1 Reply Latest reply on Nov 26, 2010 2:32 AM by christoferdutz
    Complex controls in Flex4 skins
    christoferdutz Level 1
      I am currently evaluating tools for integration testing of Flex applications. Currently I am working with Ranorex and am pretty sattisfied with it ... except that I was having some problems with a spark DropDownList that I use for selecting the language in my main applications skin. The Ranorex support claimed that I shouldn't use "complex controls" such as a DropDownList in a Spark Skin and that a Skin should be treated as nothing else than a complex CSS File.
      Well this statement stands in contrast to the way I understood the skinning of flex. I allways thought the Idea is to define Components in Code (ActionScript ... or MXML) leaving away the design-considerations and to define a skin that places, layouts, formats the controls a component needs. The Component is ideally developed by a Software-Developer and the Skin can be entirely provided by the Designer. This way everybody can work in that domain of expertise that he is best in.
      In the component I define SkinParts which tells the Designer which controls I need and he uses them accordingly in his skin. By given the control in the skin the same id as the variable-name in the component the Flex framework sets the instance of the control in the component and then calls the partAdded function to tell the component that the control is now available ... well at least this is the way I understood this.
      I hope I understood this correctly. If not, I would be really glad to know how I should introduce a DropDownList in my applications skin without actually using a DropDownList.
      Chris
