1 Reply Latest reply on Nov 22, 2010 9:42 PM by fleRavix
    How to draw tooltip with tail on the bottom right
    Flex Rock Level 1
          I need to draw tooltip with tail on the bottom right side of the tool tip.
      Regards,
      Jayagopal.
        • 1. Re: How to draw tooltip with tail on the bottom right
          fleRavix Level 2
          <mx:Canvas
          xmlns:mx="http://www.adobe.com/2006/mxml"
          width="80"
          height="25"
          minWidth="50"
          minHeight="25"
          horizontalScrollPolicy="off"
          verticalScrollPolicy="off"
          clipContent="false"
          creationComplete="show()"
          showEffect="{showEffect}"
          implements="mx.core.IToolTip"
          cornerRadius="5" backgroundColor="#FFFFFF">
          <mx:Script>
          <![CDATA[
          import mx.core.IToolTip;
          * THIS HAS TO BE an empty string of at least one character to
          * get a tool tip to be created by Flex
          public static const TOOL_TIP_TRIGGER : String = ' ';
          public static const LEFT : String = 'LEFT';
          public static const RIGHT : String = 'RIGHT';
          public static const UP : String = 'UP';
          public static const DOWN : String = 'DOWN';
          /** A summed combination of left/right (or top/bottom) padding */
          private static const PADDING_SUM : int = 40;
          private static const PADDING : int = 20;
          private static const MIN_HEIGHT : int = 55;
          private static const DEF_ONE_FIELD_VISIBLE_HEIGHT : int = 59;
          private static const DEF_TWO_FIELD_VISIBLE_HEIGHT : int = 35;
          private static const DEF_WIDTH : int = 135;
          private static const MIN_WIDTH : int = 50;
          private static const MAX_WIDTH : int = 300; //262;
          private static const HTML_MODE_WIDTH : int = 200;
          private static const HTML_MODE_HEIGHT : int = 150;
          private static const HTML_MODE_MAX_HEIGHT : int = 200;
          private static const FIRST_LINE_Y : int = 17;
          private static const SECOND_LINE_Y : int = 36;
          /** This is the height of the title text filed for a single line of text*/
          private static const DEF_TITLE_TEXT_FIELD_HEIGHT : int = 24;
          /** This is the height of the content text filed for a single line of text*/
          private static const DEF_CONTENT_TEXT_FIELD_HEIGHT : int = 21;
          [Bindable] private var _titleVisible : Boolean = true;
                  [Bindable] private var _contentVisible : Boolean = true;
                  /** required methods of the IToolTip interface; **/
                  public var _text:String;
                  [Bindable]
                  private var _backgroundColor : uint = 0xFFFFFF;
                  [Bindable]
                  private var _strTitleText:String = "";
                  [Bindable]
                  private var _strContentText:String = "";
                  [Bindable]
                  private var _direction :String = DOWN;
                  [Bindable]
                  private var _spawnPoint : Point = null; //new Point(0,0);
                  private static var _miCoachToolTip:ArrowToolTip;
                  public static function getInstance():ArrowToolTip
                  if (_miCoachToolTip == null)
                  _miCoachToolTip = new ArrowToolTip();
                  //_miCoachToolTip.reset();
                  return _miCoachToolTip;
                  public function get text():String {
                      return _text;
                  public function set text(value:String):void
                  //_text=value;
            /** If HTML text is provided, other fields hidden **/
          [Bindable]
                  public function get htmlText():String
                      return _strHtmlText;
                  public function set htmlText( value : String ):void
                     _strHtmlText = value;
                     if(_strHtmlText != null && _strHtmlText != '')
                     _strContentText = null;
                     _strTitleText = null;
          [Bindable]
                  public function get titleText():String
                      return _strTitleText;
                  public function set titleText( value : String ):void
                     _strTitleText = value;
                     if(value != null && value != '')
                     //_strHtmlText = null;
                     _titleVisible = false;
                     _contentVisible = false;
          [Bindable]
                  public function get contentText():String
                      return _strContentText;
                  public function set contentText( value : String ):void
                     _strContentText = value;
          [Bindable]
                  public function get direction():String
                      return _direction;
                  public function set direction( value : String ):void
                     _direction = value;
          [Bindable]
                  public function get spawnPoint():Point
                      return _spawnPoint;
                  public function set spawnPoint( value : Point ):void
                     _spawnPoint = value;
                  private function show() : void
          _backgroundColor = this.getStyle('backgroundColor') as uint;
          layoutTextFields();
          //adjustSizingForText();
          drawArrow();
          private function layoutTextFields () : void
          layoutForStandardText()
          * This takes into account if one, two or all three fields are visible
          * It positions and resizes as needed.
