5 Replies Latest reply on Nov 24, 2010 7:40 AM by Buqpa
    Stroke filling a path
    Buqpa
      Hello everybody,
      I have spent the last hours trying to figure this out, but I feel clueless...
      I want a stroke to fill a path with differente thinkness. It is like a shadow being filled. I really want to use the "begin-finish" effect inside the stroke and I could manage to do do it simply with the stroke effect if all the shadow have the same thickness, but it changes depending the place...
      Any suggestion?
      Best,
      Diego
        • 1. Re: Stroke filling a path
          Create the variance on a separate layer then use that layer as a matte on the actual layer that has a big fat stroke being animated along a mask....
          Mylenium
          • 2. Re: Stroke filling a path
            Buqpa Level 1
            Great suggestion, but I have the following problem: a thick stroke "jumps" because of its thickness, like too many pixels per step.
            Is that normal? Is there a way to avoid that? It feels like it tries to advances too many pixels per frame,
            Best,
            Diego
            • 3. Re: Stroke filling a path
              Try to use shape layer paths with capped ends (create the path, apply a Trim Paths modifier). This wil lavoid the big rounded blob effect. Additionally, consider pre-composing the wipe and applying CC Force Motion Blur to enforce a few sub-samples and make it look more pleasing...
              Mylenium
              • 4. Re: Stroke filling a path
                Buqpa Level 1
                Woah, thanks! Let me try it
                It seems to be a bit tricky :S
                • 5. Re: Stroke filling a path
                  Buqpa Level 1
                  Well, I have tried like 20 times but I do not achieve the effect Isn't there a simple way to make the stoke to go pixel by pixel?
                  An alternative may be the following: draw a closed shape and fill it following a path. Is that possible on AE? How can I do it?
                  Thanks for all your replay M.
