2 Replies Latest reply on Nov 27, 2010 10:50 AM by Arnoud Bos
    Flex 4.1 with flex 3.5 SWFLoader breaks PopupManager (marshaling plan bug?)
    Arnoud Bos Level 1
      I'm building a prototype application making use of the nested SWFLoader. That loader needs to open a popup (An alert).
      Unfortunately this gives a null pointer...
      And yes I included the Popupmanager in the host application. The SWFLoader is loaded in a sandbox (loadForCompatibiliy=true, trustContent=false)
      The error i get is in
      public function addPopUp(window:IFlexDisplayObject,
                            parent:DisplayObject,
                            modal:Boolean = false,
                            childList:String = null,
                            moduleFactory:IFlexModuleFactory = null):void
      here:     if (window is IUIComponent)
                  IUIComponent(window).isPopUp = true;
      gives: Main Thread (Suspended: TypeError: Error #1009: Cannot access a property or method of a null object reference.)
      mx.managers::PopUpManagerImpl/addPopUp
      mx.managers::PopUpManager$/addPopUp
      mx.controls::Alert$/show
      SubApp/___SubApp_Button1_click
      and the debugger shows me that window is an alert instance. So the casting goes wrong.
      What i also see is that FlashBuilder debugs
      the flex 4.1 popupmanager even though the Sub app (3.5 swf) is loaded via SWFLoader in a sandbox!  (loadForCompatibiliy=true, trustContent=false)
      But even if it was not loaded in a sandbox the Marshaling plan should work because loadForcompatibility is set to true...
      Any clues?
      If someone is interested i can put a .zip of the project online...
      Thnx,
      Arnoud