          * Not 100% operational as of 11-5-2008
          private function layoutForStandardText () : void
          //_useHTMLText = false;
          // //this.width = DEF_WIDTH;
          //this.height = DEF_TWO_FIELD_VISIBLE_HEIGHT;
          _titleVisible = (_strTitleText != null && _strTitleText != '');
          _contentVisible = (_strContentText!= null && _strContentText != '');
          var metricsTitle : TextLineMetrics;
          var metricsContent : TextLineMetrics;
          //Only Title is visible/enabled
          if(_titleVisible  && !_contentVisible)
          this.height = DEF_ONE_FIELD_VISIBLE_HEIGHT;
          //metricsTitle = txtTitle.measureText(txtTitle.text);
          //txtTitle.y = FIRST_LINE_Y;
          this.height = MIN_HEIGHT;
          this.width = MIN_WIDTH;
          // this.height = txtTitle.height + (PADDING * 1.5);
          this.height = metricsTitle.height + (FIRST_LINE_Y * 2)
          if((metricsTitle.width + (PADDING_SUM)) > MAX_WIDTH)
          this.width = MAX_WIDTH;
          else
          this.width = metricsTitle.width + (PADDING_SUM);// + 3;
          //Adjust the height if more than one line in the content
          // if( txtTitle.height > DEF_TITLE_TEXT_FIELD_HEIGHT)
          // this.height = this.height + (txtTitle.height - DEF_TITLE_TEXT_FIELD_HEIGHT);
          //Only Content is visible/enabled
          else if(!_titleVisible  && _contentVisible)
          metricsContent = txtContent.measureText(txtContent.text);
          txtContent.y = FIRST_LINE_Y;
          //Calcs for content
          if((metricsContent.height + (PADDING_SUM + 2 )) > DEF_ONE_FIELD_VISIBLE_HEIGHT)
          else
          this.height = metricsContent.height + (PADDING_SUM) + 2;
          if((metricsContent.width + (PADDING_SUM)) > MAX_WIDTH)
          else
          this.width = metricsContent.width + (PADDING_SUM);// + 2;
          if( txtContent.height > DEF_TITLE_TEXT_FIELD_HEIGHT)
          this.height = this.height + (txtContent.height - DEF_TITLE_TEXT_FIELD_HEIGHT);
          //Only Sub title disabled/invisible
          //This is default on Plan details
          else if(_titleVisible  && _contentVisible)
          txtContent.y = SECOND_LINE_Y;
          //Calcs for title
          if((metricsTitle.width + (PADDING*3)) > MAX_WIDTH)
          else
          this.width = metricsTitle.width + (PADDING_SUM + 2);
          //Calcs for content
          if((metricsContent.width + (PADDING_SUM + 2)) > MAX_WIDTH)
          else
          //Only reset the width if the second line of text is longer than the first
          if((metricsContent.width + PADDING_SUM) > this.width)
          this.width = metricsContent.width + PADDING_SUM;// + 2;
          //Default height for one line
          this.height = metricsTitle.height + metricsContent.height + PADDING_SUM - 3;;
          if( txtContent.height > DEF_CONTENT_TEXT_FIELD_HEIGHT)
          this.height = this.height + (txtContent.height - DEF_CONTENT_TEXT_FIELD_HEIGHT) + 2;
          * draw the colored and white backgrounds, and the arrow
          private function drawArrow ():void
          var g:Graphics = this.graphics;
          g.clear();
          g.beginFill(0xFFFFFF, 1);
          whiteHRule.x = this.width - 40;
          whiteHRule.y = 20;
          g.moveTo (this.width - 50, 25);
          g.lineTo (this.width - 40,  50);
          g.lineTo (this.width - 30, 20);
          protected override function commitProperties():void
          super.commitProperties();
          protected override function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
          super.updateDisplayList(unscaledWidth, unscaledHeight);
          layoutForStandardText();
          drawArrow();
          public function reset () : void
          </mx:Script>
          <mx:Text
          id='txtContent'
          text="{_strContentText}"
          width='100%'
          paddingLeft="0"
          paddingRight="0"
          paddingBottom="0"
          paddingTop="0"
          y="3" x="2" textAlign="center" fontFamily="Verdana" fontSize="9" fontWeight="bold"/>
          <!-- This line is here simply to get rid of the canvas border where the pointer touches the panel -->
          <mx:HRule y='{this.height - 1}' id="whiteHRule" x='20' width="21" strokeWidth="1" strokeColor='{_backgroundColor}'/>
          <mx:Fade id="showEffect" alphaFrom="0" alphaTo="1" duration="200"/>
          </mx:Canvas>
          Mark this answered if helpful
