5 Replies Latest reply: Nov 24, 2010 3:28 AM by JayNewWeb RSS
    Print quality is compromised
    JayNewWeb Community Member
      I'm using InDesign CS3. I also have Photoshop CS3. XP Pro SP3.
      I bought a picture from iStockPhoto that came at 2720x1807 at 300 dpi. I open it in Photoshop and it's in RGB mode. Here's the image (this image is licensed so please respect that):
           [Link removed by forum moderator]
      I have an HP CP2025 color LaserJet.
      When I print that image directly from Photoshop, the colors are great and the natural gradual shift in the brightness of the blue sky is a very smooth transition.
      But when I place it in InDesign and print it, the colors suffer and the gradual shift in brightness of the blue sky is far less smooth of a transition.
      The same thing happens if I export it from InDesign to a PDF and then print that:
            www.silver100.com/x/clouds-pdf.zip
      Any suggestions?
      Thanks.
      Message was edited by: Peter Spier. If you need to see the image, please contact the OP directly.
        • 1. Re: Print quality is compromised
          [Jongware] Community Member
          Your document may be in CMYK mode, so every color image gets translated to that.
          • 2. Re: Print quality is compromised
            Thanks.
            That partly solved it.
            I can't find any place in InDesign in Document Setup or Preferences to make it into an RGB (or CMYK) document per se.
            What I'm finding under Edit > Color Settings are settings for both RGB and CYMK (which I'm so far leaving at the defaults). It's apparently not an "either-or" choice; it's just settings for both.
            On printing from InDesign, however, I've now noticed, following your suggestion, that in the Print > Output dialog is a dropdown for Color that was defaulting at Composite CMYK. When I change that to Composite RGB and then proceed to print, it's printing correctly, like it did from Photoshop.
            So, that's got my problem partly solved.
            I'd like to please ask if you can perhaps also help me figure out how to Export from InDesign to a PDF without the loss in quality. (I often have my employee do the printing in-house to our color LaserJet from their computer, which has Acrobat Reader but not InDesign. And sometimes I send a print job out to a local print shop, in which case I typically just give them a PDF.)
            Thanks again!
            • 4. Re: Print quality is compromised
              P Spier CommunityMVP
              I've removed the link to the copyrighted image. This forum is shared with the world and everyone reading may not be as honest as you.
              • 5. Re: Print quality is compromised
                Eugene Tyson wrote:
                There's a good read here
                http://indesignsecrets.com/my-cmyk-images-change-when-i-print-or-expor t-pdf.php
                Thanks, but frankly this is going way over my skill level and I could get myself into trouble even trying to dabble in most of what it discusses. I did read it thoroughly, though.
                I had already previously tried to export to PDF from InDesign with Export > Adobe PDF > Output > Color Conversion > Convert to Destination > sRGB IEC619662.1 but that didn't change the result at all.
                After having read the article, I checked the box for Color Settings > Profile Mismatched - Ask When Opening and made sure the default for Color Management Policies - CMYK was as indicated in the article (Preserve Numbers), but on closing and reopening the document it didn't flag me about anything.
                So, other than getting into Embedded Profiles, which I'm sure is way over my head and an invitation for getting myself into real trouble, I'm still at a loss.
                I even tried opening the original JPEG in Photoshop, saving that as a PSD, and placing that in InDesign and doing Export to PDF, but that didn't help either. I even tried unchecking Save As > Adobe RGB (1998) while doing the export and still no dice. (I'm also having the identical issues trying to Save As > Adobe PDF in Photoshop even after trying most of the same approaches I tried in InDesign.)
