3 Replies Latest reply on Nov 24, 2010 9:51 AM by Sean_Wilson
    Strange error in compiling
    Hosseinrostamzadeh
      Please help, this gets me MAD!!!
      When I run this code every thing goes normally, It means that I can access all variables later in the movie.
      on mouseUp me
        global  usrName,usrSurName, password
      --  if sprite("usrNameTF").text = "" or sprite("usrSurNameTF").text = "" or sprite("passwrdTF").text = ""  then
      --    alert("Fill alle fields to continue!")
      --    go to the frame
      --  else
      --    go to frame "menu"
      --  end if
        usrName = sprite("usrNameTF").text
        usrSurName = sprite("usrSurNameTF").text
        password = sprite("passwordTF").text
      end
      BUT when  I uncomment the commented section above(because I need it) I get error, where it says PROPERTY NOT FOUND ........... # text
      It simply does not accept a sprite to have a property named "text"
      What is wrong with this section??
      why it does not annoy with three last lines where I use the same concept i.e.  sprite("usrNameTF").text ???? here the text property causes no problem and works as it is designed.
      Any help is appreciated.
      Best regards!
      HR
        • 1. Re: Strange error in compiling
          Sean_Wilson Adobe Community Professional
          I suspect it's a typo. Your top code asks for sprite("passwrdTF").text while below you refer to sprite("passwordTF").text - do you see the difference?
          Try the following modification:
          on mouseUp me
            tUsername = sprite("usrNameTF").text
            tSurname = sprite("usrSurNameTF").text
            tPassword = sprite("passwordTF").text
            if tUsername = "" or tSurname = "" or tPassword = ""  then
            else
              usrName = tUsername
              usrSurName = tSurname
              password = tPassword
              go to frame "menu"
            end if
          end
          • 2. Re: Strange error in compiling
            Hosseinrostamzadeh Level 1
            Thank you Sean!
            Your suggestion helped.
            But I still do not get the point why
            if sprite("passwordTF").text = "" then
            end if
            should cuase an error in compiling at all??
            The exchange between passwrd and password in
            was just typing error.
            Best regards!
            HR
            • 3. Re: Strange error in compiling
              I thought it was a runtime error you were seeing, not a compiler error.
