7 Replies Latest reply on Nov 27, 2010 3:37 PM by kglad
    AS1 and 2 reading from PHP
    ssamuels222
      Hello.
      I have a php file which ends with:
      if (mail($mailto,$subject,$message, $headers)) {
      $message_back = "Success";
      echo "Success";
      } else {
      $message_back = "Your email could not be processed";
      echo "No Success";
      I can loadVars into it just fine and it sends the email as well.
      My question is: How do I read back into AS1 the variable message_back.
      or is echo also read into as1.
      I am new to this subject and still trying to understand the communication aspect of it.
      Thanks for any insight on this. Samantha
        • 1. Re: AS1 and 2 reading from PHP
          with as1, you have to use loadVariables and start a loop that awaits the php return.
          • 2. Re: AS1 and 2 reading from PHP
            ssamuels222 Level 1
            Hi kglad
            I think, I do have a loop in as1 and it uses loadVariables but my question is how do I read into as1 the php variable $message_back. or the echo?
            Do I assign it to a varialble?
            Does as1 just knows that message_back exists.
            Do I have to have message_back in as1 empty until I get the message back and then assign it to it.
            This is my script on my submit button. The function below (what I think is my loop) checks for the output to be sent. But I don't know if 'sent' is an actual variable that Flash just understands to check for success:
            on (release) {
                  if (conditions for success-sorry I took these out because it was too long and it didn't keep the format)
                         sender_name = _root.pag.pages.page7.tf_1;
                         sender_email = _root.pag.pages.page7.tf_3;
                         sender_message = _root.pag.pages.page7.tf_4;
                         message_back = _root.pag.pages.page7.cfMessage;
                         loadVariables("process.php",this, "POST");
                         _root.pag.pages.page7.cfMessage = "Processing...";
                         _root.pag.pages.page7.tf_1 = "";
                         _root.pag.pages.page7.tf_3 = "";
                         _root.pag.pages.page7.tf_4 = "";
                         this.onData = function()    {
                               if(this.output ne 'sent')  {// in case of error
                                    _root.pag.pages.page7.cfMessage = "Your message was not sent by the server. Please check your email.";
                                     Selection.setFocus("_root.pag.pages.page7.tf_3");
                                     _root.pag.pages.page7.b = 1;
                                     _root.pag.pages.page7.tf_1 = sender_name;
                                     _root.pag.pages.page7.tf_3 = sender_email;
                                     _root.pag.pages.page7.tf_4 = sender_message;
                               } else { //   Success!";
                                     _root.pag.pages.page7.cfMessage = "Thanks for your message. Someone will get back to you shortly";
                                     Selection.setFocus("_root.pag.pages.page7.tf_1");
                                     _root.pag.pages.page7.b = 0;
                _root.pag.pages.page7.bSubmit.enabled = false;
            else {
                   if (_root.pag.pages.page7.tf_1 eq "") {
                         _root.pag.pages.page7.cfMessage = "Please enter a name";
                             Selection.setFocus("_root.pag.pages.page7.tf_1");}
                   else if (_root.pag.pages.page7.tf_3 eq "") {
                         _root.pag.pages.page7.cfMessage = "Please Enter a valid email";
                         Selection.setFocus("_root.pag.pages.page7.tf_3");}
                   else if (EMAIL CONDITIONS-too long to fit properly ) {
                  else if (_root.pag.pages.page7.tf_4 eq ""){
                          _root.pag.pages.page7.cfMessage = "Please write your message";
                          Selection.setFocus("_root.pag.pages.page7.tf_4");}
            Thanks, Samantha
            • 3. Re: AS1 and 2 reading from PHP
              use:
              echo $message_back = "Success";
              } else {
              echo $message_back = "Your email could not be processed";
              and look for message_back to be defined to terminate your loop and respond to the value.
              • 4. Re: AS1 and 2 reading from PHP
                ssamuels222 Level 1
                Hi Kglad,
                I followed your lead and used:
                } else {
                I then waited for message_back but Flash never saw it.
