file in a Flex  3.5 app, I get multiple instances of the following error:
      1046: Type was not found or was not a   compile-time constant: Matrix3D.
      1046: Type was not found or was not a   compile-time constant: Vector3D.
      Thanks in advance
