2 Replies Latest reply on Nov 25, 2010 12:22 AM by etienne4life
    Try to find explanations
    etienne4life
      hello all,
      i just would like to have an explanation i don't find in the Help.
      If i make my own component, i can make "Action sequences".
      In "Add an action", I can choose "Define propertie". Then, i can choose "Activated" or "Opacity". If i select "Activated", i can choose "True" or "False".
      What does it means and what can i do with that.
      Sorry if the description is incorrect but I'm working on a French interface.
      Etienne
        • 1. Re: Try to find explanations
          Mykola D. Level 1
          Hi Etienne,
          In the English version of FC this option is called Enabled. If you set it Off, the component will be disabled after the action is executed.
          The generated code will have something like this:
                  <s:Parallel id="Sequence1">
                      <s:Parallel target="{customcomponent1}">
                          <s:SetAction property="enabled" value="false"/>
                      </s:Parallel>
                  </s:Parallel>
          Does it answer your question?
          - Mykola
          FC QE
          • 2. Re: Try to find explanations
            etienne4life Level 1
            YES, thank you very much !!
            Etienne
