0 Replies Latest reply on Nov 25, 2010 3:57 AM by Sen Imagines
    Non uniform intervals in the X-axis of LineChart
    Sen Imagines
      I am using a Flex3 Line chart which takes data from an External XML file.
      But I dont get the DataTip points correctly if i give some numeric values in the X values and
      even then, the values in the X-axis starts from the "0"th position and the interval between the "0"th & 1st value (in X axis) is half of the others (shown in red bar in the attached image) and also for the last one.
      How to have the uniform intervals in the X-axis so that the DataTip shows correct values as in the data?
      Below is the MXML & the XML I use:
      The MXML:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" width="100%" backgroundColor="0xFFFFFF" creationComplete="fetchData();">
      <mx:HTTPService id="myServ" url="TempChartData.xml" fault="faultHandler(event)"/>
      <mx:Script>
      <![CDATA[
           import mx.controls.Alert;
           import mx.rpc.events.*;
           import mx.controls.ToolTip;
           //Trigger the HTTPService to fetch data from the back-end
           public function fetchData():void
                myServ.send();
           public function faultHandler(event:FaultEvent):void
                Alert.show(event.fault.message);
      </mx:Script>
      <mx:LineChart id="myChart" width="100%" height="100%" showDataTips="true" dataProvider="{myServ.lastResult.tasks.task}">
           <mx:horizontalAxis>
                <mx:CategoryAxis id="myHorzAxis" categoryField="name" title="My Tasks"/>
           </mx:horizontalAxis>
           <mx:verticalAxis>
                <mx:LinearAxis title="My Data Values"/>
           </mx:verticalAxis>
           <mx:horizontalAxisRenderers>
                <mx:AxisRenderer axis="{myHorzAxis}" labelRotation="45"/>
           </mx:horizontalAxisRenderers>
           <mx:series>
                <mx:LineSeries id="myLineSeries1" xField="name" yField="Value">
                </mx:LineSeries>
           </mx:series>
      </mx:LineChart>
      </mx:Application>
      TempChartData.XML
      <tasks usl="25" lsl="-75">
          <task name="1">
              <Value>-115</Value>
          </task>
          <task name="2">
              <Value>-112</Value>
          </task>
          <task name="3">
              <Value>-100</Value>
          </task>
          <task name="4">
              <Value>0</Value>
          </task>
          <task name="5">
              <Value>-74</Value>
      </task>
          <task name="6">
          <Value>0</Value>
          </task>
          <task name="7">
          <Value>-67</Value>
          </task>
      </tasks>
