2 Replies Latest reply on Nov 23, 2010 12:19 PM by gremuk
    No Such Device Error EntityLoad - output
    gremuk
      Getting an odd error 'No such device' on CF9.1 @ Linux Server
      Error refers to:
      C:\work\ColdFusion\cf9_u1_final_hotfix\cfusion\wwwroot\WEB-INF\cftags\dump.cfm
      on Linux?
      No such device
      ColdFusion cannot determine the line of the template that caused this error. This is often caused by an error in the exception handling subsystem.
      Resources:
      Browser  Mozilla/5.0 (X11; U; Linux x86_64; en-US) AppleWebKit/534.11 (KHTML, like Gecko) Chrome/9.0.570.1 Safari/534.11
      Remote Address  192.168.56.101
      Referrer
      Date/Time  23-Nov-10 02:53 PM
      Stack Trace
      at cfdump2ecfm1346696724._factor1(C:\work\ColdFusion\cf9_u1_final_hotfix\cfusion\wwwroot\WEB -INF\cftags\dump.cfm) at cfdump2ecfm1346696724._factor4(C:\work\ColdFusion\cf9_u1_final_hotfix\cfusion\wwwroot\WEB -INF\cftags\dump.cfm) at cfcat2ecfm2074738090.runPage(/var/www/walks/story.cfm:27)
      Code:
      Modified from:  http://www.manjukiran.net/2009/07/14/101/
      stories = EntityLoad( "Story");
      for (i=1; i<ArrayLen(stories);i++) {
          storyObj = stories[i];
           WriteOutput("Story ID: " & storyObj.getStoryID() & "<br>");
           WriteOutput("Story Title: " & storyObj.getStoryTitle() & " <br>");
           WriteOutput(" <br>");
      </cfscript>
      <cfdump var="#stories#"/>
      Outputs
      2 array items and 3 'dump items'
      Story ID: 1
      Story Title: A return to Forbidden Britain
      Story ID: 2
      Story Title: The Countryside Code
      array
      1[undefined array element] No such device
      2[undefined array element] No such device
      3[see cfc6 for Story details]
      Trying to fix triggers error above
      Very Strange
        • 1. Re: No Such Device Error EntityLoad - output
          Sam Farmer
          That error means something went wrong in the cfdump output.
          Can you post the code for the Story.cfc?
          • 2. Re: No Such Device Error EntityLoad - output
            gremuk
            Hello Sam
            Thanks for reply
            Object of type 'class coldfusion.orm.PersistentTemplateProxy' cannot be used as an array Came up
            - a little clearer - if I knew what 'class coldfusion.orm.PersistentTemplateProxy' was!
            The code is wrapped in Model-Glue - so code post would not be helpful -
            a  <message name="ModelGlue.genericRead"> call in ModelGlue.xml
            I've bypassed and rolled in EntityLoad - sick of hitting my head here
            The windows C:\  path spooked me a bit - I'll post problem to Model Glue forum
            Once again
            Many thanks
            G