                I now changed it to:
                          echo "$response= Success";
                     } else {
                          echo "$response= Server Error";
                Also I decided to make it a bit more formal in Flash and did this for my function to receive the variables:
                on (release) { //within my submit button
                //I created 2 LoadVars objects to send data and receive it back from PHP
                      dataSender = new LoadVars();
                      dataReceiver = new LoadVars();
                //Then I proceeded to check my conditions for the input fields
                            if ( everything is ok anf filled)
                                 { // I then assigned the Loadvars objects my input fields
                                  dataSender.sender_name = _root.pag.pages.page7.tf_1;
                                  dataSender.sender_email = _root.pag.pages.page7.tf_3;
                                  dataSender.sender_message = _root.pag.pages.page7.tf_4;
                                  dataSender.message_back = _root.pag.pages.page7.cfMessage;
                               // I now tell the user that the information is been processed
                               //I now use the onload attribute to receive feedback from PHP
                               dataReceiver.onLoad = function() {
                                  _root.pag.pages.page7.cfMessage = "After Function";
                                   if (this.response eq "Success") {
                                         _root.pag.pages.page7.cfMessage = "Success"; //This is to test if it is going through this I want to use the dataReceiver.response below
                                         _root.pag.pages.page7.cfMessage = dataReceiver.response;
                                         _root.pag.pages.page7.cfMessage = "Thank you for your message. Someone will get back to you shortly.";
                                   else if (this.response eq "error") {
                                         _root.pag.pages.page7.cfMessage = "Error"; //This is to test if it is going through this
                                         _root.pag.pages.page7.cfMessage = "Please check email address - does not appear valid."
                                   else if (this.response eq "Server Error") {
                                   _root.pag.pages.page7.cfMessage = "server error";
                                   _root.pag.pages.page7.cfMessage = "Your message was not sent. There seems to be a server error";
                             dataSender.sendAndLoad("process.php", dataReceiver, "POST");
                             _root.pag.pages.page7.cfMessage = "after enabled";
                else {
                            if (if the fields are blank or have the wrong information) {
                                  _root.pag.pages.page7.cfMessage = "Please enter correct and valid info";
                Flash still does not see it. I do get the emails so the form is been processes correctly
                I also used an html form to check PHP and PHP echoes back response=Success
                So I know PHP is executing but Flash AS1 does not see "response"
                Can you see anything I am doing wrong? I would really appreciate it. Sorry for the long coding. I tried to shorten it as much as I thought was logical.
                Thanks S.
                • 5. Re: AS1 and 2 reading from PHP
                  are you publishing for fp 6 or better?
                  • 6. Re: AS1 and 2 reading from PHP
                    ssamuels222 Level 1
                    Hi Kglad,
                    I am publishing for Flash 6 AS1.
                    I discovered that I could not pass the "if" conditions because flash is reading a lot of url encoding symbols like %20 etc.
                    I thus change my AS1 in Flash to the following and now it reads the php which I also changed (see below).
                    But I still have 2 problems. First: The condition is always testing "true" even when the email is not sent. Second: The variables read have all these characters embedded when Flash reads them (%20 etc). I placed comments within the code to tell you what "I think" is happening.
                    This is the AS1 on my submit button:
                    on (release) {
                    //create the LoadVars objects which will be used to send data...
                    var dataSender = new LoadVars();
                    //and one to catch what comes back
                    var dataReceiver = new LoadVars();
                    /*dataReceiver.onLoad = getResponse;*/
                      if ( all conditions for input field are met )
                            dataReceiver.onLoad = function(phpresult) {
                             if (phpresult eq true) {
                               _root.pag.pages.page7.cfMessage = dataReceiver;
                              /*_root.pag.pages.page7.cfMessage = "Thank you for your message. Someone will get back to you shortly."*/
                              /*_since I only have a message coming back. I don't have to use a for loop to read an array*/
                        else if (phpresult eq "one") {
                              /*For "one" I just send "one" in php so I have to write the answer here.*/
                        else if (phpresult eq false) {/dataReceiver contain an error at server
                    else { // if blank or email has no @ or "." or is blank between @ and ".". Ask user to fix.
                      if (if user needs to fix his input it goes here){
                    This is the php loop
                    $message_backorig="Success";
                    $message_back=rawurlencode ($message_backorig);
                    echo "&$message_back";
                    $dataReceiver .='&';
                    echo "&$dataReceiver";
                    //echo sends back a true or false response to flash.
                    //If I don't put the "&" percent is just does not read anything in flash
                    //But this loop is always true based on flash and it never waits for it to be false. Also the
                    // &$dataReceiver is read with the %20 characters like so  -- Success=&%0D%0A%0D%0A=&onLoad=%5Btype%20Function%5D
                    //So it gives me the "Success" from been true but it adds all this other stuff" With an html form I test the same php and it returns just &Success&&
                    } else
                    $message_back="Server Error. Please check your email";
                    Thanks Kglad. Agian the answer to your question is Flash 6 As1
                    • 7. Re: AS1 and 2 reading from PHP
                      i can't read that actionscript it's formatted so badly.  fix that so it's readable.
