4 Replies Latest reply on Nov 23, 2010 9:22 AM by Todd_Kopriva
    Memory set up for CS5
    Dan Jacobsen
      Hi all,
      I've just got a new PC with CS5. I had put multiprocessing on but I think everything else was in default.
      It was rendering well until a particularly large comp threw uop this error message while rendering:
      Unable to allocate 0.063MB of memory. Either reduce memory required for rendering this frame or install more RAM. (12803/object or shadow fragment) For more information see adobe.com/go/learn_ae_mem
      I had a quick look through these pages and although I didn't fully understand it, it seemed to indicate that AE needs a certain ammount of RAM to render a certain frame - not that it would just take longer as I would have imagined.
      Does this mean I would need to simplify my comp? It would be hard as it was a lot of ojects with shadows.
      I'm hoping the Preferences/memory page is not optimised for the PC. Could anyone give me some advise on what to change or how to get around this?
      System:
      Xeon X5570 @ 2.93GHz
      16 cores
      12GB RAM
      running Win 7 64
      Preferences/Memory is set to:
      RAM reserved for other apps 3GB
      RAM available for AE 9GB
      Render Multiple Frames on
      INstalled cores 16
      CPUs reserved for other apps 8
      RAM Allocation per BGND CPU 0.75GB
      Actual CPUs that will be used 8
      Any ideas what I should change here?
        • 1. Re: Memory set up for CS5
          You are using way too many cores.... Even for "light" comps, 8 cores with only 12GB is not really a good way too work. You need a lot more RAM. Set the render instances to 3 or 4 at most in your current environment.
          Mylenium
          • 2. Re: Memory set up for CS5
            Dan Jacobsen Level 1
            So it sounds like a lot of cores will be redundant.
            Would it be good idea to throw more RAM in then? I mean cost effeciant?
            How much RAM per core should I consider, and how many of my cores should I aim to use?
            • 3. Re: Memory set up for CS5
              Yes; buy more RAM.
              Try these recommended settings.
              • 4. Re: Memory set up for CS5
                Todd_Kopriva Level 8
                It depends on what kind of work you're doing and whether the rest of your system is powerful enough to not introduce other bottlenecks.
                A good rule of thumb is to have 3-4GB installed per core, and then only assign 2/3 to 3/4 of that to After Effects. I have 24GB installed in my hyperthreaded quad-core computer, which has 8 processors counting the virtual processors created by hyperthreading. I leave 2 processors and 6GB for other applications, leaving 6 processors and 18GB for After Effects. This works well for me when I'm working on 2K RED frames. I move to using only 4 processors when I'm using 4K frames.
                Follow the link that Szalam gave. It has our current recommendations for starting points---but they're still just starting points.
                BTW, regarding the bottlenecks that I mentioned at the top of this response: If you've got a lot of processors, you need to make sure that you've got fast hard disks that can feed them with input (source files) and offload their output (rendered and encoded frames). I see way too many people with screamingly powerful computers that are bogged down trying to push and pull data through tiny I/O pipes.
